Question about EliteGroup ECS P4M800-M Socket 478/P4M800/FSB800/A&V&L/M-ATX Motherboard (MOTEC18)
I believe I need to jump the computer because I got a used machine that is locked by a password. I do not have the original discs. The computer I have is a ECS running Windoes Professional, the motherboard is a ECS 761GX-M754 V:1.1
  • brad583 Feb 04, 2009
    Yes it is asking before windows loads,I have tryed taking the battery out with no luck
  • Peter Steiert
    Peter Steiert May 11, 2010
    Is it asking you for a password before Windows loads? If so a simple CMOS reset will do the trick.
    Sergeant:
  • 219 Answers
Check the motherboard's manuals to see if there is a jumper to reset the CMOS.
If not, unplug the power cord to your computer, open the side, pop out that same battery and keep it out for over 24 hours. After 24 hours (or more) have elapsed, plug the power cord back in to your computer's PSU. At this time we will not be inserting the battery. Start the computer and see if it still asks for that password.
If so, when does it ask for the password? Does it ask after the system POSTs and is about to boot from the Hard-Drive? If so there's a possibility the previous owner of the computer downloaded some form of application that activates when windows begins to load which asks for an authentication code, in this case the password. In such a case you will have to reformat the hard-drive and reinstall windows.
If not it's possible that the CMOS reset is not working (for some odd reason).
I hope you get this resolved, sad to buy something then not get to use it.
Posted on Feb 04, 2009
How to retrieve forgotton password.I have all original instal discs etc
The best way is to delete the password and set up a new one. To delete your password go to:
http://www.lazesoft.com/forgot-windows-admin-password-recovery-freeware.html and make the freeware CD on a friend's computer. Then boot your machine from this CD.
Aug 26, 2015 | ASUS A3Ac Notebook
Tip
How to Retrieve Forgotten Password to Access My Computer
Instructional steps
  1. Find a different computer that can connect to the internet and is capable of burning CDs.
  2. Choose a Windows password recovery tool. You will find several of them on the market. Some of the best ones are Ophcrack, Offline NT Password & Registry Editor, Cain & Abel and LCP. The last two are free and available for download.
  3. Download the password recovery tool on to the second computer.
  4. Burn the software on a blank disc using your CD-writing tool.
  5. Shut down the original locked computer. Insert the disc you created in Step 4. Now restart the locked computer.
  6. Press any key when you get the prompt "Press any key to boot from the CD." The Windows password recovery software should start running.
  7. Follow the prompts to retrieve the old Windows password. Use this password to log in to Windows as an administrator and access "My Computer." Note down the password in a safe place once you retrieve it for future use.
on Oct 09, 2010 | Computers & Internet
Tip
Reset your Apple's Original Admin Password.
Resetting the original administrator account password Follow these steps to reset a password when there is only one administrator account on the computer, or if the original administrator account needs a password reset. "Original" administrator account refers to the one that was created immediately after installing Mac OS X. If the original administrator password is known, that administrator account may be used to reset the passwords of other administrator accounts using the steps described above. These steps require an optical drive; if your Mac does not have an optical drive and you have a Mac OS X v10.6 Install disc, see below.
  1. Start up from a Mac OS X Install disc (one whose version is closest to the version of Mac OS X installed). Usually, you can start from the disc by putting it in your computer, restarting, and holding the C key. Or, put it in the computer and click the Install or Restore icon you see in the disc's main window (after which the computer will start from the disc without you needing to hold C). Or, you can use Startup Manager or the Startup Disk preference pane to select the Install disc.
    Choose a language, click the arrow button to continue,
  2. Mac OS X v10.6 or later: Choose Password Reset from the Utilities menu.
    Mac OS X v10.5 or v10.4: Choose Reset Password from the Utilities menu.
    Mac OS X v10.3: Choose Reset Password from the Installer menu.
    Tip: If you don't see this menu or menu choice, you're probably not started from the disc yet.
    Note: The default keyboard layout is U.S. English while started from the installation disc. If you use a keyboard layout other than U.S English, use the Input menu (the flag icon on the right side of the menu bar) to select the desired layout before typing a new password.
    Select your Mac OS X hard disk volume.
  3. Select the user name of your original administrator account.
    Important: Do not select "System Administrator (root)". This is actually the root user. You should not confuse it with a normal administrator account.
  4. Enter a new password.
  5. Click Save.
  6. Click the red button in the upper left corner to quit the application.
  7. Choose Quit Mac OS X Installer... from the Mac OS X Installer menu.
  8. Click Restart.
After following these steps, you'll want to also follow the steps in this article.
Mac OS X v10.6: Resetting the original administrator account password on a Mac that has no optical drive
These steps require a second computer that has an optical drive.
Note: If the second computer is a Mac, make sure Mac OS X v10.5.3 or later is installed. If the second computer is a PC, make sure the DVD or CD Sharing Update 1.0 for Windows is installed.
  1. Open "Remote Install Mac OS X" from the Utilities folder.
  2. Follow the onscreen instructions.
on Feb 10, 2010 | Computers & Internet
I forgot the administrator password, there is a malware protection software I believe. Is there any way to recover password?
You need to restart with original media disk and then you can choose reset password from the apple menu bar.
