Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
there is a motor inside the timer that turns the knob. the problem must be the replacement timer. was it a brand new timer from maytag or a 2nd hand? also double check your timer is connected correctly.
i do believe the part number for your washer model number is 22003371and when searching the part number 2605660 none of my 4 parts lookup websites can not find that part number but yet all of them tell it the timer part number for model# MAV6200AWW is part #22003371
Set the timer to any off position. Unplug the unit for 10 minutes. Plug it back in and try that. The worst thing you can do to a Maytag washer is advance the timer yourself...hope this helps.
this is a good one! dependable care unit made in my home town.
http://www.servicematters.com/maytag_library/docs/16010373%20(16001145).pdf
insert flat blade under center plastic clip in the center if timer knob , you will find a little clip and sping here , then remove two 5/16 screws , then remove two phillips screws on control panel , you should see 4 ,2 on each side remove the inside 2 then tilt panel forward unplug timer. so easy
