Question about GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Microwave will not heat
I have a GE Profile Sensor Microwave which has stop heating regardless of setting. All other functions on the unit are working normally. All deplays are normal. Just won't heat.
Model # JE 1860SB 002 Manufacture date was Dec 2001.
What part will I need to replace? Thanks for any advise.
  • 4 more comments
  • Anonymous Feb 25, 2009
    Timer works and counts down, but won't turn on or heat. Convection mode won't work either. Checked fuse and door switches, both good. When it first started doing it, if you hit it it would come on and work. Any Ideas?
  • abandlar Feb 25, 2009
    Ideas?
  • Anonymous Mar 08, 2009
    No matter what I want ti heat it will not heat up?
  • cynthia_zoll Mar 13, 2009
    I have the ge spacesaver model # jvm1650sb004 serial # rf 902580 B. It was working great until one day my kids were going to pop popcorn and it wouldnt heat. Everything else works .It comes on , timer works everything but it will not heat. Do you have any ideas of what it can be and how to fix it? I really love it and dont want to have to replace it.
  • Thomas Malailua
    Thomas Malailua May 11, 2010
    dose it make a loud hum when it should be cooking.or dose it count down on the timer put no noise?
  • Anonymous Mar 17, 2014
    replacing a GE microwave JE1640GA 002
    President:
  • 563 Answers
Unfortunately, there is no way to tell which part the microwave needs without opening it up for examination. There are a few parts that, if defective, would prevent the oven from heating.
  • a high voltage transformer which passes energy to the magnetron
  • a magnetron which converts high-voltage electric energy to microwave radiation
  • a magnetron control circuit (usually with a microcontroller)
This is NOT a repair that you would want to attempt yourself. The labor for the repair would cost a minimum of $50 and shouldn't exceed $100. You'll also have to pay for the necessary part if it's still available from the manufacture or their parts distributor.
Posted on Feb 04, 2009
Ge microwave stopped heating food
The problem is in the magnetron/inverter board if less than 7 years.
Apr 09, 2012 | GE Profile Spacemaker Over-the-Range...
My ge Profile microwave just stopped heating food/liquids. All else works on panel; just not heating. Why?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
45xs
May 12, 2010 | GE JE2160 Microwave Oven
Microwave not heating
OK, if everything, including the fan, is working, this will confirm Magnetron failuer. you cannot reset the function of a failed Magnetron heating unit. replace this failed device asap if possible.
Jun 05, 2009 | GE Microwave Ovens
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
Ge jvm1870 it won't heat anything, all other items work
Ok, if this unit has stopped heating, this will confirm a major fault within the Magnetron. this device is responsible for the heating affect and, you will need to replace this damaged part in order to restore proper heating functions in you microwave oven.
Mar 03, 2009 | GE JVM1870 Microwave Oven
Everything works except heat
Sounds like you've had a failure in the microwave portion of the unit.
Microwave not heating problems when the timer/controller board appears to function properly, are related to the following components -
1) Diode
2) Capacitor
3) Transformer
4) Magnetron
Jan 24, 2009 | GE JE1540 Microwave Oven
Ge profile microwave doesn't seem to be heating food real hot. during the last bag of popcorn we tried to pop it never even started popping it, and the microwave stopped and said on the screen...
On GE models, "SENSOR ERROR" appears on the display when:
  • Using the sensor feature, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
  • Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Otherwise, your sensor may have failed.
Nov 22, 2008 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
2,368 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
