Question about Dell E171FPb 17" TFT LCD Flat Panel Monitor
Fixed lock and unlock sign,then dell ajustments for screen-can't
This comes and goes. I can't remove it.Dell E171FPb is the heading on the screen adjustments.
  • 1 more comment
  • ckgan_2 Mar 07, 2009
    a padlock with lock and unlock sign flashing at the centre of the monitor
  • Anonymous Mar 21, 2009
    same
  • Anonymous Mar 24, 2009
    flashing lock and unlock sign in the center of the screen is in the way
    Sergeant:
    Champion:
  • 373 Answers
Call dell
Posted on Feb 04, 2009
Why won't my Dell E171FPb monitor work? When I turn my computer on the monitor flashes the first screen, the "DV051...Bios Revision A01" screen, then goes black. I'm using a Dell Dimension E310 that's...
Check the power supply DC filter caps, burnt parts, cold solder joints, etc.
If you are going to DIY repair, please read below and look at my album of failed Dell monitors to get some ideas.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 25, 2010 | Dell E171FPb 17" TFT LCD Flat Panel...
The screen goes black how can I fix this
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Dell monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Replacement board: http://www.lcdrepair.us/e171fpb-power.html
http://www.lcdrepair.us/e171fpb-inverter.html
May 12, 2010 | Dell E171FPb 17" Flat Panel LCD Monitor
My dell e171fpb monitor lost its clarity. now all it shows are verticle and horizontal lines in different colors. Can it be fixed for less than a new lcd?
A new lcd will cost you about 100 bucks. You can go cheaper by replacing the monitor. Many pc outlets sell grade a lcd monitors for about 80 bucks.
Nov 05, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
Padlock appears on screen
The padlock is an indication that the On Screen Display is locked. You can also lock or unlock the OSD by pushing the Menu button for over 15 seconds.
http://support.dell.com/support/edocs/monitors/e171fp/en/controls.htm
Sep 30, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
White horizontal lines on entire screen
I’ve never seen this kind of video output caused by a bad video cable or bad FL inverter board. laptop was fixed after I replaced the LCD screen.
Apr 03, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
POWERSAVE
I have A "Dell" E152FPc, and I have found an open transistor (Q201) on the Power Supply Board. My monitor comes on nice and bright for approximately 2 seconds, then goes dark; the power LED is steady. The voltage to the PWM IC is waky.
Before you try any hardware troubleshooting go to your control panel and turn off any power management options.
May 26, 2008 | Dell E171FPb 17" TFT LCD Flat Panel...
Dell e171fpb lcd monitor
The driver tabs between the LCD panel and it's controller board have failed.
These are very fragile and not repairable for anything in the cost effective range.
Best option is to either find a new panel to replace it, or get a new monitor.
Sep 10, 2007 | Dell E171FPb 17" TFT LCD Flat Panel...
Dell E171FPb monitor turns on, but that's it
Hi Letneper,
Hope this will give you hints. Some monitors have standby mode or screen saver feature and or self test feature when not connected to video input of your PC or CPU. Except this problem did not occur at first use. You can turn this off like other monitors manually at OSD (on-screen display) settings if available. No more no less if it works fine with PC or CPU on then there's nothing to worry.
Best regards,
Rosener Guyano
Sep 04, 2007 | Dell E171FPb 17" Flat Panel LCD Monitor
Hold the menu button until the padlock unlocks, it takes anywhere from 30 seconds or even a minute or so
Mar 12, 2007 | Dell E171FPb 17" Flat Panel LCD Monitor
Dell E171FPb 17" TFT LCD Flat Panel Monitor Logo
340 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
