Question about GE GDS20KCS
Clicking sound have a GE frige model# GDS20KCSABS any one familiar with this problem? some time it goes away for hours then comes back on..like chinese torture...is this coverd by warranty made in 2006...Tony
    Problem Solver:
  • 11 Answers
NO IT IT IS NOT COVERED .MOST WARRITY ARE 1 YEAR ELTICAL .. 5 YEAR SEALED SYSTEM DOES IT STILL WORK . THE CLICKING NOISE SOUNDS LIKE COMP. RELAY AND/OR RELAY ON MOTHER BAORD IN BACK
Posted on Feb 04, 2009
  • 306 Answers
More then likely not your warranty is maybe only one year on parts and 5 years on compressor. You could try but technicality the PTC is bad.
The clicking sound is a relay called PTC relay. You need to replace it. First be sure to unplug frig. Remove the cardboard cover that covers most backs of the frig units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
My GSS20IE side by side is not cooling the refrigerator side. The freezer seems to be fine. I unplugged the frige and can hear the compressor click off. When I plug it back in the compressor clicks on but...
Condenser fan near the compressor- Check to see if your have voltage at the fan. If you do the fan need replacing. There should be voltage any time the compressor is running.
Jul 22, 2011 | GE GSS20IEP Side by Side Refrigerator
Why do i keep getting a puddle of water in the bottom of my frige? The water must be coming from the top because each day, there is water on top of the food containers all the way down to the bottom.
Sounds like you have a defrost drain issue. Often times these get clogged, and the back flow water drips into the fridge, usually the culprit on a GE is a clogged drain diverter, located on the outside back of the unit. Remove the tube by bending and pulling away from the diverter while holding the diverter firmly in place. Then turn the diverter one quater turn clockwise and it should pull down and away from the appliance. Clean this diverter out thoroughly, as it is likely full of gunk. However, on some older model GE top mounts, ive seen the drain pan underneath the evaporator coil inside the freezer with a small rust hole, and the water drips through this hole instead of the intended drain hole, the water then misses the tubing, and drips into the fridge. this drain pan will then have to be replaced.
Dec 10, 2010 | GE Refrigerators
My GE profile gas range keeps clicking all the time, this happens right after we have cleaned the gas range. And usually it goes away after a few hours. But this time around it refuses to go and it is very...
You are getting water into the range when cleaning causing the igniter switch to short out. The reason why it goes away after a few hours is because the water finally dries up. When cleaning the range refrain from using so much water. You will need to leave the range unplugged until the water dries up again.
Sep 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a model ARB2257CSR Amana frige (freezer on bottom) and the freezer is not working I think. there is a sound that comes on and off like the motor maybe is trying to come on... the sound comes from...
Sounds like the overload/relay is going out . If the noise is a " click " , replace the o/relay after checking the 3 terminals on compressor for continuity and each terminal to ground ( copper tubing ) .
Jul 15, 2009 | Amana ARB2257CSR Bottom Freezer...
Clicking sound - not cooling
The problem is most likely the condenser fan motor at the back-side/bottom/right of the unit. If this fan is not turning, unplug the connector to this fan (inside the protective cover on the wires near the fan)... if the clicking stops, then this fan needs to be replaced.
What is happening is that this fan has failed but continues to draw a heavy load from the circuit board... It draws enough power from the circuit board to drop the voltage on the circuit board to 5-6 volts and the relays on the board open up and disconnect the power to the fan. The the voltage jumps back up to 12-13 volts and the relays turn back on causing the voltage to drop again and the relays to open.... ON....OFF...ON...OFF..... thus the clicking!
The exact part number for this fan may vary depending on the model and serial number of your unit... My model is GBS22K-BRBBB and the fan part is WR84X10055 and should cost $60-$70 though I have seen it being sold for as much as$130.
Mar 12, 2009 | GE GBS22KBS Bottom Freezer Refrigerator
GE GSS22sgrf ss - Side-by-side refrigerator
I need to make sure that your refrigerator model and make numbers are listed correctly. Im having trouble with the information listed above your comments. I have GE data base and want you to look at the hyper link listed below.  and let me know if this or I can help lead you in the correct direction, Thanks, Sea Breeze
http://www.appliance-parts-warehouse.com/general-electric-parts/General-Electric-Refrigerator-Parts-Page-6901.cfm
Oct 25, 2007 | GE GSS22JFMWW Side by Side Refrigerator
Frige not cooling and click noise.
Sounds like a relay is chattering on the board. First thing would be to change that circuit board, it controls pretty much the whole unit. Make SURE the clicking is coming from the board and NOT the compressor though! See item 801 below http://www.partselect.com/Schematics/GE/00118404i08.gif
Feb 05, 2007 | GE GSH25JSRSS Stainless Steel Side by Side...
The water and ice dispenser is not working, the light goes on and off to normal and dim. There is a low tone bonging sound.
Start with the easy stuff. Is there water at the refer? Remove the line from the back and check for water flow. If equipped, is the filter plugged (water flows without filter in sort of thing)? Is there debris in the line to the refer blocking the valve? Does the water valve solenoid "click" and flow water if you remove the internal water line that goes to the frige interior? Is the water line frozen in the door (turn off frige for a day and check water flow).
Sep 27, 2006 | GE GSH25JSRSS Stainless Steel Side by Side...
GE GDS20KCS Logo
124 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
