Acoustic Solutions SP151 Hard Disc Jukebox, keeps saying bad disc
I have just got myself the above item.
Started putting my cd's on to it yesterday and with pretty much every other cd, pops up a message saying bad disc and stops the process.
It is rejecting a wide range of discs, new - old, well used - hardly touched.
Would like to try and solve the problem so haven't got to send the bloody thing back
  • Anonymous Mar 10, 2009
    Hi, I bought the same thing, same problem. Dealer was happy to exchange it, but I had already loaded som e2000 songs onto it. The dealer then suggested the swapped the CD player part which cured the problem.
    Gerrit Bulten - The Netherlands.
Jukebox will turn on and pick up cd but won't play
You did not say if the disc turns or not. You also did not say if it puts the disc down and immediately picks it up. If it immediately picks it back up you probably have a bad microswitch. Other than that the first thing to do is to clean the laser eye. Use 90% or higher isopropyl alcohol on a q-tip. DO NOT USE 70% ISOPROPYL. It has too much glycerin and mucks up the eye. Many people screw up their boxes this way and it is a simple fix. Hope this helps.
May 03, 2014 | Wurlitzer Jukebox CD Player
It won't play disks and just makes a lot of mechanical noises as it goes from disk to disk trying to play one.
The mechanical parts are working but the laser pickup assembly is not reading the disc. The possible causes are, dirty laser pickup lens, bad pladder motor, or no b+ to the motor, or worn out laser assembly system. Because of the expense of buying the Bose units I highly recommend a professional service man to work on the item.
Dec 28, 2010 | Bose Acoustic Wave (32022) 5-Disc CD...
Hi! my OMT CD Wurlitzer is in need of a new printed circut board, is has the phillips CD Player unit CDM12 ABOVE IT. Type;CDF 91 0055647 Model: OMT CD -100 nz NR 41018750 V 100-240 any help with locating a...
Hi Ken,
I would search on Ebay (do a world wide search)
Here is a seller selling the head only.
Item number 380005560333 (UK seller)
There are a number of sellers world wide including Hong Kong and the USA.
Best of luck.
Alan Hood
Item number: 380005560333 Item location: Kingston, Surrey, United Kingdom
Oct 15, 2009 | Wurlitzer Jukebox 1015 One More Time...
Sony vaio pcv rx680g desktop
First, ensure that the bios is reading the hard drive and that the hard drive is part of the boot sequence. If you have a known working drive and the drive is not been read by the bios, you will get the Disc Boot failure error because windows resides on the disc which the bios cannot access.
Secondly, if the bios is reading the disc then ensure that the disc is set as part of the boot sequence-preferably the item after DVD drive should be Hard Disc in the boot menu.
If both of these items are in correct order then you could have a bad boot sector on the drive. Run a C:Chkdsk. If no bad sectors are found try C:Fixmbr-ensure that the Windows installation disc is in the CD/DVD drive when running Fixmbr.
If that fails do a clean install of windows.
Good Luck
Sep 28, 2009 | Sony VAIO Digital Studio PCV-RX680G...
Bose Wave Music System - CD Says "Not Playable"
I turned mine upside down pressed play and it started working.
Turned it back over and it's working fine.
Dec 22, 2008 | Bose & Wave& Music System
Toshiba DVD SD-3980SU2 or SC2 player loads every disc as "bad disc"
Toshiba says:
Information for Owners of Toshiba SD-3980 and SD-K750 DVD Players spacer.gif To ensure the satisfaction of our customers and to maintain the integrity and quality of our products, Toshiba America Consumer Products, L.L.C. is issuing an important product update. This is not a safety issue.
Toshiba is committed to customer service and to continuously improving the quality of its products. It has come to our attention that certain DVD players bearing the model numbers SD-3980 and SD-K750 may at some point in their life stop playing discs due to a component part failure. In such case, the error message "bad" will be shown on the unit's display. Affected units will have "SU2" at the end of the model name (e.g., SD-3980-SU2), which can be found on the back of the unit.
If you own either of these models and experience the issue described above, please contact Toshiba Customer Solutions at 1-800-631-3811 for information on how to obtain a replacement unit.
Mar 29, 2008 | Toshiba SD-3980 DVD Player
635 people viewed this question
