Question about Frigidaire FEQ332E Electric Dryer
Large knob broke
Me again. The large knob that sets the drying mode and the drying time seems to have broken. Do I have to take the top of the dryer off to fix this? Is this something I can fix being half handy and having the tools?
  • 1 more comment
  • ksklong Feb 03, 2009
    no, it seems the motor mechanism inside the dryer broke. The shaft now is wobbly and doesn't turn correctly.
    How do I remove the lid? It seems to be easier to remove the back than the lid. I noticed two notches in the front but not sure if they are useful/ Thanks.
  • ksklong Feb 04, 2009
    Got it. Had a hard time pushing and pulling the front of the top up. Also, I only had two screws on the back hinges so I kept looking for two more. Any idea where I get the new timer unit?
  • 640 Answers
Just push in and turn counterclockwise...now the shaft of timer did not break,,,???
Posted on Feb 03, 2009
  • 1 more comment
  • onthethejob1
    onthethejob1 Feb 03, 2009
    ok unplug unit remove lid...now you should see the back of timer...the screws for timer are in front...you have to dislog knod and pull that dail straight out..keep me posted
  • onthethejob1
    remove the for screws on back and top and slide forward...
  • onthethejob1
    onthethejob1 Feb 04, 2009
    ok now we have to do our homework,,everyone is trying to make a buck ,,so you have to shop around for best price ok,,,but im going to give you a start...appliancepro.com...apwagner. com...searspartsdirect.com....good luck
Dryer will not stop when clothes are dry in auto-sense mode
Try "timed" cycles. If it shuts off on timed it's not the timer. It's more likely it's not cycling on the thermostat due to an airflow problem like the vent. To rule that out (or in) run ONE load through it with the vent disconnected. If it shuts off you'll know where to look
May 03, 2014 | Admiral AED4475TQ
WHERE CAN i BUY A KNOB FOR GE 3-CYCLE EXTRA LARGE CAPACITY GAS DRYER?
You can try an appliance parts dealer or maybe one of the online sources
Jan 05, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
How do i reset code e63
your coils in the heating unit are touching the can you will need to clear them probably have to replace a broken porcelin insulator once you do this then you can reset the machine.
factory reset, press and hold the temperature and dry level buttons simultaneously for 6 seconds for models with temperature and dry level and dry time buttons press and hold the drylevel and dry time buttons simultaneously for 6 seconds.
diagnostic mode press the cancel button to enter standby mode and enable diagnostic entry.within 10 seconds after pressing cancel press and button but cancel to wake up the control. within 5 seconds of wake up turnthe selector knob to the far left cycle and press and hold the cancel and the center button under the display simultaneously for 3 seconds to enter the diagnostic mode. upon entering diagnostic mode all lights should flash on and off turn the selector knob clock wise on setting, you will need a book inside the dryer to read the codes pop off the top of the dryer it should be folded down in the front of the machine...
Jul 29, 2012 | Electrolux EIED55H Dryer
When washing Machine goes into spin cycle, , it starts making a grinding noise and never goes to full momentum and starts to slow down, after the grinding noise. The clothes aren't fully dry as they...
Sometimes, a Whirlpool dryer may not function as you'd like.Although specific details vary by model, the company offers several generalguidelines to troubleshooting your Whirlpool dryer and getting it back intoworking order.
Verify that thedryer is connected to its power source if it won't turn on. Whirlpool alsosuggests checking your home's circuit breaker, as the high power needs of thedryer may have tripped the circuit. If the circuit has been tripped, reset itby flipping it back into the "On" position. Push the door of the dryer. Whirlpool designed its appliances to not turn onif the dryer isn't secured and notes that the dryer door may not be fullyclosed even if it appears shut. Push firmly at the top and bottom of the door,as some Whirlpool models have two latches. Press the "Start" button again. Whirlpool reports that some modelsrequire you to press and hold the button for five seconds to fully start themachine. Depending on the model, the button may be labeled "Hold toStart," "Start" or "Push to Start." Check that the dryer's settings knob is set to an actual drying mode and notsimply "Air" or "Tumble." On most Whirlpool models, themanufacturer states that the settings knob should be set to"Accudry," "Timed Dry" or "Automatic Dry." Clean the lint trap, typically located at the top of the dryer and removedby pulling its plastic handle. Over time, lint and dust builds up here. Thethicker the trapped layer of lint, the slower your dryer performance. Whirlpoolrecommends removing built up lint after every dryer load. Remove some of the wet clothes inside the dryer if it's taking an unusuallylong time to dry your clothes. Whirlpool warns that placing too much clothinginside the dryer reduces hot air circulation, which also reduces dryingcapabilities. Recommended dryer load s vary, with compact Whirlpool modelsholding approximately 3.4 cubic feet while extra large Whirlpool dryers holdingmore than 7 cubic feet.
