Question about Maytag Atlantis MAV6000 Top Load Washer
Matayg Atlantis Washing Machine gets stuck in the Rinse Cycle and will continue to rinse for hours.
  • 370 Answers
This is the sign of a bad timer. It is not sensing how long it has been in the cycle. The timer is not advancing. Replace the timer.
Posted on Feb 04, 2009
My eurolux dw2112p/1 gets stuck halfway in rince cycle
replace the timer: a tiny gear that is driven by the timer mpotor has broken teeth at that time point
Feb 04, 2013 | Washing Machines
My whirlpool washer periodically gets stuck on rinse.. the water continues to run but its only about half full so it must be draining. My water bill was over $100 last month, please help.
check the lid switch, if it isn't working right the machine will not enter the spin cycle, also the timer may be going bad, it could stay stuck in between the rinse fill and rinse cycle
Jun 21, 2011 | Whirlpool Washing Machines
My MayTag Atlantis washer will not spin or drain the water out, when it gets to the rinse cycle or spin cycle , it just makes a buzzing or clicking noise.
The brake mechanism is not releasing properly. The noise your hearing is the motor trying to move but can't. Do not continue to operate the washer or you will burn out the motor...an expensive replacement. See instructions for my other solutions.
Sep 23, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Not draining after rinse cycle
replace the timer it has a bad spot inside of it in this segment of the timer and isn't passing voltage for spin,when you forward it then it gets power again,they do wear out too
May 14, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Hi, I have a Maytag Atlantis MAV9750AGW and have experienced loss of power to the machine on many occassions over the last week. Machine stops mid cycle and has no power. Machine will eventually start...
george first thing i would do is have the receptical replaced old recepticals have a tendicy to get hot and fail also go to the electrical panel and turn the breaker fully of then on older breakers tend to get stuck when they get old sometimes they dont trip but they dont supply the correct amperage either good luck
Apr 12, 2010 | Maytag Atlantis MAV9750A Top Load Washer
Water not filling in tub washer spins,
It sounds as if the timer has failed internally. Spinning on each setting means the motor is not reversing and that reverse function is controlled by the timer itself. It would never fill if it is stuck in spin unless you select rinse and depending on cycle it can inject water in the spin during the final rinse. If your machine does this normally see if it injects water. If it does inject water at that point I am 95 % sure your timer is the problem.
Jan 11, 2010 | Maytag Atlantis MAV6000 Top Load Washer
In spin cycle machine makes squeaky noise.
Your bearings could be going out, causing excess stress on the belt. Take the back off of the washer and check the belt tension. If there IS something stuck back there, you'll be able to see it.
May 21, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV7200 doesnt drain at end of rinse goes to OFF
It sounds like it may be the lid switch. It may be as simple as adjusting or tightening. But ultimately it may need replacement.. Hope this helps
Apr 04, 2009 | Maytag Atlantis MAV7000
Maytag Atlantis 6451 Stops abruptly at end of rinse cycle
sounds like the brakes squeal to me is that the end of the cycle if it is i would worry about it brakes do that not worth the effort of dealing with
Jan 27, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
711 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
