Question about Toshiba 46HM95 46" HDTV
Noise from inside TV
Sometimes the screen goies on and off
Probably the colour wheel needs to be replaced. You must have a qualified TV tech to perform the repair.
Posted on Feb 04, 2009
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
Screen issue for dell inspiron 5110, I dropped my laptop earlier today fron about a foot n a half drop, the back of the screen is what hit the ground first, the screen was fine though, not shattered but it...
The screen's connection is loose or something is broken inside. I suggest that you have it checked by a technician but if you can do it, then you better check the connections.
I hope this helps!
David
Jun 07, 2013 | Computers & Internet
NOISE LINES I THINK
Hello
These lines are calle vertical retrace lines. Try to eleimitate them by adjusting its screen control. Screen control is inside the Tv, can be located at the LOT.
Mar 02, 2012 | Sony KV-27V65 27" TV
Good Morning\r\n i have a JVC Interiart 29" Flat screen tv which is 8 years old which has started making a noise when switched on,a very loud humming noise and no picture for a couple of minutes then the...
That usually indicates a capacitor going out in the power section or flyback section of the board inside. Depending on your repair shop this can be a fairly cheap repair (or not). Get an estimate and know what a replacement tv is worth. Sometimes its cheaper to get a new one than repair the older tv. As well power problems can stress other parts so it might get fixed only to fail later.
Jun 14, 2010 | Televison & Video
I have a Mitsubishi WD-57833, made a loud popping noise, piture went out, I removed the bulb it is out, but on the back bottom right side has a sparking goiing on inside, is because the buld went out?...
Yes, its the Lamp sparking is coming from your Ballast Board their is a What they call it Spark Cap diode it will ark when Lamp is Bad. FOX has that Lamp for $139.00 1-800-227-5369 Mats Electronics Listed Lamps for $99.00 and up? 1-800-628-1118
Jan 09, 2010 | Televison & Video
Hello, I own an LG42PCSD,good picture, but, i am
Sometimes the transformer on the Z-Sustain board can vibrate & give off a high pitch noise or hum, or the tranformers on the power supply, I've even known the plasma screen itself to cause a hum. The best remedy is to try & locate exactly the area of the hum to pin point which board is the cause & then replace the board or if it is the screen, then it is more economical to try & put up with the noise rather than replace the screen.
Jan 08, 2010 | LG 42PC5DC 42 in. Plasma HDTV
Tv shutting off auto
Solution: Replaced color wheel ( inside engine light), ( broken or defected inside). I fixed a lot with this problem. partstore.com or tritronicsinc,com
I hope this help you Thank you
Aug 08, 2008 | Samsung DLP HL-P5663W 56" TV
Dvr station
hi
pl see kept PAL/ ntse now ok
Jun 06, 2008 | Archos DVR Station for Select Portable...
Mitsubishi big screen TV
Sounds like something in the deflection or audio circuits. Wish I could help more. I will post a link where you can get the service manual.
http://servicemanuals.vstore.ca/
Feb 28, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Sanyo DS32920 Blue Screen
My panasonic Tv pic suddenly turned into a blue color I can't see the pic any more just can hear the audio.....any solutions????
Mar 19, 2006 | Sanyo DS32920 32" TV
Toshiba 46HM95 46" HDTV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
