Question about Dual L8SW Subwoofer
The power fuse blows as soon as the unit is plugged in
Fuse blows even when power switch is in off position. Prior to the fuse blowing, the unit emitted a loud hum without the stereo unit being turned on. The unit is about a year and a half old and no previous problems.
  • 4,234 Answers
There is a problem with the amplifier within the sub. Many of these units never completely turn off. They are often set to automatically startup when a signal is detected. This may be the case here. The loud hum as a defect in the output amp section. At this point you probably have a blown amp section. The "protection" for this is to cause a dead short that will open up the fuse. This unit will require service. It is unlikely that any service info is availabel to the general public either.
The fix could be simple, but without seeing the unit, I can not state that for sure.
Keep us posted.
Dan
Posted on Feb 03, 2009
Unit will crank and start but as soon as you let off key switch to the run position it dies it also blows the main 15 amp fuse
You have a short to ground on that circuit . Find a wiring diagram an see what all the main 15 amp. fuse powers up . Disconnect all components an isolate the circuits till the fuse stops blowing . Could help but you don't say what make , model an year vehicle you have.
May 25, 2016 | Cars & Trucks
Fuse Blows
does the unit works at all?
Dec 11, 2007 | Lowrance Iway 500c GPS Receiver
KLH ASW8 Powered subwoofer keeps blowing 3A-250V fuses
The transistors at the output stage of the sub amplifier circuit might be shorted so each time you power on, the circuit draws a very high amount of current which causes the fuse to blow. It's definitely a problem with the circuit so using a higher current rated fuse would probably just result in damaging the amp even more. You should ask a qualified electronics technician to take a look at it. I hope you can fix it.
Oct 17, 2012 | KLH ASW8100 Subwoofer
The fridge is blowing the 12 volt fuse as soon as I power up the motor home, The fridge is turned off and it still blows the fuse, I tried to undo the 2 wires that go to the 12 volt block on the fridge and...
Unplug the wire located at terminal J4 (12v positive) on the control board, and see if you are still popping fuses. If so, then the fault lies between the wire you just removed and the fuse that keeps blowing.
If the fuse holds, and blows when you plug the wire back onto J4 terminal, then unplug the wire(s) at J2. These go to your door heater (used in humid conditions to remove condensation), as well as the interior light. The switch for the door heater is located on front panel, or is at the top edge of the freezer compartment with door open. It is not unusual for this switch to have issues since it gets chilled and moisture condenses on it. If unplugging the wires at J2 allows the fuse to hold, you probably got a shorted heater or bad heater switch. But, pull the lens off the interior light, and check the contacts there as well.
If the fuse still blows with J2 removed, then unplug the connector in the top left corner of the control board. This goes to the control panel on the inside of the fridge. If the fuse blows, replace the control board. If the fuse holds, the replace the control panel.
Jul 13, 2010 | Dometic RM2652 Refrigerator
The ac cont fuse keeps blowing on 97 lumina. If I put another fuse in it will blow as soon as the compressor turns on. If I unplug the power to the clutch and plug the power back in it will run for...
If you can unplug the compressor and put the switch in run forever and it doesnt blow then your compressor has a short in it and the car wash had nothing to do with this unless you can find water in the fuse block or relay block
Sep 02, 2009 | 1997 Chevrolet Lumina
No power!
There's an internal fuse - about 20 Amps. It usually blows when the magnetron dies. Unplug the unit from the wall and access the internals. You should plainly see the fuse holder - remove and check the fuse. Spares are available at any ACE hardware store. If the unit is more than 5 years old, I wouldn't mess with it.
May 24, 2009 | LG LRM1260SW Microwave Oven
I have no brake lights, no hazzard lights, but the signal lights work. Wiring has no breaks, but the fuse blows as soon as the brake or hazzard lights are used.
there is a short somewhere-try disconnecting all components on that circuit,put new fuse and try using one,if the fuse still blows,problem is in wiring or switch unit,if not,plug one component in and a time until the fuse blow,replace component
accordingly.make sure there is no slightly shaved wire touching the chassis,this will show when all if d/c'ed and fuse still blows,good luck
Aug 12, 2008 | Chevrolet C3500 Cars & Trucks
Fuse Keeps Blowing In Car Plug
try using a 3a or high fuse
You can buy a new car adapter by clicking on the hyperlink:
buy replacement car adapter power charger cord for Durabrand DUAL 7" dvd player
Feb 09, 2008 | Durabrand Portable DVD
Dual L8SW Subwoofer Logo
343 people viewed this question
Top Dual Audio Players & Recorders Experts
Jerry Naidoo
Michial Gueffroy
Are you a Dual Audio Player and Recorder Expert? Answer questions, earn points and help others
