Question about Sharp AR-168D Black and White Copier
Can't get into test command mode
I have a Sharp AR-168D with the H4-00 error message on. I have found the service manual, and know about the test command mode, but can't get the machine to go into tc mode. I have tried turning it on while holding down the start button, and the clear button, and various combos of buttons, but have had NO success. I have also just keyed in the # *C* sequence repeatedly, but the machine just beeps at me and continues to display the H4-00 message. Can anyone help me with this procedure? My other question is, if I can get the machine to go into test command mode, what is the [10KEY]? On other machines, it is the key that adds 10 copies at a time to the number you want; however, this machine doesn't have one. I'm confused!
  • 4 Answers
To enter the serviceman test command mode, press the keys as
follows:
[#] key → [*] key → [C] key → [*] key
To cancel the test command mode, press the [CA] key.
H4 00 Content Heat roller low temperature detection
Detail The fusing temperature does not reach 185°C
within 27 sec of turning on the power, or the
fusing temperature keeps at 140°C.
Cause Thermistor abnormality
Heater lamp abnormality
Thermostat abnormality
Control PWB abnormality
Check
and
remedy
Use TC 5-02 to check the heater lamp blinking
operation.
When the lamp blinks normally.
Check the thermistor and its harness.
Check the thermistor input circuit on the control
PWB.
When the lamp does not light up.
Check for disconnection of the heater lamp and
the thermostat. Check the interlock switch.
Check the power PWB and the lamp control
circuit on the MCU PWB.
Use TC 14 to clear the self diagnostic display.
Posted on Feb 05, 2009
How do you clear the error message on a AR-168D?
We inject the cartridge int he printer it gives the message on AR-168S
Apr 07, 2011 | Sharp AR-168D Black and White Copier
Hi, Can someone help with resetting error H2-00 on sharp 168d
H2 00
[Content]
Thermistor open
[Detail]
The thermistor is open.
The fusing unit is not installed.
Fusing section connector disconnection
[Check and remedy]
Check the harness and the connector between
the thermistor and the PWB.
follows:
Enter 14 Start to clear the code.
Oct 26, 2009 | Sharp AR-168D Black and White Copier
How do you reset the error message : maintenance requred, call a service technician?
You call a Sharp Service Technician and have them reset it. That code cannot be reset by a user.
Oct 08, 2009 | Sharp AR-168D Black and White Copier
Error H3-00
Hello sir; This error code require a reset procedure ;
press "#", "*", "clear", "*",these four keys by order, then enter 14 press start. then turn power off and back on.
Aug 26, 2009 | Sharp AR-168D Copier
I have a sharp 1r-168d copier. I have replaced the fuser assembly and now have a H2-00 error. I am unable to enter the servicemans mode to clear the self diagnostics
follows:
then enter Sim 14 then hit the start button and restart the machine.
Jun 23, 2009 | Sharp AR-168D Black and White Copier
Sharp AR-168D H2-00 error code
Check
http://www.copier-help.com/copier-help/ecs/sharp/ecsar161.html
Thanks.
Jun 11, 2009 | Sharp AR-168D Black and White Copier
System error H4-00
H4 indicates a heating problem in the fuser. The roller never reached a specific temp. Make sure the fuser is free of any left over paper pieces (maybe from a paper jam). Check to make sure its clean.
Try reseting the the error in service mode.
To enter the test command mode, press the keys as
follows one after the other :
[#] key [*] key [C] key [*] key then enter 14 and press start/copy key. this clear error counter. make sure to restart copier afterwards.
May 19, 2009 | Sharp AR-168S Copier
Error on Sharp AR-168D Copier
The manual says to turn off and unplug the machine and wait for 10 seconds. Then plug it back in and turn it on. If this doesn't get rid of the problem contact your sharp dealer/service man.
Jan 12, 2009 | Sharp AR-168D Copier
Service mode
Hello:
All I have access to is the Toshiba Version of your machine but I think maintenance mode is the same.
This is the excerpt from the relative info in the service manual.
Example:
Basically you press # * c * ( to get into maint. mode
Press 20 Start 01 start (then the maintenance counter will clear)
I hope you can figure it out
The drum and dev counts are below
To enter the serviceman test command mode, press the keys as follows:
[10KEY]:(number pad) Entry of MAIN CODE/SUB CODE
Selection of an item
Setup of an adjustment value in case of test commands for adjustment
[/]: Selection of MAIN CODE/SUB CODE
[OK (ENTER)/START]: Settlement
<In case of test commands for print>
[OK (ENTER)]: Settlement (Without print)
[START]: Settlement/Print
[C]: (Interrupting operation check) Returns to the upper hierarchy.
In case of test command of operation check, terminates the operations.
[CA]: Exits from the test command mode.
For a test command of adjustment, the display returns to the initial display (00-00).
20 01 Maintenance counter clear (M-CNT CLR.)
24 06 Developer counter clear (DVLP CLR.)
24 07 Drum counter clear (DRUM CLR.)
Mar 12, 2008 | Sharp AR-168D Copier
Sharp AR-168D Black and White Copier Logo
245 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
