Question about Jensen VM9410 Car DVD Player
My jensen in car dash reads no disk when I load a cd or dvd
No matter what I do it will not read anything I've had this for a yr and it's always worked could I need to clean the lens or just get a new deck?? I use a ipod and that works just fine its just dvds and cds.
zappanut
  • 959 Answers
SOURCE: Jensen VM9312 not loading DVD.
If it reaeds the cleaner... then try another disc. 20-30 seconds is a long time to looad a disc...
If the new disc does not work either , I would suggest resting the deck .
If reseting does not help , it is still under warrantee. so have it serviced.
Posted on Dec 12, 2008
LVT7857
  • 116 Answers
SOURCE: bad disk
Wow! That's a first. I used to sell both the Jensen AND Phase Linear versions and never a problem. It sounds like a bad unit. You say it plays NOTHING? No CD's OR DVD's that are the factor made?
The only thing I hav up my sleeve is to do a reset on the unit. If it has a button (I don't think it does frm what I remember) use it first, then with the unit ON, unplug the poer plug, wait a few, then plug back in and see.
Sorry I have no more tricks foir that,
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
MNfisherman
  • 11896 Answers
SOURCE: jesen touch screen player new will not play cds or dvds , it will scan the disk and in a moment will promptly eject the disk . is this a factory recall?
My first question is: Has it ever played CDs? If not, it try using factor CD's and NOT Burnt ones.
I also recommend taking the cover off the player and use rubbing alcohol and a cotton swab and clean the glass laser eye. They tend not to read when they are dusting.
If the player is going to work, it will after the suggestions I just made. Otherwise the laser or laser motor may be faulty.
Posted on May 22, 2009
  • 10 Answers
SOURCE: vm9212n in-dash dvd player won't load cd's or
Must reset lazer lens manually. Most of the time this does the trick. hope this helps you
Posted on Jul 01, 2009
SOURCE: jensen uv8 sub works with radio an dvd but not with cd
quiero instalar mi dvd car radio y violar el codigo de parqueo se que hay opciones para poder estar el vehiculo rodando y poder verse el dvd gracias
Posted on Sep 13, 2010
I got a Jensen VM9020TS Car DVD Player ,i have a problem with it , why i can't play dvd when i inserted it is said loading but nothing happen?
Please try to put in an ordinary audio CD track and see if this is detected. If yes the optical is working, if not there is no laser scanning and the possibility of the head being faulty is high.
Now certain cleaner disks are not read and so will not be tracked.Try to open and do a cleaning manually of the laser head eye with a cotton bud very softly and without any pressing of the lens eye.
make sure that the Cd is loading into the drive and sets into the head if not the loading mechanism has some errors and must be reset for proper loading into the slot. possible obstruction or dirt accumulation must be checked.
Dec 10, 2010 | Jensen VM9020TS Car DVD Player
The Jensen dvd player won't play all dvds. It says dad disk on brand new disks. Does anyone know how to make it read all dvd's.
New player? Under warranty? Take it to whoever installed it. Sounds like a weak laser, or a laser alignment problem. Could also simply be a dirty laser lens, but proper cleaning requires disassembly (those laser cleaning discs are hit-n-miss, and I've seen them actually damage the laser pickup, so I do not recommend them).
Nov 21, 2009 | Audiovox Jensen In-Dash DVD/CD Receiver w/...
Dvd player always says no disc . will not load
That happens because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only few CD, DVD. After more prolonged usage , often the unit will start losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD cleaner disk to clean the lens. If that does not work you will need to disassemble the player, and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
Aug 28, 2009 | Philips DVP3962 DVD Player
Dvd will not read
If purchased less than a year ago, it's under warranty. Get it replaced.
Warranties are normally for one year unless you bought an extended warranty. You should be OK.
Jul 07, 2009 | Acer Aspire 2100 (91.AB675.D02) PC Desktop
LightScribe DVD SuperMulti Drive/CD-Writer won't read disks. It has been cleaned and passes all tests. Has read these disks before, but file will not load from disk.
check and see if there are updated drivers and install them. have you changed your Operating System via upgrade or anything.
May 26, 2009 | HP PAVILION A6230N DESKTOP PC
Bad disk
Larry T
Winona Lake, IN
Jan 26, 2009 | Jensen VM9510 Car DVD Player
Dell D600 not reading any type of disk
When the CD does not read any disk, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD will not be read, therefore the error.
When this problem is beginning you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
Try first using a CD lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with cotton tips and isopropyl alcohol, or to replace the CD drive unit.
Jan 14, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
My phase linear uv8
Hi
The Laser Diode inside the UV8 that reads the DVD media is most likely set too weak for the amount of dust built up in over time. This dust block the laser optics and causes the player to not read DVD's. You will want to go get a bottle of air from Radio shack and blow the DVD player out. The reason it is reading CD's is that its laser diode may be set stronger and is able to break through the dust. There are two Laser Diodes, one for CD, and one for DVD. Good luck. www.PlaystationClinic.com
Sep 04, 2008 | Jensen VM9510 Car DVD Player
Jensen VM9410 Car DVD Player Logo
73 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
