Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
No hot air
I have a honeywell furnace that the fan blows but theres no hot air. it stays at 58 when i have it set to 70. The burners are cooled and weve tried restarting the gas and theres still nothing. the model number we have is sv9500m
  • Henry Russ May 11, 2010
    Jennarose061, Do you have plenty of fuel (gas)? Do you smell any gas? If you have fuel, then it sounds like your Ignition Control Module may be at fault or if your gas regulator is a 24VAC type, then check for 24VAC at the electrical wires supplying the gas regualator.
    Problem Solver:
  • 17 Answers
The sv9500m units are notorius for having cracks in the solder connections where the 4 wire plug socket attaches to the board in the gas valve. A short term fix or test is to apply pressure to the wiring by twising it, then try a relight. If it works you have a loose solder connection. To repair this (you assume all liability- there is no room for oops here)- remove 2 small security torx screws holding the plastic cover on. Remove only the half of the cover with the on/off switch sticking though it. It should just lift off. you may have to move it around a little no forcing. The solder spots are now accessable. check & resolder the connections where the 4 wire main connector hooks to the board- put the cover back on & test it. done.
Posted on Jul 06, 2013
    New Friend:
  • 92 Answers
Well first off honeywell does not make furnaces.all a home owner should do when dealing with any type of troubleshooting is what the manufactorer tells them to do in owners manual.heating systems can be very simple or complex but all have the potential to go boom so if your not sure call a professional
Posted on Feb 05, 2009
Furnace blower fan stays on
Gotta have some info..............is It a gas furnace?What brand?Model?
Fan switches do get stuck ON. Is it blowing ALL the time,cool air? don-ohio
Dec 30, 2016 | Heating & Cooling
Fasdfas
Does the furnace stays off?.
Furnace are ment to cycle on and off because of limits .If you set to 70 furnace would cycle several times before reaching that temperature.
Just make sure your filters are clean and you got proper return air flow because lack of air flow will cause furnace to shut off sooner than normal
Jun 08, 2017 | Heating & Cooling
The furnace comes on just briefly then goes off, after a time it will come back on and stay on. Is this normal?
Yes, depending on exactly what you mean by furnace on. Many furnace fans react only when plenum temprature reaches a certain amount.... (helps keep from blowing cold air) The circulation fan can run several times after burner shoutdown, based on the temp....
Mar 01, 2011 | Honeywell Heating & Cooling
I installed a honeywell CT87N thermostat. The
the burners light? if the burners dont light than it's working right the blower on the furnace comes on with the a\c
Jun 19, 2010 | Honeywell Electronic Programmable...
Own a heil gas furnace. The thermostat is set at 80. Is it normal for the heater to turn on and the burner to come on for 2 seconds, shut off then the fan blows room temperature air, then the cycle is...
Not normal. Is the thermostat located away from a heat supply vent (and direct sunlight)? If so, it will sense temp higher than it actually is, and shut off burner.
Sep 06, 2017 | Honeywell International Heil Quaker...
When furnace kicks on the air seems cold at first, is that the humidifier?
There are two sensors on the burner box of the furnace that control the fan. One tells it when the furnace has warmed up and the other tells the furnace has cooled down. If it blows before the box is hot enough, the limit switch is bad. Any heating and cooling company can get one for you and you can probably switch it out yourself.
Jan 28, 2010 | Aprilaire Humidifiers
Blower won't stay lit
If the fan motor is blowing out the burner then is there a hole in the heat exchanger
Jul 18, 2017 | Honeywell Power Humidifier: Furnace...
150000 1974 national gas forced air furnance does the fan come on the same time the gas comes on. ...
not familiar with that particular model but on virtually every type and style of furnace i have worked on in the last 21 years. the fan is delayed. usually the burner lights then 3 to 5 minutes later after the heat exchanger has gotten nice and hot the fan comes on and blows nice and hot air. on old furnaces there was and is a switch usually on the upper right side of the furnace bulkhead that has a spring like device that heats up and rotates till it makes a set of contacts that turn the fan on. if it gets to hot the set of contacts breaks the power to the gas valve and shuts down the burner. as the furnace cools down on shut off there is a third set of contacts that open to turn off the fan so you don't get a draft. sometimes the stat can be wired up wrong, and it will bring the fan on right away ,and air will be cool and drafty till furnace catches up.
Nov 12, 2008 | Heating & Cooling
Heating & Cooling Logo
148 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
