Question about Amana ACF7225 Electric Kitchen Range
My amana oven stopped working. Oven modle #ZRTC7511.
Stove tops work fine, but the display has blacked out and the broil and bake will not come on
  • Thomas Malailua
    Thomas Malailua May 11, 2010
    my advise as repairman.find your wiring diagram that comes with your range.then look at the path ways that the voltage travels to get to your oven/broil elements/clock and start your checks their .
SOURCE: Amana ARG7300w oven inop
It has a bad oven igniter.
Posted on Aug 27, 2007
jbjaxiis
  • 95 Answers
SOURCE: Amana oven and broiler won't fire
Check your stove breakers first. Click them off, leave them off for a minute and put the breaker back on. It sounds like you are having a power supply problem. Make sure to check your potlet and power chord as well.
Posted on Jul 08, 2008
  • 6 Answers
SOURCE: oven not lighting on Amana model agds902ss
SOUNDS LIKE YOUR ELEMENT CONTACT MODUE IS BAD YOUR AMANA IS MADE BY MAYTAG AND THE PART # FOR THE MODULE IS Y0042123 AS TO WHERE YOU WILL GET ONE TODAY NO IDEA JUST TRY YOUR LOCAL REPAIR DEALERS IS ALL I CAN SUGGEST
Posted on Dec 24, 2008
aborcass
  • 2651 Answers
SOURCE: Amana stove, oven igniter works but oven wont light
although the bake ignitor appears to be glowing, it probably does not glow with the intensity it needs to open the safety valve assy, VERY common problem, go aheadand replace the ignitor, this will correct your issue
Posted on Feb 09, 2010
Testimonial: "100% correct, I ordered the part from on line and it was a very easy fix and the oven is working great. Thank you"
heatman101
  • 43501 Answers
SOURCE: Hello, I have an Amana oven model number ACF3325ab
The ignitor has gone bad.. you will need to replace it.
Here is a tip that I wrote about that problem..
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Heatman101
Posted on Mar 05, 2010
Oven will not heat at all. Stovetop works fine
Phillip, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Oven Wont Heat or Not Working Bake and Broil Element Testing Oven...
Electric Stove Troubleshooting Oven Not Working
Top 6 Reasons Electric Oven Wont Heat Electric Range Troubleshooting
Stove Terminal Block Replacement Frigidaire Electric Range Repair part...
Jun 17, 2016 | Kitchen Ranges
I have a Gas Amana Range. The stove top works fine, but the oven will not heat when I select a temperature or broil. I can hear it making noise, but still no heat!
Hi.
If the oven is not baking or broiling test the temperature probe sensor located inside the oven cavity. To test the sensor read impedance (Ohms) using a multimeter. If the reading is infinity, then the sensor must be replaced.
If sensor is OK, the problem is usually either broiling or baking. In that case check igniter and valve coils, the flame sensor does not fail very often.
Regards.
Ginko
Jul 08, 2011 | Amana Kitchen Ranges
Gas oven won't work on "bake" setting
If the hot surface ignitor is very red in the middle of it when turnig on the oven, it is faulty. Replace it.
Jul 18, 2010 | GE Kitchen Ranges
My Maytag Performa oven and stove top will not turn on (heat up)
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
However....."broil" feature works just fine.
Please help.
Mar 09, 2010 | Maytag 30" Built-In Single Electric Wall...
The oven doesn't turn on in the bake cycle
oven doesn't come in broil but the broil should . the bake should in bake . but if it does work in self clean then your oven is ok and its the clock ( erc) that has failed . some times there is a code in the display stating the problem. but ist loks like a clock failure . **** ..
Dec 23, 2009 | Amana AGR5735QDS Gas Kitchen Range
Bottom filament on bake not working but broil and
FAULTY ELEMENT OR THERMAL SWITCH. HAVE IT CHECKED OUT BY AN ELECTRICIAN.
Sep 07, 2009 | Stoves 720EF Electric Double Oven
Bake and Broil not working
Product manuals
Product manuals are available for most in-stock items.
Order a product manual by calling 1-800-366-PART (1-800-366-7278). Or download a free product manual at ManageMyHome.com.
Aug 01, 2008 | Kenmore 33169 Gas Single Oven
very likely your oven control it does those things without any input from the oven so if it doesnt do what it is supposed to it is likely bad
Aug 01, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Electric Oven not getting hot enough
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
Mar 30, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
Amana ACF7225 Electric Kitchen Range Logo
42 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
