Question about InFocus LP 820 Multimedia Projector
Fan stopped on my infocus lp820
It sarts just fine then it shuts down after 30 seconds and says fan stopped . Infocus wants to charge $300 plus $30 to ship to them to replace the fan. From what I can tell all of them are working has anyone else had this problem and if so what do I need to do to fix it
5 Suggested Answers
Mark_Webber
  • 472 Answers
SOURCE: Infocus LP820 - Turns on for 30sec then shuts down
This could be one of two problems I have seen with another model Infocus projector (they are very good projectors though)
The first is the video input. Make sure it is attached correctly at both ends of the cable.
The second, remove the dust covers and blow them out. The problem can arrise if the temperature sensor detects the air inside the unit is getting too hot. If you can see the sensor when the dust covers are off (it will look like a little lump of goo on the end of a wire) then just give it a wipe as well. If dust settles on those it can cause incorrect temps to be reported.
Hope that solves your poblem =)
Posted on Apr 11, 2008
SOURCE: Connecting Dell laptop to Infocus LP820
The USB cable doesn't transmit Video. You need to plug in the VGA cable. The "DVI" port on the LP820 is not a a DVI but a M1 Digital port and won't work with DVI unless you get a converter.
Posted on Jan 08, 2009
SOURCE: lp820 infocus will not turn on
Some capasitors should be changed in the powersupply and several diodes too, may be. There are temperature mode in the power supply is very hard and those capasitors broke from that. Therefore running of projector is not stable. However if dont change capasitors at time then one diode may be broken and the projector will not start afterthat alwase.
Its not so big work for repaire.
I hope may english is understandable for you.
Best regards. Sergei82@gmail.com
Posted on Dec 13, 2009
projdoc
  • 2237 Answers
SOURCE: Infocus LP130, Bulb fires then goes out
there is a problem with the power to the front fan from the main board. there are 3 wires going to the fans: one power, one return, and one signal. if the main board reads no signal from the fan's speed, it'll shut down. check the power going to the fans and the signal. you may need to replace the main board.
Posted on Mar 09, 2010
LP820 projector powers up and all is well. After about 40 seconds to a minute it powers down. Control panel lights are on and LCD display says restarting. It comes back on for a couple of seconds and...
It could be are any of the led's blinking. ?
The other thing is to check the bulb is seated correctly in its connector.
Try removing bulb and reinserting.
Also clean the air filters at same time to make sure they are fine.
Please dont forget to vote if you liked my answer
thanks
Feb 10, 2011 | InFocus SP-LAMP-012 Projector Lamp for...
I have an infocus lp820 with what looks like an blue ghost omage in centre of screen,i suspect optical engine or lcd panels
This projector is one I've worked on many times and you are correct. The lcd panels are burnt probably due to a hard shutdown not allowing the fans to cool the inner components done repeatedly over several sessions.
Mar 22, 2010 | InFocus SP-LAMP-012 Projector Lamp for...
Have a infocus lp820 . There is a blue line on the
if it's a pixelated line, it's your lcd panel. if it's a blended, uneven line, it may the polarizer on the lcd panel. either way, you'll have to replace the whole optical engine.
Dec 07, 2009 | InFocus SP-LAMP-012 Projector Lamp for...
Projector turns on for about 30 seconds then shuts down. the fan kicks up high, and led light flashes yellow for about 4 min until the fan shuts off. does not feel hot so overheating does not seem to be...
if the lamp lights and then shuts down, replace the lamp. it's at the end of it's life. to rule out overheating, blow the projector out with canned air. dust retains the heat that the projector is trying to expell. also see if all of the fans are working. if you do get an image for a short time, try to get into the menu to reset the settings to factory default. lastly, if all else fails, you have a ballast issue. unfortunately, infocus no longer sells parts for this model.
Nov 28, 2009 | InFocus LP 630 Multimedia Projector
Infocus LP70 powers itself down after 30 seconds or so.
HI,,
ITS PROBLEM WITH URS PROJECTION CIRCUIT WHICH HAS BAD CAPACITORS..
JUST REPLACE THE CAPACITORS..
TNKS
RABBANEES
Nov 12, 2009 | InFocus LP 70 Multimedia Projector
Infocus lp820 i press power can not hear any fan moving lamp turn on with gray light after 10 sec lamp shut off and message says "fan stopped"
you need to replace the fans; they may have burned out. you could try to get one from an infocus service center or send it to them for repair, but know that this is an old machine and parts may not be available. you could try getting a used one on ebay that has a different problem and swap out the parts. if you do decide to send it in or find new parts, try av solutions in ny. they're really good. www.avsolutionsny.com
Nov 12, 2009 | InFocus LP 820 Multimedia Projector
LP120 : fan stopped error
you can purchase and replace the blower assembly- part # 505-1917-00. it's tricky, but you can do it. find an infocus authorized service center form their web site to buy it.
Jan 19, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Intermittent Power up / dn
HI-
The projector is overheating, try cleaning the filters for the fan.
Hope this helps
Oct 29, 2008 | InFocus LP 600 Multimedia Projector
Apr 11, 2008 | InFocus LP 820 Multimedia Projector
InFocus LP725 light goes out after 10 minutes
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
Feb 02, 2008 | InFocus LP725 and LP735 Replacement...
InFocus LP 820 Multimedia Projector Logo
196 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
