Question about Dell 924 All-in-One InkJet Printer
Refilled cartridge dell 924 wont recognize
I have just tried to put in a refilled colour cartridge into my printer and it wont recognise the cartridge, this cartridge is the original and have had it refilled. any suggestions
Can someone direct me on how to put ink in my printer
Posted on Feb 04, 2009
I filled in a Dell 924 cartridge and now the printer does not recognize it and does not print
if the cartridge is chipped, it will still be recognised as empty, since the cartridge uses a backwards counter to estimate the amount of left-over ink. there are tools to reset the chip on an ink cartridge to refill it, which you can normally buy in the shop where you bought the refill-kit (if not already included). please note that the cartridge may not warn you again about being empty. when print quality deteriorates, refill. if print quality stays bad (even after a refill), replace the cartridge with a new (original) one.
Jan 18, 2010 | Dell 924 All-in-One InkJet Printer
My 725 printer keeps telling me the print cartridge is missing
try to restrt you printer and your computer..or clean the tab circuit of the carrier or the cartridge holder...
May 19, 2009 | Dell 924 All-in-One InkJet Printer
Printer cartridges not recognised
Sometimes even when an ink cartridge has been refilled to capacity, your printer still registers it as empty. This is because your printer remembers that the cartridge was previously installed and it can only remember it as being empty. Part of this is due to technology put in place by printer manufacturers so that you will always have to buy new cartridges. Part of it is also that print catridges are clogged if not used for sometime after its empty even after refilling this is because the contact was already clogged due to the dryness of the old ink inside it before refilling so in that case you will clean/soak the contacts with solvent before refilling .
again since there is no “official” way to fix this problem, you have to basically clear the printer’s memory to make it recognize that you are installing a full cartridge. If you have tried to install the refilled cartridge and you have done all you can to convince your printer that the cartridge isn’t still empty, then basically you just have to unplug your printer for a minute and then trying reinstalling again. but it should fix this problem and it can potentially fix other annoying things your printer is doing.
Sep 06, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Dell 924 inject
Use only original cartridges and not generic/refilled ones. I think that is the source and answer to your problem ;)
May 15, 2008 | Dell 924 All-in-One InkJet Printer
Dell photo 966 error 1243 incorrect cartridge
is it a refilled cartridge? if it is it wont recognice it u should just buy a new one or keep printing if it lets u because i had the same problem and i had to get a new cartridge because it wouldnt let me print at all
May 02, 2008 | Dell 924 All-in-One InkJet Printer
Problem with Dell ink jet refill....
Are you using the Dell software to replace the cartridge?
If you where just replacing without running the software then it wont know you have replaced the cartridge.
Let me know.
Zod
Apr 24, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 printer problem with black cartridge
Dell printers donnot seem to work on refilled cartridges. Do buy new cartridges to fix the issue
Apr 08, 2008 | Dell 924 All-in-One InkJet Printer
Dell All-in-one 924 error: "right cartridge is incorrect"
Hi ,
if you are getting the error msg 12203 , pperform the following steps,
remove both the cartridges from the printer and unplug the power adapter ( black box) from the back panel of the printer, clean the cartridges using a damp cloth .
initially put only the black cartridge and then turn on the system , it will give you the error msg right cartridge missing, you can ignore it and try copying a document .
remove the black cartridge and put the color one in, and then try printing.
during the printing with any of the cartridge inside the printer if it gives out the error msg 1203 then that cartridge has to be replaced...
Mar 05, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
247 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
