Question about Nintendo Wii Console
Wii Fit Hula Hoop does not register on rotating to the right
Whenever I try to hula hoop rotating to the right, the board does not register my movements and the hoop falls to the ground. No problem rotating to the left, only the right. I did not have the problem initially, but now it happens all the time.
You rotate left your hula hoop same your body and you move the hula hoop with your body
Posted on Feb 04, 2009
How do you get the weight balanced in a hula hoop?
A hula hoop is not designed to be repaired or serviced. If it has failed you need to dispose of it and purchase a new one.
Apr 17, 2012 | Sewing Machines
New crown compatible wii fitness board will not sync with wii console. board only blinks a few times then switches off
Have new crown compatible fitness board, new batteries inserted, inserted Wii fitness disc, choose training, then trial, choose hula hoop game, used remote press A to start.
Screen says place me on a flat floor and press POWER button before stepping onto me
Followed the instructions power button flashes blue, as do the four corners then the lights go out - then nothing happening, still have the same message place flat on floor etc....
Have also tried the Wii Balance Board Check - followed all instructions last one says please turn on power. Pressed button flashes blue as do four corners then they go out
Am I doing something wrong or Is this a faulty board ?
Thanks
Sep 27, 2010 | Video Game Consoles & Games
I just bought a flight commander watch by chase durer and its doing a hula hoop around my wrist, how do i make it tight?
This link shows how to shorten several link band styles. Find the one that matches yours.
http://www.webwatches.co.uk/how_to.htm
Best regards.
Aug 23, 2010 | Watches
USING THE HULA HOOP
The trick to hula-hooping is timing. If you get the hoop moving fast on its initial turn around your midriff you have a better chance of getting the timing- I like to use my legs to get the hula just right... And remember- the slower the body moves on the timing, the faster the hoop hulas.
Oct 07, 2009 | Balance Health & Beauty
Wii Fit - Hoola Hoop
If you're not shifting enough weight to one side, you can't catch a hoop. I have found that lifting the opposite foot off the board as soon as the toss is thrown helps quite a bit.
If you're still having trouble, evaluate how the board works with other activities on WiiFit. If you notice problems in other areas, you may have a defective unit. There is a calibration feature on the program, and if that doesn't work, try opening up a trouble ticket on www.nintendo.com.
Feb 04, 2009 | Nintendo Wii Fit for Wii
Wii Fit instructions for movements are all in reverse
No it is not how Wii Fit is supposed to be. First, let me suggest that you ensure that the power button on the Wii Fit Balance Board is facing AWAY from the TV set. This may seem silly, but it's the most common error. As for the Hula Hoop game, make sure that your weight is all on the side of the Wii Fit Balance Board in the direction that you need to lean to catch the hoop.
There have been instances of the sensors in the Wii Fit Balance Board going out. If you have tried the above steps and you are still getting errors, please go to www.nintendo.com, register your product, and open a problem ticket with them.
Jan 28, 2009 | Nintendo Video Game Consoles & Games
Wii Fit Hula Hoop Game
try standing as far back as u can, then jump and then do twenty jumping jacks.
Nov 24, 2008 | Nintendo Wii Console
Tye Dye Picture Always!
Is this an Analog TV with a picture tube? If so, it sounds like the screen is magnetized. Have you had any magnets (including speakers) near the screen?
Inside all analog TVs is what is called a degaussing coil. When you turn on the TV for the first time (cold), the degaussing coil is energized for a couple seconds to demagnetize the screen and then it goes off.
You can purchase an external degaussing coil and demagnetize the screen youself. A degaussing coil looks like a small hula-hoop about 6-8 inches in diameter with a AC line cord attached. I've even made these coils out of long lengths of enameled wire, electrical tape and a line cord.
Once itas plugged into the wall outlet, you hold it close to the screen (1/2' away) with the hoop facing the screen and move the hoop in a circular pattern, covering all areas of the screen and slowly move the hoop away from the screen while still moving in a circular patten until your about 2-3 feet from the screen.
If you did it right, the color splotches will be gone.
Let me know if I can be of further assistance to you or help you to locate one of these coils.
It's possible that the coil in your set is bad.
Good Luck!
- Jim
Feb 07, 2008 | Samsung DynaFlat TX-P2764 27" TV
Screen has green and reddish spots in two upper corners
It sounds like the screen has become magnetized by the magnets in the speakers.
Inside all analog TVs is a device called a degaussing coil. When you turn on the TV for the first time (cold), the degaussing coil is energized for a couple seconds to demagnetize the screen and then it goes off.
It's possible that the coil in your set is bad. The coil is energized for a few seconds when you turn on your TV and then it shuts off a few seconds later. You can try turning on the set for around 30 seconds, and then turn it off. Wait about 10 minutes and turn on the set again. Doing this several times may let the sets internal coil (if its working) to demagnetize the screen. If not, you'll need to use a degaussing coil.
Let me know if I can be of further assistance to you.
Good Luck!
Oct 22, 2007 | Sanyo HT32744 32" TV
Nintendo Wii Console Logo
99 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
