Question about Apple Computers & Internet
Folder with blinking question mark in it after start-up
I just bought this off ebay it has no operating system, and the cd drive does'nt open so i use a paper clip to open it. I put windows xp in it to see if it would load up and it would'nt I ordered OS 10.2 Jaguar, just wanted to see if the folder was because there was no OS on it this is my first Mac ever.
  • 3 more comments
  • dhibiz Feb 04, 2009
    lliriks I just found out that I have no ram, so I'll get some and see if that will fix the problem.
    To make it clear I have a ibook 14", 800 mhz, 40 gb hard drive, 640 mb ram(found 0 ram).
  • dhibiz Feb 09, 2009
    My computer still does the same, and I just got in my 512 mb ram, software ibook restore 1-4, apple hardware test, 2-imovie disc 1 for Mac OS X and 1 for Mac OS 9.1, and a white disc that has a big blue X on it and has Mac OS X on it. Now here is my new problem I put the Mac OS X in it ran a second and gave me (Sorry a system error occurred "ASR" error type 41) and when I put the (Hardware test disc) in it said apple do'nt support this device - ibook restore disc tells me This configuration is not supported on this computer need help fast!!
  • dhibiz Feb 10, 2009
    So far no dice -- (When I try to boot the restore disc with Mac OS ver.
    9.1, 10.0.3 - I see this a big box and under Configuration it has ibook
    HD Disc 1.dmg the box next to it tells me about apple restore disc
    erasing the contents of my hard drive or partition - Under Destination
    disk it has a Macintosh HD and two buttons eject disc which will not
    work until i push the switch disk button - Under this I see This
    configuration is not supported on this computer - Next to this is two
    buttons Quit & Restore, Quit works and Restore never works). But I
    will keep trying also how can I format this hard drive if I can't get
    it to install software? I think I'll put a new hard drive in hopefully
    that works out.
    Yes these are original Apple software disc, but I found something on the web stating that this computer is compatible with (OS 9.2.2 Classic, 10.2 Jaguar, 10.3 Panther, 10.4 Tiger) and the one I got off ebay has 9.1, 10.0.3 on the Restore disc and the white disc with the big blue X on it (Mac OS X) says version 10.0.3. Could this software be my problem?
  • Illirik Smirnov May 11, 2010
    Can I get a little info? What is the model of laptop?
  • 38 Answers
Folder with a blinking question mark means a missing system folder, in other words there isn't an OS installed. To fix this you need to boot from the OS X installer CD. With the OS X installer CD in the drive, hold down the C key on your keyboard when you start your mac. This tells the mac to boot from the optical drive (i.e. CD drive) and load the OS X installer. From there just follow the onscreen instructions to install OS X.
Also, you should be aware that the ibook is not compatible with Windows XP. Only the newer “intel macs” of the past few years are compatible with XP. Your mac predates Apple's transition to intel processors and Windows XP compatibility on the mac platform by a few years. This is why your Windows XP CD didn't load on it. The ibook is Mac OS X only.
It only runs on Mac OS X however it is compatible with newer versions of the OS. 10.2 jaguar is kind of old and a little buggy. You may want to consider installing 10.4 Tiger for improved stability and performance. Avoid the newest version (10.5 Leopard) as it is geared towards newer and faster machines.
Hope this helps. Enjoy your mac
Posted on Feb 09, 2009
  • 1 more comment
  • thomtime
    thomtime Feb 10, 2009
    Error type 41 applies to computers that are running OS 9 and earlier and basically means something has gone seriously wrong with the OS and it cannot boot. There are methods to recover from this but frankly they are far too complex for a mac novice and given that this is new to you and OS 9 is obsolete I'm going to recommend you format the drive and install OS X. Here's how.
    Boot from the OS 9 CD using the methods I described for OS X (Start machine holding down C key) After a while, the machine will load the entire OS 9 from CD and present you with the mac desktop (circa 1990s). In the top right corner will be an icon that looks like a CD with the caption Mac OS 9. This is the installer CD. Double click this to open a window that contains the installer and additional folders. Double click the Utilities folder. In there is a program called Drive Setup. Double click this to start the program. When the program launches you will see a list of drives and a button at the bottom right that says Initialize. Choose your start up drive (typically named Macintosh HD) and click Intiialize. This will open another window where you format the drive. Choose 1 partition as a partition scheme and set the type to Mac OS Extended in the drop down menus. Click OK. When it is finished quit the program. Shutdown the machine by going to the Special Menu at the top of the screen and choosing shutdown. Your computer is now ready to install OS X
    Boot the machine from the OS X installer CD by again holding down the C key on startup, and as I said before follow the onscreen instructions. Thankfully OS X is a little more straight forward to install and you shouldn't have any problems. Good luck
  • thomtime
    Just to clairfy, do you have a retail installer disc for OS X or OS 9?You can verify it is retail if it does not name a specific type of computer on the disc label.  The errors you are having with the restore discs could be one of two things.
    1. They are not the original CDs that came with the computer.
    2. The installed OS is of a different version than the restore CDs
    In either case only a retail installer disc can be used to boot your machine. Make sure you have one and try to boot from it (holding down the C key with the CD in the drive) if you do.
