Question about IPC -400
Wifi disable hi. i bought a ipc 400 mini laptop . the wifi is disable. how can i fix it i see all the available wifi network but i cant get in. thanks
  • Peter Steiert
    Peter Steiert May 11, 2010
    Are you trying to connect to your own wireless network or someone else's?
    Master:
  • 474 Answers
If you can see the available Wifi signals in your area then the wireless is turned on and working fine. you need an encryption key and to configure it or have it auto detect to connect to them.
Unless they are open connections with no encryption/security.
Do you have your own wireless network or are you trying to get on some one elses?
You will need your encryption to get on.
Select you connection from the list, click connect and it should prompt for a key code. enter it and it should do the rest.
Posted on Feb 03, 2009
I cant connect to wifi with my dell inspiron e1505
go to device manager and disable your wirless network adapter.wait till ten seconds.then enable it again.......
please also make sure that your device driver is up to date...
Oct 30, 2012 | Dell Inspiron 1501 Notebook
My gateway laptop cant connect to the internet. _When I plug a cable, the red light in the port does not respond _ The WIFI does not respond
Hello John,
It seems that: 1. Your LAN controller and the WiFi controller could be disabled in your BIOS setup.To re-enable them, if applicable,
  • Press the F1(or F2 ) key repeatedly after restarting the computer to enter the BIOS setup.
  • Navigate through your BIOS and locate the settings for LAN conroller and wireless, and select Enabled to enable them.
2. You may not have the appropriate drivers installed on your laptop for your network controllers. Upon further investigation, your laptop runs on the following network hardware:
  • ActionTec IEEE 802.11b network card installed in Mini PCI expansion slot
  • Broadcom BCM94306 IEEE802.11g network card installed in Mini PCI expansion slot
  • Broadcom BCM94300 IEEE802.11a/g network card installed in Mini PCI expansion slot
Download and install your drivers for the hardware above from: Wireless Drivers(Broadcom BCM94306) from http://www.soft32.com/download_175098.html Broadcom BCM94306 10/100Mbps LAN drivers from http://www.broadcom.com/support/ethernet_nic/downloaddrivers.php
Hope this solution helps.Good day.
Jan 14, 2011 | Gateway M305CRV Notebook
No wifi
Hi its very small switch with the WiFi symbol on it check at the front of your laptop and some laptops have it at the side you can find it easily check carefully
thank you
if this information is useful kindly vote for me
hbristol173
Mar 31, 2010 | Computers & Internet
How to turn off wireless on Advent 5421
You can disable the wireless adopter
Type ncpa.cpl in run command
It opens the network adopters in ur laptop.
Right click the wireless adopter and disable
Thanks
Siju
Aug 28, 2009 | Dell Inspiron 1525 Laptop
Cant connect laptop to internet
Hi!
I think that maybe you are using and incorrect password to connect to your wifi network.
Feb 18, 2009 | HP Compaq Evo n610c Notebook
Wireless router
device manager and if you see ethernet right click and disable
don't disable the wireless network then right click the wireless and if you see enable click otherwise click and update
restart--- then control panel and network connections
then view available networks if a network shows highlight and then click connect
if there are no networks then on left side of page click refresh network list do this until you see a network then again high light and connect
please let me know if you are connected now
Feb 01, 2009 | Acer Aspire One PC Notebook
Cant get my belco alpha 400 linux 2.4 online by wifi
First of all does the modem say you Internet check the LED light or directly connect your laptop to it through the Ethernet interface looks like a phone plug but wider if you do have Internet the problem is with the router. it is not syncing with the modem this should be fixed by reseting or unplugging for about ten minutes if thats does not fix the problem you may have a faulty router or a modem doesn't send the right code to your ICP why you can get LAN Internet and not wireless is one of those mysteries.
Jan 01, 2009 | Computers & Internet
IPC -400 Logo
213 people viewed this question
Top IPC Computers & Internet Experts
David Payne
David Payne
Are you an IPC Computer and Internet Expert? Answer questions, earn points and help others
