Question about Sharp EL-531VB Calculator
I HAVE AN EL-531WH.HOW DO I CALCULATE FRACTIONS WITH IT?
3 2/5 X 1/2
  • Sharp Master
  • 8,068 Answers
If you want to enter improper fractions you use the key [a b/c]
3 [ab/c] 2 [ab/c]5 [x] 1/2 [=] (no need to use the [2ndF] [d/c] to enter 1/2.
Hope it helps.
Posted on Sep 20, 2009
How do you use the calculator to solve aRITHMETIC AND GEOMETRIC SERIES
http://www.ticalc.org/pub/83plus/basic/math/series/ Check out the first file on the page, it should be a program to do it
May 17, 2011 | Texas Instruments TI-83 Plus Calculator
Hoe do I calculate the IRR (internal rate of return) on sharp EL531WH
Can anyone provide the steps for calculating IRR on the Sharp EL-531WH?
Mar 30, 2011 | Sharp EL-531VB Calculator
How to calculate logarithms using SHARP EL-531WH
you can press the "log" button or the "ln" for logarithmic calculations. the difference is just that "ln" calculates log on base "e".
Feb 18, 2011 | Sharp EL-531VB Calculator
How do I remove the FIX from my sharp el-531wh
1. Press the 2nd function
2. Press Alpha(which is the same as M-CLR)
3. Press 1 to reset the calculator
Nov 01, 2010 | Sharp EL-531VB Calculator
I want Sharp Calculator manual .Model no is EL -531WH
Get it from the manufacturer's web site at
http://www.sharpusa.com/~/media/CF70E34972714230ABB931048EF5CB44.ashx?cal_man_EL531_509.pdf
Jul 28, 2010 | Sharp EL-531VB Calculator
How do i display exponents besides 2, or 3 on the sharp EL-531WH?
EL-531W SHARP:
If you want to find 5 to the power of 6 (5^6)
you hit the 5 button, then the button that says yx ( the x is in the exponent spot) then the 6 so it will looks like this 5^6 then press enter to get the answer...hope that helps!
Jul 04, 2009 | Sharp EL-531VB Calculator
How to solve quadratic equation in SHARP EL-531WH
This calculator does not have a program to which you give the equation, and which returns the solutions. Sorry. You have to use the formulas you learned.
Let the equation be ax^2 +bx+c=0
You compute the discriminant Call it disc.
disc= (b^2-4*a*c)
1. If discriminant is larger than zero you have two solutions. Let us call them x1 and x2.
Then x1=(-b+square root of disc)/(2*a)
and x2= (-b-square root of disc)/(2*a)
2. If disc=0 , square root of disc =0 and x1=x2=-b/(2*a)
3. If disc is negative, there are no real solutions.
To find the solutions you replace a, b, and c by their numerical values, to calculate disc, its square root, and calculate X1 and X2.
Hope it helps.
May 05, 2009 | Sharp EL-531VB Calculator
I want to calculate permutation and combination.
Use the sequence [2ndF][nPr] for permutations and [2ndF][nCr] for combinations.
Exemples: 10(nPr)3 is entered as 10[2ndF][nPr]3 [=] gives 720
5(nCr)2 is entered as 5 [2ndF][nCr] 2 [=] gives 10
Hope it helps.
Apr 09, 2009 | Sharp EL-531VB Calculator
Fractions
I checked the manual for the EL-501W calculator and I found out that it does not do fraction calculations. However yours may be able to. Look for a key labeled [a b/c] and a [2ndF] key [d/c].
If you have them then you can calculate with fractions.
The way to use the [a b/c] key is as follows
15 [a b/c] 7 [a b/c] 19 [a b/c] should allow you to enter 15 and 7/19.
A mixed fraction can be converted into an improper fraction by pressing [2ndF][d/c]
Jan 08, 2009 | Sharp EL-501WBBL Calculator
User's manual Sharp EL-531WH
You can download the manual from the link below: http://esupport.sharp.at/html/om/index.php?StartRec=50&ListLimit=10&Lang=%&TemplateLang=en&ProdLine=30&SortOrder=DESC&OrderBy=Title&SearchString=
Aug 10, 2007 | Sharp EL-531VB Calculator
Sharp EL-531VB Calculator Logo
260 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