Jun 07, 2011 | Washing Machines
Dryer does not dry all the time sometimes it dry fast other time you have to reset 2-3 times
You can put this machine into the field service mode to view the errors here is how to do that.
  • Turn the dryer on.
  • Go to the home screen.
  • Press help.
  • Press and hold my cycles and back simultaneously for 3 seconds.
Once done you can view the errors, post what it says. Note that once you exit this mode it will erase the errors so write them down.
Feb 28, 2011 | GE Profile Harmony DPGT750EC Electric...
Dryer taking to long to dry
Overloading
1. One of the simplest problems to remedy could simply be that you are putting too many items inside the machine during the drying cycle. Avoid overloading your dryer, as this might cause your dryer to work extra hard to dry your clothing, extending the length of the dry cycle.
Wrong Heat Setting
2. A common issue with clothes dryers could be the wrong heat setting. Most home dryers feature several settings, from low heat settings to high heat and permanent press. Be sure the setting you choose is right for your needs. Another setting to check is the load size of your dryer. If you are drying a large amount of clothes, be sure the setting for large loads on high heat is selected. Choosing the wrong heat setting or load size can cause your clothes and linens to take longer to dry.
Lint Trap
3. One of the simplest fixes for drying issues might just be that your lint trap is clogged. Each time you use your dryer, lint will form in the trap. If the lint trap and vents are full, this could block air going into your dryer and slow down if not completely stop the drying process. After you use your dryer, remove this lint trap and empty it fully. Even if the lint trap is full, your other dryer vents might be clogged as well.
Clogged Vents
4. If your clothes are in the dryer for a long amount of time, but still not drying, the reason for this could be a clogged vent. A sign that your vent is clogged is if your clothes are warm or hot to the touch after sitting in the dryer, but still damp. To unclog your dryer vent, you may need professional assistance. This is especially necessary if your dryer vent leading out of the house is particularly long.
Heat Source
5. If the dryer is not getting enough heat to dry your clothes,something could be wrong with the heating system. After the drying cycle, touch your clothes to see if they are warm. If not, this means that the heating mechanism is malfunctioning. It will need to be repaired or replaced by a professional.
Feb 28, 2011 | GE Profile Harmony DPGT750GC Gas Dryer
My Whirlpool Duet gas dryer doesn't seem to be drying my clothes. The clothes are staying damp.
If the load is extremely large or heavy it may require more time. If you are using the auto cycle and the clothes are not drying try setting the sensor to a "more dry" setting. Make sure the lint filter is clean and that the exhaust vent duct is not clogged. Check all the way to the outlet. If all is clear then the thermostat may need to be replaced if it is not calling for heat as often as it should. Also check to make sure there is air flow from the vent. If not then the fan/blower may be broken or disconnected from the motor shaft.
Dec 22, 2009 | Whirlpool Dryers
How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
How to use the dryer?
This should be simple and will not need a user manual. For silk, polyester, nylon, wool and delicate fabrics that dryer setting knob should be set to "Less Dry" or similar settings and then press on the start knob. For cotton, use the "More Dry" Setting. Now, these settings may vary between models. I am more familiar with the Whirlpool ones. Gook luck.
Aug 30, 2007 | Hoover Nextra HNWF 3135 Front Load...
Drying time knob broke
You should be able to simply push the new knob right on the switch shaft. If part of the broken knob shaft is on the switch, remove it first before installing the new knob. If you see that the switch shaft is broken off, replace the switch as well. Hope this helps.
Aug 07, 2006 | Hotpoint Aquarius WD63 Front Load...
Frigidaire FEQ332E Electric Dryer Logo
82 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
