Samsung Tocco F480 - Pay Monthly Cellular Phone Logo
Posted on Feb 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot use Vibration alert
I cant sem to get my Vibration function to work on my Samsung F480. i have had it for a week and its set to vibration and melogy but doesnt vibrate...can some one hwlp me .
Rodolfo Atun
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 158 Answers
  • Posted on Feb 03, 2009
Rodolfo Atun
Expert
Level 2:
Cheetah:
Answers
158
Questions
Helped
37882
Points
430
Sir...
open your phone, just follow the instructions...
but pls be careful... it might kill your phone..
just follow the link and watch the video on http://www.wonderhowto.com/search/dismantle-f480/
clean the contacts between the ******** and the board..
tnx
tip
CUSTOMIZING YOUR PHONE SOUNDS
the samsung sync is a pretty good phone with many options of customization available. problem is, most are hidden. heres how to access them:
1. open phone, and push the side key under the memory card slot. [alternatively, just get to the PROFILE option. in that case, skip 2]
2. scroll over to the 'PROFILE' setting
3. highlight the 'NORMAL' setting, and push the 'OPTIONS' key.
4. go to 'EDIT'. push 'CALL ALERT' and you get a wealth of options.
i will map them out for you too lazy to look through everything:
1.    INCOMING CALL
Call Alert Type:
                [Melody]
                [Increasing Melody]
                [Vibration]
                [Vibration Then Melody]
                [Vibration & Melody]
                [Vibration And Increasing Melody]
                [Mute]
Voice Call Ringtone
                [Takes you to My Stuff, where you can choose a .mmf file to use.]
Ringtone Volume
                [1-7]
Auto Reply
                [Activation OFF/ON]
                [IF ON, THEN REPLY TO SEND]
2.   New Messages
Message Alert Type
                [Melody]
                [Vibtarion]
                [Mute]
Message Alert Tone
                [OPTIONS:
                   [1. USE EFFECT TONE]
                   [2. USE MY ALERT TONE]
Message Alert Repetition
                [Once]
                [Periodic]
Alert Tone Volume
                [1-7]
3. PHONE SOUNDS
Keypad Tone
                [Beep]
                [Clean]
                [Mute]
Power On Type
                [Melody]
                [Vibration]
                [Mute]
Power Off Type
                [Melody]
                [Vibration]
                [Mute]
Folder Open/Close Tone
                [Melody 1]
                [Melody 2]
                [Melody 3]
                [Mute]
Volume, Phone Sounds
                [1-7]
if i missed anything, leave me a message, or email me:  mannyftw [AT] aim [DOT] com
My Samsung Galaxy Light won't vibrate anymore. How can I fix it or get it to work again. Thank you
Setup the Vibration
This option allows you to set your device to vibrate and ring.
1. From the main Settings page, tap My device tab ?
Sound.
2. Tap Vibrations.
3. Select a vibration pattern and tap OK.
- or -
Tap Create to then use an on-screen touch circle to
create your own custom vibration pattern. Tap Save to
store the new vibration pattern.
Sound Settings
From this menu you can control the sounds on the phone as
well as configure the display settings.
 From the Home screen, press and then tap
Settings ? (My device tab) ? Sound.
The following options display:
Silent mode via Device Options Screen
Silent mode is convenient when you wish to stop the phone
from making noise, in a theater for example. In Silent Mode
the speaker is muted and the phone only vibrates to notify
you of incoming calls, or other functions that normally have a
defined tone or sound as an alert.
1. From the Home screen, press and hold
(Power/End) until the Device options screen displays.
2. Tap either Mute, Vibrate, or Sound from the Device
options screen to activate or deactivate these features
(the current mode displays).
You can download the User manual from the site below
https://support.t-mobile.com/docs/DOC-9140
I have samsung e840 it have no vibrate no alert incoming call
Hi, did you set the vibrate alert on?.
If you did set it it will give you a vibrating alert.But if not that means you will have to go through where the ringing to setting alert and set the vibrate alert on.
After setting it and no vibration yet,that mean you will have to replace the vibration inside the phone.
Would advice if no experience with phones, contact an expert technician around you.
Take care.
Jun 15, 2010 • Cell Phones
2helpful
When my samsung impression is on vibrate, and i get a text message it vibrates at least 10 times. how can i get it to only vibrate once?
1)tap on settings
2)next tap sound profile
3)next tap normal
4)then tap on the upper right side (the dialog box that says call) with the drop down arrow
5)choose message
6) then you can set it from there, you can change the setting of your msg alert type, alert tone, alert repetition, alert tone vol, and vibration pattern.
Cant get the phone to vibrate on a incoming call
Lorraine,Go to Settings->Sound->In Coming->Alert type. Select Melody and Vibration. Or similar settings. But it has to be connected to your In Coming Calls.
1helpful
2answers
Help
press dial, then press and hold the # (hash) key. This will select silent. Repeat to undo.
Vibration
Go to "settings"
"Phone Profiles"
For each profile, you can set the Call Alert Vibration level and save it.
Hope that helps.
Sms text tone
Make sure you change your message alert type to Melody or Melody and Vibration before you get to pick your text alert tones or songs. If I remember correctly, my phone was set to only "Vibration" when i first got it.
2helpful
2answers
Samsung U900
I came across your post when investigating exactly the same problem. In my case I did not realise that vibration was not enabled until the profile Call Alert Type was set to 'Vibration and melody' (mine was set to Melody and I didn't notice the other options). HTH.
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
