Question about Dell All-in-One 968+ Wireless Network Card Bundle InkJet Printer
Turns on by itself after turning on PC
Is there a way to prevent the printer from automatically turning on when I power up the PC? I made sure the printer was turned off manually with the power button shutting it down completely (not in any sleep or hibernation mode). However, after powering on the PC (Dell XPS 630I with Vista) the printer was automatically turned on as well. How do I separate the power on for each unit? I want to power on the printer on my own by using the Power button on the printer itself, not have it tied in with the PC. Thanks!
  • 1 more comment
  • ntlives Feb 03, 2009
    Just an extra note to my post:
    I do not use any wireless network card bundle. It's a Dell All-In-One that is connected directly to the PC with a USB cable.
  • ntlives Feb 07, 2009
    Hi Cajun,
    Thanks for your fast reply, but unchecking the printer boxes in msconfig didn't solve the issue. Yes, one cable is USB between the PC and printer, the other is an electrical cord to the wall. There was no related setup option on the printer interface or the software on installed on the PC to not turn on in conjunction with the PC.
    Thanks Cajun, very kind of you:)
  • 741 Answers
You should have two cables. One USB cable for the print data to flow thru to the printer. Then a separate power cable hooked into an outlet from the printer. If you make that set up then the printer will not turn on when the computer turns on. Second option: click on start>run>type msconfig in the box. This will bring up a window, one of the tabs on that window says startup. Look in that tab to see if you can find printer. Then disable it and it will not startup when computer starts.
Don't forget to rate this solution before you log out.
Posted on Feb 03, 2009
  • Randall  Trahan
    Randall Trahan Feb 07, 2009
    Wow..please keep me updated on this one..I've never heard of a PC powering up when it was manually turned off. I'll do some more research though and also discuss it with some of the fellow technicians. See if we can get this one figured out..
How do I fix our Printer?
Tebogo,
This sounds like a power supply problem to me.
I would get in touch with Xerox concessionaires as soon as you can it could be a faulty power supply or one which needs upgrading perhaps. If it's not too old then I'm sure theres a fix.
Good luck.
Apr 30, 2015 | Xerox Phaser 3635MFP/X Multifunction...
DVD player automatically stops and turns itself off, how do I prevent this?
Warning: Laser inside! If you want to open it up and troubleshoot, make sure you don't point toward your eyes.
Check the nylon laser carriage to see if it slides laser from center to outside line. If it sticks, it's probably shutting down from not properly reading a disk.
Aug 03, 2014 | Pioneer DV-343 DVD Player
Hp c4280 photo smart The printer automatically turns on the display says <E>
try to check carriage , if there is nothing , mean formatter is faulty
Mar 26, 2013 | HP Office Equipment & Supplies
My acer 5315 turns itself off occasionally with no warning. looked at the power settings , no problem there
Is it overheating, and then automatically shutting itself off, to prevent the heat from causing damage?
Turn it off. Disconnect the AC power. Remove the battery.
Buy a can of compressed-air, and give your computer a "blow-job" to remove dust from inside it,
because a layer of dust is acting like an insulating blanket, i.e., retaining excess heat.
Apr 01, 2011 | Acer Aspire 5315 Notebook
My hp psc 2170 powers up and then turns itself
make sure the power cord is not loose and there is proper power supply try to connect the power cord in diffrent power unit and check.
Have a nice day and do not forget to rate please...!
Feb 06, 2010 | HP PSC 2175 All-In-One InkJet Printer
My pc turns off itself
Check your cpu heatsink/fan. This sounds like an overheating problem as the cpu has a sensor that will automatically shut down your system to prevent it from frying. Hope this helps.
May 12, 2009 | Computers & Internet
My laptop turns itself of after 8 minutes - every time i turn my laptop on it lasts for about 8 minutes then turns itself off automatically how do i stop this? My HP laptop keeps shutting itself off after...
Sounds like something to do with a power saving feature either from HP itself or from Windows. It could also be that for some reason your computer is overheating, which it than shuts itself off to protect the processor. I would try playing with your power saving features, and cleaning out the fans.
Mar 13, 2009 | Computers & Internet
Xbox turns itself off, were green light should be turns red
check the exhaust fan on the back of the unit! if the fan did'nt work, the unit automatic off to prevent over heating.
May 12, 2008 | Video Game Consoles & Games
Camera turns off
the red symbol is the erasure prevention slider on the tape. check it's not on or push the slider on and off prevention. this should fix the red symbol, you might have to do it a couple of times before it works. not sure what F14 is can't find it in the manual. try the solution here. if it still turns off after a few seconds i have another way to fix the power.
Nov 04, 2007 | Panasonic NV-DS65 Mini DV Digital...
Dell All-in-One 968+ Wireless Network Card Bundle InkJet Printer Logo
80 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
