Question about Polaroid FLM-2632 Television
Turns on but nothing else works
I had the TV connected to my PC when it broke, I restarted the computer and the TV kind of freaked out. Then, when I would turn the TV on, there would just be a blue screen... after a couple of hours of trying to get it to work the blue screen started turning black. I would try changing the input from PC to TV, but no buttons work on the remote or on the TV. I have to unplug the TV to get it to turn off.
Any clues? Someone told me the tuner. But I don't know how the tuner could make no buttons work, etc. I'm thinking the motherboard.
    President:
  • Polaroid Master
  • 1,779 Answers
Your probably correct, however, the tuner also has serial/data lines going to it so the tuner can cause that problem but highly unlikely.
Posted on Feb 18, 2009
When I hook up my PC to my tv nothing shows up on the screen
check to see if your TV remote has an "input" selection. Look for something like "line" or "PC" as a choice. Failing that, your computer might not be generating the signal on the cable yet. With the cable connected try the F8 key on your computer, or just restarting it.
Sep 21, 2014 | Cell Phones
I have a pc that the screen stoped working. so I have it connected to my phillips tv via HDMI, and it was working good like that. but know every time I shutdown and restart I get "prepare boot to...
Your tv will only work when it is hard wired to the computer output. With no connection, of course, it is not going to work!!!!!!!!!!!!!!!!!!!!!!!
Aug 25, 2017 | Computers & Internet
Compaq Presario V2000 PC Notebook: All ports are "in use" with nothing connected. I c...
Click on start. Then click on Run.
Type in MS config.
Uncheck load startup Items.
click on ok and then click on restart.
Any application which turns on and starts using your port when the computer turns on would stop loading on their own and you will have free ports to use.
May 17, 2010 | HP Compaq Presario V2000 Notebook
Nothing comes up on the screen but the computer turns on
It really needs to get to a shop. It could be a failed hard drive, bad ram, or a motherboard issue. If it posts (you get a logo or some kind of screen), then it could be a software issue. There's not much way to tell without proper testing of the parts.
May 01, 2009 | Computers & Internet
External hard drive not recognized
You need to first narrow down the problem to either your PC or the external hard drive. Do you have access to any other PCs you could try connecting your hard drive to? (think friends, family, public PCs, etc)
If the hard drive works on other PCs, we know it isn't a problem with the hard drive.
If it turns out that the hard drive is fine and the PC is the problem, I would suggest going in to Device Manager and uninstalling everything USB related. Once you have done this, either reboot your PC or right-click inside device manager and "scan for new hardware". All of your USB related devices should reload their drivers automatically. You may want to try this both with and without the usb drive connected.
Another tip would be to try various USB ports.
Mar 19, 2009 | Western Digital 500GB My Book World...
Screen freaks out when external monitor connected
prombelms quite simple your 42 inch monitor has to many colors for the driver and it cann't work with it is incompatiable.....lala linda
Jan 06, 2009 | Acer Aspire 5100 Notebook
S510 Logitech Keyboard & Mouse Connection
Normal 0 Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
May 19, 2008 | Logitech Cordless Desktop S 510
Failure to work
Hello Ruxi,
The problem could be viral in nature.
Are you running an Anti Virus application, and if so are it's virus definitions up to date?
Do you hear any sounds (through your speakers, or the hard drive spinning) when you re boot the computer? And what do you mean by "it just broke down"?
Have you tried to enter your BIOS or boot to "Safe Mode" on boot or do you not even see anything on the screen at all ever now?
You can try the above if you haven't already, and let us know what you find.
We'll be checking on this, and Good luck.
Mar 18, 2008 | Acer Aspire 5100 Notebook
Compaq Presario V6000
It actually sounds like you might have a hardware problem. If you're comfortable with opening the computer, remove any recently added hardware. If no hardware was added, then it may be necessary to remove each of the components in the following order and retest the boot process until it functions, and replace the last part removed.
Pressing F8 and/or reading the CDROM that early in the BOOT sequence is not possible, so it's in a hardware check.
Floppy, CDROM, SoundCard, Network Card, <any other cards>, extra RAM, except one or two to be able to boot.
It is also possible that either internally or externally, a cable may be loose. If you are able reseat all the cables, this may make it work. Stuff can come loose and the computer freaks out.
Lastly, if you feel like making sure that component is the problem, start plugging all pieces back in and all may work. This would mean that something was loose.
Nov 26, 2007 | Compaq Presario s4020wm (DK214AR#ABA) PC...
Polaroid FLM-2632 Television Logo
79 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
