Question about Sony Handycam CCD-TRV318 Camcorder
How do you set the date & time
I cannot find the manual that came with the camera and I can't remember how to set the date & time
Somewhere there should be a menu button on the camera that will let you into a menu. if you find this, scrool through and there should be a date/time setting. Hope this Helps!
Posted on Feb 15, 2009
I have to set the date everytime I switch it on
On this camera you have a supplemental litte battery that is just beside the AA batteries. If you pull on the little tab that says CR 1220 you will find a battery that looks like a battery watch. Just replace it, go back into your date/time settings and you should be good to go! It worked for me!
Dec 20, 2011 | Canon PowerShot A400 Digital Camera
Every time I want to take a picture, I have to set the date or it goes back to 01-01-80. I replaced the (date) battery with CR1220 as instructed and put in the correct date. When I shut it off and turn...
Ah-h-h, January 1, 1980....I remember that day. Whoops, I started to slip away!. Try pressing menu/set twice after you set the date and see if it sticks around this time.
Feb 18, 2011 | Canon PowerShot A400 Digital Camera
Camera does not retain time & date when battery is removed.
HI there you camera internal CMOS battery is down need to replacement.
Jun 08, 2010 | Pentax Optio A30 Digital Camera
How to date change in camera for display see date
Switch on the cameraPress MENU at the back You will 2 icons. One for camera and other for tools. Select tools settings
Scroll down to Date & Time settings. Press Set/Function. Change the date and time as per our time zone. Press again Set/Function. For display of date Select camera icon and on the drop down menu select display. By pressing the function key select the date /date and time. Press Set. The camera is set. Whenever you view picture it will display the date and time
Apr 26, 2010 | Canon IXUS 80 IS Digital Camera
Date/time screen always shows up upon startup. Does not remember date/time entered.
Your camera needs a small CMOS battery replacement which saves date, time and maintains these settings even when your camera is off. Look on to the sides of the camera, there will be a small rubber flap which has this battery. You need to replace this small coin-like battery. This battery is not the same as you always use/charge. If you can't locate the small battery, you will find more information in the camera Manual in troubleshooting or camera diagram.
Jan 12, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
I received a canon powershot as a gift last year and am just now really starting to use it. The pictures seem fine, but the it seems like I am frequently requested to put in the date and time (i.e. about...
There is a button battery in your camera (CR1220) that remembers the date and other settings when you remove the main batteries. It probably needs to be replaced. It's in a slide-out holder next to the AA batteries (see page 184 in the manual).
You turn on the date stamp by using the photo size settings. Press the Function key and scroll down to the bottom item (usually L). Then scroll over to the Date Stamp icon (to the right of the L, M1, M2, M3, S options). Press the Function/Set key again.
Nov 15, 2009 | Canon PowerShot A590 IS Digital Camera
Need to reset time and date every time I turn on camera.
The backup battery needs to be replaced. This small button battery (CR1220) provides the power for your camera to 'remember' settings when you change or remove the AA batteries. Instructions for changing this battery are in the manual on page 191 (US version of manual).
You can view/download the manual here.
Sep 08, 2009 | Canon PowerShot SX100 IS Digital Camera
How to make date stamp option ON in Canon IXUS70 Model
Hi there, my name is Rob and I can help you.
To put the date stamp in a picture do this:
1) Make sure you have the correct date and time set in the camera. To do this:
Push the function/set button. Press the directional button down to select Date and Time.
Push the directional button to the right then down or up to set the date and time. Then press the function/set button to save it.
Then:
2) Push the selector button up to the camera icon, and press function/set. Scroll down to Date Stamp.
Scroll right to turn on the Date and Time Stamp, then up or down to until it says On.
Press function/set when your done.
That is your solution. Remember once the date/time stamp is embedded in a picture, you can't take it out.
Let me know if you have any further questions, and thanks for coming to FixYa. Please feel free to rate my solution a fixya.
Rob
Feb 19, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Adjust the date on the i70
Hey Mat,
You can find your product manual here:
http://www.samsungcamera.com/popup/download.asp?prol_uid=4148&prj_uid=733
You'll find once you download the manual's pdf, it'll be on page 20 of the pdf manual. The sample is below, but it's much clearer on the pdf manual. Best of Luck!
When Using the Camera for the First Time : Setting up the Date / Time and Language
When the camera is turned on for the first time, a menu will be displayed
in the LCD monitor to set date, time and language. This menu will not be
displayed again after setting up the date, time and language. Set up the
date, time and language before using this camera.
■ Setting up the language
1. Press the [Language] menu button.
2. Select a desired language by pressing the
vertical smart button.
■ Setting up the date, time and date type
1. Press the [Date & Time] menu button.
2. Select a desired date type by pressing the
3. To change the date, select the [2008/01/01]
menu and press the vertical smart button.
4. To select Year / Month / Day and Hour :
Minute, press the horizontal smart button.
To change the numbers, press the vertical
smart button.London
● You can select any one of 22 languages. These are listed below :
- English, Korean, French, German, Spanish, Italian, S.Chinese,
T.Chinese, Japanese, Russian, Portuguese, Dutch, Danish,
Swedish, Finnish, Thai, Bahasa (Malay / Indonesian), Arabic,
Polish, Hungarian, Czech and Turkish.
● Even if the camera is restarted, the language setting will be
maintained.
Jan 07, 2008 | Samsung i70 Digital Camera
Date time setting does not program
There is not an option to remember the date/time when you power off the camera. The camera should always remember the time. If it forgets the setting when you power it off then your backup battery has gone dead. Check your manual to see if it is something you can replace yourself. I am not familiar with this camera specifically but some cameras make the backup battery accessible and some require disassembly. David Millier Advance Camera Repair
Feb 22, 2007 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Sony Handycam CCD-TRV318 Camcorder Logo
205 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