Mar 14, 2015 | Apple 24" iMac Desktop
Forgot user password
Hi I'm Peter , You can change your user password by going in with your administrator password. Here are a few helps https://iforgot.apple.com/password/verify/appleid and see
http://support.apple.com/kb/HT1274 and
and Kappys answer
https://discussions.apple.com/thread/4251616?start=0&tstart=0
In OS X Lion or later, you can reset your user password with your Apple ID.
In Mac OS X v10.6.8 or earlier, follow these steps to reset a password when there is only one administrator account on the computer, or if the original administrator account needs a password reset. "Original" administrator account refers to the one that was created immediately after installing Mac OS X. If the original administrator password is known, that administrator account may be used to reset the passwords of other administrator accounts using the steps described above. These steps require an optical drive; if your Mac does not have an optical drive and you have a Mac OS X v10.6 Install disc, see below.
  2. Choose a language, click the arrow button to continue,
  3. Mac OS X v10.6 or later: Choose Password Reset from the Utilities menu.
    Note
  4. Select your Mac OS X hard disk volume.
  5. Select the user name of your original administrator account.
    http://km.support.apple.com/library/APPLE/APPLECARE_ALLGEOS/HT1274/HT1274_Leopard.png
  6. Hope this helps.
Apr 20, 2014 | Apple eMac G4 Desktop
Kocaso nb726a
Resetting a password without an additional account Use these steps to reset a password when there is only one administrator account on the computer, or if the original administrator account needs a password reset.
  6. Enter a new password.
  7. Click Save.
  8. Click the red button in the upper left corner to quit the application.
  9. Choose Quit Mac OS X Installer... from the Mac OS X Installer menu.
  10. Click Restart.
After following these steps, you need to update your keychain so that it recognizes the new password.
If your computer doesn't have an optical drive, connect it to a computer that does using Target Disk Mode, or use the Remote Install Mac OS X utility to start up the computer remotely. Resetting a user's password in Mac OS X v10.5 or earlier If you are using an earlier version of OS X, select your version number below for password reset instructions. Avoid setting a blank password for a user account when using these steps. Mac OS X v10.3 through 10.5.8
  1. Log in with an administrator account. Tip: If you don't know the password of any administrator accounts, see "Resetting the original administrator account password" above.
  2. From the Apple menu choose System Preferences.
  3. From the View menu choose Accounts.
  4. Click the lock button if it appears locked; enter the administrator password.
  5. Select the name of the user whose password you want to change.
  6. Click the Reset Password button or the Change Password button.
  7. Enter a new password in both the New Password and Verify fields, and add a Password Hint if desired.
  8. Click the Reset Password button or the Change Password button.
  9. If a dialog box appears with the message "Your Keychain password will be changed to your new account password," click OK.
Mac OS X v10.2 through v10.2.8 Use Accounts preferences to reset an account password.
  4. Click the lock button if it appears locked.
  5. Select the username whose password you want to change.
  6. Click Edit User.
  7. Navigate to the New Password field.
  8. Enter a new password in both the Password and Verify fields.
  9. Click OK.
  10. If a dialog box appears with the message "Your Keychain password will be changed to your new account password," click OK.
Regardless of how many characters are actually in a Mac OS X v10.2 password, seven bullet characters (•••••••) will appear in the New Password and Verify fields the next time the password is edited. Mac OS X v10.1.5 or earlier Use the Users preference pane to reset a the password.
  3. From the View menu choose Users.
  5. Select the username whose password you wish to change.
  6. Click Edit User.
  7. Enter a new password in both the Password and Verify fields.
  8. Click Save.
Important: Passwords for administrator accounts should not be blank.
Regardless of how many characters are actually in the password, thirteen bullet characters (•••••••••••••) will appear in the Password and Verify fields the next time the password is edited.
Jan 01, 2014 | Computers & Internet
Apple G3 starting problem
    Note
Feb 13, 2010 | Apple MacBook Mac Notebook
How can I find the admin password on my mac. I had a new hard drive put in my pc. I want to change some of the admin settings but I need the password. How can I find it or change it without knowing the...
  5. Click Save.
  8. Click Restart.
  9. After following these steps, you'll want to also follow the steps in this article.
Feb 10, 2010 | Apple MacBook PC Notebook
I forget username and passowrd in my MAC OS X Version 10.4.11,please findout the solution to restore my username and password.....
Did you lost the administrator password? There is a way to reset it. You will need the install disk in the resetting process. Please make sure you follow the steps accordingly.
From Mac OS knowledgebase:
  2. Choose a language, click the arrow button to continue, then choose Reset Password from the Utilities menu (or from the Installer menu, if using Mac OS X 10.3.9 or earlier). Tip: If you don't see this menu or menu choice, you're probably not started from the CD yet.
    Note
  3. Select your Mac OS X hard disk volume.
  4. Select the user name of your original administrator account.
  5. Enter a new password.
  6. Click Save.
Sep 04, 2009 | Apple Mac OS X 10.4
Lost my admin user name and password
Reinstall windows, or what you can also use is windows password recovery. You can download and burn on disc from another computer and boot up locked computer with this disc. Another thing you can do is download a program called "windows recovery" and it will erase everything on the hard drive and you will be able to reinstall windows and have brand new computer.
Jun 17, 2009 | Fujitsu Siemens SCENIC P300 PC Desktop
EliteGroup ECS P4M800-M Socket 478/P4M800/FSB800/A&V&L/M-ATX Motherboard (MOTEC18) Logo
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
