Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher
Problem for Fisher and Paykel 23 in. DD603H SS Free-standing...
Beeping and red light stating U3
By ashsanford on Feb 03, 2009
When I turn it on Normal cycle after about 1-2 minutes it will stop and turn red and start beeping. in the screen its says U3.
Same Problem
May 23, 2009
-   My upper drawer dishwasher will run for a few minutes and the start beeping and has a red light saying U3. What is wrong? -   cath1277
Feb 13, 2009
-   MY MODEL # IS DD602-SS-USA-V2 -   Guest
Best Solution
posted on Feb 04, 2009
Very Helpful)
RescueTech
Rank: Guru
Rating: 96%, 161 votes
Hi and welcome.
You posted your question in the DD/DS603 series section, but code U3 is usually seen on a DD/DS601 or DD602 series. When this code appears, most comon cause is that the machine is set in LP or LOW PRESSURE mode and needs to be set to HP or HIGH PRESSURE.
The fault is sensing water level too high in the drawer, which can also be caused by a blocked drain or inoperative pump. I can tell you exactly how to tell if the machine in in the wrong mode if you can tell us the correct model number. The machine's pump/drain system can easily be checked by putting the machine in diagnostic mode and running the drain pump.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Fisher and Paykel 23 in.
Questions and Unsolved Problems for Fisher and Paykel 23 in.
Do you recommend Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher?
Answer
Answer
My Fisher and Paykel dish drawer started making a screeching noise -- any idea what this might be?
Answer
Top drawer flashes F4 with a spanner symbol, how easy is the sensor to replace? Thanks
Answer
I have F&P freestanding dishwasher the top draw has started to leak. I have checked plastic... (More)
Answer
disable sabbath mode on a fisher paykel DD603 double dishwasher
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fisher and Paykel 23 in....:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