  • thomtime
    Yes it could be the problem. These may not be the original discs that came with your machine and may predate the release of your ibook. In this case they can't boot the machine because the disc don't contain drivers for your newer machine. Defiantly try to get your hands on a newer version of OS X. As you discovered your machine is compatible with 10.2 - 10.4 so try to find an installer disc in that range on ebay (or borrow one from a friend). Remember you will need a retail version of OS X not a computer specific installer. Hope this helps.
Can't play files copied to DVDisc, does'nt recognize as there, why?
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Mar 27, 2012 | Gateway Computers & Internet
I bought this macbook pro 13 on ebay and it will not open the interface ...I only see a question mark blinking constantly. what do I need to do to rectify the situation?
You need a system dvd or cd
the blinking ? is the mac telling you it can not find an OS on the drive.
Hope this helps,thanks for using FixYa
Vote for this if you like it.
Sep 15, 2011 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Hi sir can help me for product key of windows xp pro sp3.tnx
HI,
You can find the product key. just follow these steps. Insert Windows XP cd into a working computer. Exit the Auto-run introduction.Open "My Computer" Right Click on the Windows XP cd-rom drive and select explore.Open the USWXP32P_ZX folder. (It may be as a hidden folder. If you cannotlocate the folder, you may also search forunattend.txtand mark "Search Hidden Files".)Open the sysprep folder. Open unattend.txt Your CD's product key is containedwithin the unattend.txt file.
Jun 06, 2011 | Microsoft Windows XP Professional
Grey screen with a blinking folder and question mark
Ok get ready for this, you have a PRAM battery on the motherboard, since your system is old the battery is dead. It is the same as a CMOS battery for a PC. It hold crucial startup info. Open the case replace the battery (can be bought at any radio shack) Press the reset on the mob and start from cd and set date and time then restart.
May 14, 2010 | Apple Power Mac G5 Desktop
My cd reader in my hp pavilion dv6000 is not reading properly. when i put in a cd i see the little green light blinking and i hear the cd spinning but thats all it does.
sorry to tell you but your Cd drive is bad it is fairly cheap and easy to install usually two screws and give the drive a little yank and it should pop out you can purchase the CD drive online try ebay good luck but make sure first im not sure if maybe you think that something is supposed to happen every time you insert a cd it does not insert your CD go to my computer and try to access the drive if you can browse the files then your drive is ok sounds like you need to enable Autoplay a feture that enables something to happen when you insert your cd but you probaly know all that ...
Nov 03, 2009 | HP Pavilion dv6000z Notebook
I have just intalled anti virus and it has messed with my windows activation code so now it dont work and can not find the code
Find Windows XP Product Key from the Windows XP CD: 1) Insert Windows XP cd into a working computer.
2) Exit the Autorun introduction.
3) Open "My Computer"
4) Right Click on the Windows XP cd-rom drive and select explore.
5) Open the USWXP32P_ZX folder.
6) Open the sysprep folder.
7) Open unattend.txt
Your CD's product key is contained within the unattend.txt file.
Note: On some system disks, USWXP32P_ZX is a hidden folder. If you cannot locate the folder, you may also search for unattend.txt and mark "Search Hidden Files".
Oct 26, 2009 | Microsoft Windows XP Professional
How to find windows xp product key on windows xp cd
Aug 10, 2009 | Microsoft Windows XP Professional SP2 Full...
Blank screen with blinking folder
This is a sign that the startup disk can't be found.
When you power on the computer, try holding down the "alt" key or "option" key on your keyboard.
Then after a while, it should ask you to select the location of the operating system. Select your macintosh HD. Everything should load as normal.
If this doesn't work, insert the install cd's and hold down "c" instead. This will load the cd with mac os x on it. You can then install the operating system. Please make sure you have backups. Unless the option to simply upgrade or repair your mac pops up, you will loose your files following this method.
Nathan.
Apr 13, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Lode needed dlls for kernel
Use the ERD disk and repair the installation. Choose to replace all files, and then replace only the Hal.dll and Ntoskrnl.exe files.
If you can start another installation of Windows NT on the same computer, you can expand the correct Hal.dll and Ntoskrnl.exe files from the Windows NT CD-ROM. To do so, follow these steps:
  1. Boot to the working version of Windows NT.
  2. Start a command prompt.
  3. Change to the CD-ROM drive.
  4. Change to the appropriate folder on the CD-ROM (for example, I386 for Intel-based computers).
  5. Type expand hal.dl_ <systemroot>\system32 where <systemroot> is the path of the non-functioning Windows NT folder.
  6. Type expand ntoskrnl.ex_ <systemroot>\system32.
  7. Restart the computer into the other Windows NT installation.
Mar 27, 2009 | Microsoft Windows XP Professional
My Mac wont work. blinking Folder with "?"
When the "?" mark comes up, it means it's looking for the operating system to boot to. It can be fixed by opening system preferences and in the startup settings, select your operating system as the tarted startup. It should speed up boot up time.
Apr 06, 2008 | Apple Power Mac G5 Desktop
Computers & Internet Logo
2,021 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
