It has an electronic igniter,Just make sure the gas is turned on the the dryer(at the valve located behind it)and make sure the power cord is plugged in.
99% of the time it is just dirt and dust in the pilot light. NOT a bad thermocouple! These units generate their own power through the pilot light and it has to burn perfectly. Turn off gas supply, remove the cover and the pilot light assembly, including disconnecting the tiny gas line from the gas valve. Blow compressed air in, around and through it to get dust out. Replace everything, use soap bubbles at gas fittings to leak test and light the pilot. I bet it stays lit.
Shut gas valve off and let it air out. You can see the pilot with the little rod on it. Turn valve to pilot position and light a lighter to light the pilot. Hold the valve for a minute. If it stays lit, then turn valve fully to the ON position.
The pilot light has a thermal sensor above it to determine if the gas is burning or not. If the pilot light goes out, it cools and then the gas line automatically closes so that you don't get a constant stream of gas. When the sensor dies, the same thing happens -- no gas for the pilot.
Replace that sensor.
i would suggest a professional,,unless you are familiar with gas,,,pilot lights,,and thermolcouple's,,although you should be able to safetly observe if the pilot light is lit.
The pilot light lights? Then goe's back out? There is two stiff wires right in front of the flame. One of them is an ignightor, and the other one a thermocoupler. Or may just be one. That is the ignightor and thermocoupler. The thermocoupler is what detects that the pilot light lit. Its a saftey feature. It makes sure that there is fire before it turns on the main gas. So it wont blow up. It gets a film built up on it from the gas. Take some real fine sandpaper, or steel wool and clean it real good.
Then try again. It should work. If not then it needs to be replaced.
How old is your dryer? Only models from the 1980's and older have actual pilot flame lighters. If it's newer it will have either a spark igniter or an electric glow bar. If you have a large front access panel across the bottom, then you may have a pilot light. Remove the panel and look for the gas valve. (NOTE: Before lighting anything, make sure you do not smell gas. If you do, you'll need to air the room out before trying) There will be a burner coming out the back of the gas valve control and this control will have a red push button in the front or side of it to allow gas to the pilot only. Using a extended bbq type lighter, light the pilot at the pilot assembly and hold the button for about 60 seconds. The pilot assembly is connected to the gas valve control by a small diameter aluminum tubing with a copper thermocouple right next to it. Release and make sure the pilot stays lit. Before putting the access panel back on, turn on the dryer and watch for the burner to light. It should be a strong blue flame. Let us know if we can help you further. Not knowing why your pilot went out in the first place, there may be a unforeseen issue that may need attention. If you have a propane gas dryer and you ran out of gas, then it may take a while to get gas to the pilot, so be patient when trying to light it. Never hold the button down without the lighter lit at the pilot assembly, so there is not a build-up of gas. If you are not comfortable doing this, I recommend you call your gas co to light it for you, as many will do it for free! Good luck and be careful!
No pilot. Unplug the power to the unit and it cannot run/ignite. There is a shutoff on the valve behind the front panel if you want to turn off the gas supply without moving the dryer.
If you have a pilot light (small flame) you can try to re-light it by turning the knob on the gas valve to the pilot position and pushing the knob down while lighting the pilot, you may have to hold the knob down for up to 30 seconds before releasing it. The pilot should stay lit and then turn the knob to the on position. If the pilot will not stay lit or the main burner will not light it could be the gas valve or the temperature sensor.
