Question about Schwinn 430 Elliptical Trainer
Find repair service for schwinn treadmill
Console (screen) of treadmill is not working properly. I am lookiing for a local repair service. Zip is 95370
Jean Howard
  • jeanehoward Feb 04, 2009
    I ned to find a repair service, not be told the obvioius of what to do. I know the screen needs replacing. I need to find someone to do it.
    Jean Howard
  • ty1040 Mar 10, 2009
    Digital console for the Schwinn Elliptical trainner shows NO POWER, despite checks on batteries, power supply, etc.
    Believe the console may need replacement. Is there anybody in the Manhattan area who can repair this???
I have tradmill personal trainer 405 n needs belt 4 motor wear can i bay.
Posted on Dec 07, 2011
Short of changing batteries ,if you got them, theres nothing you could do other then replace it, If your speed rpms and distance doesnt read its the speed sensor
Posted on Feb 03, 2009
Schwinn 450 turns off after 5 seconds
The symptoms seem to be either stopping or displaying the "keep striding" message after 5 seconds, depending on the program/course in play. The most likely reason is the speed sensor is not working. A call to Schwinn support suggested opening the frame by pulling the crank to get to it. In my case, I found a simpler step to try first, and in my case it resolved the problem. Note: this may not be applicable to all models - I have a 450.
Remove the two screws holding the storage bin (at the base of the console mast) in place. See if the speed sensor is properly positioned. I found that it had become detached from the bracket and was just lying on the inside. I glued it back to the bracket (using a flexible adhesive good for plastic and other materials), and lo and behold, everything is working!
If this doesn't work, then your speed sensor is probably bad and it's on to the full and more lengthy repair. You will need to get a crank puller for a tapered crank from a bicycle shop to complete the job. Talk to Schwinn support; they were really good the two times I called.
Here are a couple of pictures showing the storage bin removed and the correct position of the speed sensor.
Mar 08, 2014 | Schwinn 450 Elliptical Trainer
I Need Console for 1988 Airdyne
The age of the machine is not as big of a replacement parts hinder as is Schwinn going through so many buy outs since 1988.
One of the best exercise repair parts on online is FitnessRepairParts.com. They have consoles which are similar to your generation of machine for 170.00 - 240.00
Otherwise schwinn was most recently owned by Nautilus/Bowflex/LAMAR fitness and they may be able to help through their website.
Sorry, I don't have a great source of imformation to help with. I repair Schwinn exercise and it has become very hard to find parts recently as the new generation of AEROdynes are very different. Although, up until maybe 1-2 years ago, nothing had changed for 30 years.
Alternatively, search craigslist and ebay. You may have to buy an entire unit to get the part you desire. Often they have a drive mechanism worn out which devalues them to the seller, but has minimal to do with your search.
Good Luck.
Jan 06, 2013 | Schwinn Airdyne Ad4 Upright Bike
Schwinn belt stopped
Dear Sir:
1) You must LUBE the Deck Belt, in according with the instruction manual. The deck maybe is worn.
2) See if the deck belt is in bad condition.
3) Test the drive belt if o.k
4) Test the main motor if running, if not the motor need attention and repair.
5)Test the input voltage for motor coming from the main motor BOARD.
see my personal TIPS for HELP.
sincerely. God bless you
Apr 23, 2012 | Schwinn 820 P Treadmill Silver Service...
Belt slipping on Schwinn Treadmill 5620P looking for local repair zip code 97405
http://www.youtube.com/watch?v=yX_0vRPdMfU&feature=related
See this video: and maybe you can do it.
after that you can continuing watching this other video.
http://www.youtube.com/watch?v=JC72OIKdluY&feature=related
if you insist to call some serviceman, contact:
www.unitedassemblers.com
you give your zip code and ready. sincerely.
E.CUADRA
MANAGUA, NICARAGUA C.A.
Nov 17, 2011 | Exercise & Fitness
Light switch turns on when cable plugged in; however, the treadmill is not starting. Please help. Nothing is coming on the console.
You need to be on the console for it to start. (I presume you are on it). Make sure the screen and console are properly connected.
if this is a new device, call the service technicians, they would know best. This device has a known problem with the console.
May 22, 2011 | Life Fitness F3 Folding Treadmill
I have a Schwinn 815 treadmill. Today, during the middle of a workout, it stopped dead. The console display has no lights on. The only light that is on is the power switch light. Other than that,...
it sounds like the problem could be the wire from the console down to the motor control board has come undone or partly undone. you need to take the console off and see if the wires are conected properly. if this isnt the problem then the console might have fried somehow, possible from the same reason, the wires came disconnected and shorted out on something.
Sep 05, 2010 | Sport & Outdoor - Others
Schwinn 820 treadmill quit working in the middle of walk shows L-5 on screen. what is problem?
Loss signal: 3 possible areas that can be causing the problem speed sensor , motor control Board ( MCB ) or the drive motor. Unplug unit remove motor shroud then plug in unit now on the MCB their should be L E D s lights should be on. One of the L E D s should speed on other P W M . Start your treadmill you see the PWM light flickering thus the upper console and cable connections are good now it will go back L S. Reset your treadmill then manually start pushing the running belt now the speed light should be flickering if it does then the peed sensor is good if not flickering then replace sensor. If we have a good speed sensor then I would check the Drive Motor this done unplugging the unit the disconnect the two leads coming from the motor to MCB then by using a fully charge 18v drill battery connecting the leads to the motor should move it at approx; 1 mph then Your MCB is defective and need to be replaced. if no belt movement you for the most part will have worn brushes or open windings in the motor , I would open the brush compartment and inspect the brushes if they are less than 3/8" in length replace them this should the motor issue. Good Luck
May 13, 2010 | Schwinn 820 P Treadmill Silver Service...
Error code L5 on schwinn 820p
Landice L9 tredmill, L5 display on screen,belt runs slow and nothing else works to the touch.
Schwinn 430 Elliptical Trainer Logo
1,353 people viewed this question
Top Schwinn Exercise & Fitness Experts
Steve
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
