Question about Acer Veriton 5600G PC Desktop
ACER Veriton 5600GT how to turn off USB power after shutdown
I have a USB powered hard drive plugged into one of the rear ports and it stays powered on even when system is shutdown. I cannot see any BIOS settings to manage USB power status. Are there any hardware jumpters on the motherboard which would change it so that the USB disk powers down when the system is shutdown.
  • fredmurk Feb 04, 2009
    Thanks for the suggestions but I have certain behaviors and a separation of data types in mind for the non-tech end user of this system. I will buy a cheap PCI USB card and use that - I expect (hope!) that its USB ports will power down when the PCI bus powers down. Cheers.
    Master:
  • 474 Answers
Not likely.
What you have is power over USB which is good because it allows the hard drive to get enough power to run without a seperate power cord. This is also usefull for IPODS and other media that Charge through a USB. It means you can turn your computer off and still charge something.
If its an external hard drive, its meant to be removed. You can right click and disconnect it from the bottom right and then remove it safely.
You may have a port that doesnt provide power when turned off, maybe a front USB port, you could plug it in there.
There most likely isnt a way to change any jumpers unless your system board instructions specify that you can and how to. Dont go tinkering around because if you put jumpers on the wrong spot, you can blow some of the small components on the board.
This would render the USB completely useless.
If you want a permanent extar HDD for back up, just get a new IDE for the internal, There cheep these days. you can get a 250 gig IDE for under $60.00
Posted on Feb 03, 2009
My acer veriton m464 goes to black screen with a flashingline in top left corner please help
This symptom usually means a hardware problem. Remove any and all external devices plugged into the various ports, like USB devices, etc. Remove all the removable plug in devices...like the hard drive, the DVD/CD drive, and PCMCIA cards. Remove the battery.
Plug in the AC, and then power up - do you see an error screen?
Aug 21, 2016 | Acer Computers & Internet
How do i set up a acer veriton l480g desktop computer
Pretty straight forward
- Video monitor plug goes in plug on back of PC that matches
- Sound system - plug green plug into matching green port on PC
- Power cord in matching port on back of PC
- Internet cable goes in port that looks like cable plug
- USB plugs go in matching ports on back of PB
- they can only be installed one way
- It doesn't matter which port they are plugged into
Sep 04, 2014 | Acer Veriton L480G-UD7600C - Core Duo...
Hi hope you are well, I have a Acer veriton 5600gt. I reformated the hard drive and loaded xp but its not locating the ethernet controller, mulimedia audio controller and the video controller. I...
Download your the require drivers Desktop "Acer veriton 5600GT" from Acer Support Site.
The full drivers download for your PC is in a compressed zip file, extract and run the setup file.
Hope it helps.
"Courtesy is free but it will carry you forward a long way in a lifetime!"
Nov 10, 2010 | Computers & Internet
Where are ram locations to install more ram?
I dont think there are more ports for Acer Veriton 5600GT PC Desktop
Oct 19, 2010 | Acer Veriton 5600GT PC Desktop
Possible to install a SATA hard drive?
Yes it's possible you can Install thing is in your desktop mother board has a extra port or you can use Extranal HDD with USB Prot
Apr 09, 2010 | Acer Veriton 3600G PC Desktop
Acer mainboard no f89m
ACER VERITON 5600GT
Download broadcomm network driver from here:
As to the video driver is it ATI, NVIDIA, INTEL or SIS?
Jun 23, 2009 | Acer Veriton 5600G PC Desktop
Changing Onboard Video
Hi Andrew, The manual for Acer Veriton 5600 series is available at the Product User/EndUser Website (Downloads) at http://csd.acer.com.tw. The filename of the manual is VT5600series_EN_0403.pdf Re add-on video card - select video card to be used in your CMOS/BIOS. Press "Del" during the bootup process. Alternately, you casn run the built-in diagnostic to diagnose any system changtes such as an add-on video card. Re onboard soundport - try either the front or the rear line/speaker out. Verify that the drivers are properly installed in your Device Manager. By default, when you have an external speaker, the internal auto cuts-off. Hope this be of some help/idea. Post back how things turned out or should you need further information. Good luck and kind regards.
Sep 27, 2007 | Acer Veriton 5600GT PC Desktop
Acer shut down
ok go to control panel, then power options and check that the option states that when you press the shutdown button, it powers down. You also may need to check inthe bios (F2 or Del on boot up) and go to standard cmos settings or the advanced cmos settings and see if ACPI is enabled, if not enable, then save settings and exit and a reboot will follow.
Apr 25, 2007 | Acer Veriton 5600GT PC Desktop
Acer Veriton 5600G PC Desktop Logo
460 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
