Question about InFocus LP 530 Multimedia Projector
Infocous LP 530 Light comes on then stops
When I turn on the Projector the bulb will turn on for a second and everything sounds fine until it goes out and nothing happens and the light stays green. dose this mean the bulb is burnt out and is so can someone recommend a site that has cheap ones.
    Problem Solver:
  • 5 Answers
This could be one of three issues. the power supply. the firmware or the lamp. thebulbman.com
Posted on Feb 03, 2009
Dear Sirs, I have a BENQ PE8700 projector. I know it's outdated, but it still suits me fine. I've already changed the lamp, and this new one is 1000 hours old. I am recently having a problem:...
If the bulb on this projector is filament less then it may be a bad ballast. If it is that kind of a bulb the ballast is like the starter on a florescent bulb that excites the internal gases for light to be emitted. If it conks out, the bulb stops emitting light even though the cooling fan stays on.
Apr 30, 2017 | BenQ PE8700 Multimedia Projector
Just replace my lamp with a new one, when i start my projector, everything seems to work fine but the lamp doesn't light up. the lamp light flashes green for 30 second, theres a ''motor'' sound in the same...
HI,
You can visibly inspect the lamp to make sure the bulb behind the glass is intact & the round part of the bulb is clear & round. Otherwise if possible return the lamp for exchange. If the same thing happens then the lamp ballast is likely bad. I have many in stock I can diagnose it.
Apr 14, 2011 | Sharp XR-10X Multimedia Projector
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
It quits projecting, the green light goes off and the red light of the bulb goes on. I've disconnected everything and reconnected, turn it on and it works for about two minutes and shuts off projector,...
Have you tried cleaning the fliters on the back of the unit? It's easy to do. Pull them out, and blow them clean. Also, is the projector well ventilated - mine overheats sometimes and shuts off. Otherwise, sounds like he bulb to me.
Oct 25, 2010 | InFocus Office Equipment & Supplies
Infocus LP530 will turn on and work great for 15 minutes then shuts down and the green light turns orange and blinks. The Bulb only has 283 hours on it.
The ambient temperature in the room is to high.
Try lowering the room temperature. If that doesn't work get a small fan and place it near the projector ro provide extra cooling. The projector is running border line on high temperature and just needs a little extra cooling.
Jul 20, 2010 | InFocus LP 530 Multimedia Projector
I replaced the bulb on my InFocus ScreenPlay 5000. The unit turns on the picture is showing a little green while the light warms up. After about a minute, the light turns off but the project remains on as...
there is an issue with the lamp ballast. probably needs to be replaced. send it in to an infocus service center. try av solutions in ny. they're really good.
i think it's www.avsolutionsny.com
Nov 23, 2009 | InFocus ScreenPlay 5000 Multimedia...
Infocus lp 530
Hello, That should absolutely reset the lamp timer.
This is crucial: Press and hold the volume - button, then press the source button (while still holding down the volume - button) for 5 seconds.
Make Sure you hold them both down for 5 Seconds!
I hope this helps you.
Cheers
May 09, 2008 | InFocus LP530V Video Projector 2000 ANSI...
LP 530 Lamp does not power on
Did you cancell the bulb fault status in the main menu ie bulb hours when you changed your bulbs if not try this turn unit on and see if it works it may do.
To reset the lamp hours counter press and hold down the Volume minus button - , then press the source button whilst still holding down the volume button for 5 seconds .
If this works you can then verify that the lamp counter was reset by viewing the counter in the status window in the OSM
hope this helps... Regards Vortash
Feb 27, 2008 | InFocus LP 530 Multimedia Projector
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
InFocus LP 530 Multimedia Projector Logo
336 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
