Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Need to open washer to fix it. its a lsb6300
Would like some to tell me how to open up the machine so I can replace the gasjet between the pump and the motor.
  • 135 Answers
Remove the 2 screws at the bottom front of the control panel. Flip it up and back. Unplug the lid switch connector, and pry out the 2 brass clips. Now the cabinet hinges out and off. There is no such gasket, by the way. Hope this helps!
Posted on Feb 03, 2009
Water leaking inside from Maytag Combo washer/dryer
First to find the leak , most likely a rubber hose or water pump.
Dec 03, 2017 | Washing Machines
Problem with LG WM1814CW Front Load Washer. It has stopped with water inside and it says OE. I have checked the back pipe, but with water inside, can i open filter
The OE error is telling you the water hasn't drained out in ten minutes. To fix I would first start with cleaning the filter on the pump. If that doesn't fix i would recommend replacing the pump. I would also have towels and a mop in hand because when you unscrew the filter top the water that is inside the tub will come out. You should try leaning washer back before removing filter to prevent the mess.If you have to replace the pump they run about 50 or 60 bucks. I hope this helps.
Oct 27, 2012 | LG WM1814CW Front Load Washer
Leaking water when washer begins to load water.
Fist place to check is the outlet hose at the back of the machine it will leak as soon as water enters the tub, see if is leaking there, if it is you just have to tighten the clamp . if not there are a few hoses inside of the machine that may need clamps tightend also. The motor is seperated from the water so that wont be leaking. It could also be the electric water inlet valve that is leaking. let me know what you find out !
Oct 29, 2009 | Whirlpool LSB6000PQ Top Load Washer
Kenmore Series 80 washer doesn't always spin, only 1/3 of time.
First of all check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely,if it's frozen or stiff,replace it. If the pump belt is broken or looks quite worn, replace it but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Sep 05, 2009 | Kenmore 24902 Top Load Washer
I Have a frigidair washer and after the wash cycle it does not empty the water, you do not even hear the pump running. can someone tell me what the problem could be.
I fixed the problem, It was the lid safety switch.I bipassed it for now but i intend to replace it soon..another way you can also tell is if when you open or close the washer lid you do not hear the switch click.. Tom..
Jul 17, 2009 | Frigidaire Washing Machines
Washer won't spin
you could have something stuck in the pump which means tilting the machine to get to the pump to see..more likely its a sock or something small like that thats wedged in there
Jan 12, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool LSB6300 died mid-cycle now only clicks
HOPE THIS WORK, DON'T FORGET TO RATE ME
  • Timer is fried.
  • Washer went off-balance and tripped the off-balance switch.
  • Dec 28, 2008 | Whirlpool LSB6300PW Top Load Washer
    Sears 110.23812100 washer leaks when spinning
    There is a pause after the pump out that shift the tranmission into spin also if you open the lid the unit will go into spin before it pumps out completely . They have since fixed this issue...The newer models work offf the pressure switch to tell the unit when to go into spin only after the water level switch is open telling the machine there is no water left in the unit
    May 28, 2008 | Washing Machines
    My washer is leaking...
    Open the rear panel on the washer. Check the 3 rubber hoses connected to the pump. Make sure there are no splits, or a **** in any of them. Also look at the pump and make sure the casing is not cracked and dripping (if coins enter the pump they can crack the casing, causing a leak). If there is a leak in a hose, replace that particular hose. If the pump casing is cracked, replace the pump.
    Apr 11, 2008 | GE Spacemaker WSLP1100D Top Load Washer
    Washer will not run pump
    Check your lid switch. This is a tell tale symptom of a lid switch gone bad. The washer fills, agitates, but will not spin or drain. The lid switch is located along the right hand side of the lid opening on most models, but some newer models have a switch in the left rear of the lid. Simply open and shut the lid several times and listen for a distinctive "click" of the lid switch as you open and close the lid. A lid switch usually runs about $35 to replace. If you provide me with your washer model number (usually located under the lid somewhere) I can give you the part number you need. That is...if the lid switch is the problem. The only other problem that I have encountered that caused the same symptoms, was a bad timer. Timer vs Lid Switch: Lid switch is a cheaper fix. I would try this option first. Let me know if this helps and/or if you need more guidance.
    Sep 21, 2007 | Whirlpool LSR6232J Top Load Washer
    Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
    Dan Webster
    Dan Webster
    Sal De
