Question about RCA HD52W59 HDTV Projection Television
Top and bottom of picture is bowed.Images are doubled and letters
Rca hd52w59
  • 1 more comment
  • mikehillyer Feb 03, 2009
    where do i find this fuse?
    no it seems to be gone or I remember when I 1st bought the tv it went through an auto convergence, but I cant get to that either.
  • jason May 11, 2010
    have you checked fl231( fuse )
  • 905 Answers
One more question , could or can you access the convergence menu ?
the fuse will be next to the flyback transformer ( high voltage ) and ill look tan in color( 3 of them )
also the flyback pins have to be resoldered also
Posted on Feb 03, 2009
  • jason Feb 04, 2009
    if you cannot get to the auto convergence in the menu , then for sure that fuse is the problem and the resoldering on the flyback pins
I have Rca 52 inch that when I turned it on it was bowed at the top and the bottom, the images are double and the color is off.
sems like to me you have a convergences problem chedk conveg board and convergence chips and risistor or try replacing it. or try auto convergence. useally when when they are bowed at the top and bottom its the conver board..i hope this will help
May 28, 2012 | RCA Televison & Video
Picture looks like it is warped at the bottom and top of the picture. Have picture, no problem there, just not a centered picture anymore. Looks like the top of a half moon on the top and botom.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some images of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Or goto the site www.TvRepairKits.com for the parts and instructions on how to fix it yourself.
Dec 28, 2010 | RCA HD52W59 HDTV Projection Television
Screen is bowed on top and bottom. What could be our problem? Picture, letters & words blurry.
go to hatch screen adjust all colrs to make white color boxes , also adjusts linear lines
Dec 31, 2009 | RCA Televison & Video
Problem with my rca projection television
my RCA R52WH74 HDTV IS STARTING TO LOOK BLURRY. ALSOMY SCREEN LOOKS LIKE IT STRETCHING MY TV PROGRAMS....... CAN U GIVE ME A SOLUTION
Mar 16, 2009 | RCA HD52W59 HDTV Projection Television
RCA model HD 52W59 rear projection TV
Appreciate the direct "Ask Me" and your understanding. Again our apologies for any inconvenience due to the disconnection.
With your indulgence, to your concern:
  • Ifno amount of adjustment could align/merge the images, then it would besafe to assume that the convergence amplifiers are faulty.Additionally, the bowed effect strengthens the likelihood of faultyconvergence board.
  • This is a known common repair, so much sothat most owners are performing DIYs (do-it-yourself) for those unitsno longer under warranty. Should you consider the DIY, then pls findbelow specifics which may be helpful otherwise pls bear in mind that ifthe unit is still under warranty, a DIY could and would void saidwarranty. Your choice then of course, warranty repair or DIY.
To the actual repair:
  • Boardreplacement - by far the fastest, the easiest. As the term/nameimplies, identify/remove the erring board, seek/order a replacement,swap, align and the jobs is done.
  • Component level - thecomponents within the board are tested using a DVM or a VOM, thedefective parts identified, order a repair kit, desolder the defectivecomponents, replace them with the new components from the kit, cleanthe solder work on the underside of the PCB (printed circuit board),reassemble, align and the work is completed.
Should you consider board replacement:
  • Initially, pls determine the suffix (if there is) of your model HD52W59, something like YX22;
  • Pls goto http://www.tritronicsinc.com/;
  • pls click on the "CATALOG" button top near left;
  • in the "search for:", pls select Model Number;
  • in the next (right) box, enter HD52W59 plus the YX?? and click on the Search button;
  • on the next page, click on the model number on the left to confirm;
  • in the "Enter Description..." box, pls type "conv" less the quotes and click on Submit button;
  • you would be interested with the Convergence Amp board;
  • Alternately,you can call Tritronics for a 24 hr order. Pls get numbers to theiroffice nearest you fromhttp://www.tritronicsinc.com/storefrontB2CWEB/jsp/b2ccontacts.jsp.
Should you consider component level repair:
  • Plscontact Slinteriors @ http://servicemanuals.vstore.ca/. They sell arepair kit that includes the 2 STK 392-??? ICs, resistors and picofuses.
  • Additionally or more importantly, they supply them as a completekit PLUS an illustrated instruction sheet detailing the repairprocedures.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 16, 2008 | RCA HD52W59 HDTV Projection Television
Have a RCA model HD 52 W59 rear projection tv
Hi again,
Sorry, but for some reason the session was disconnected. Our apologies for any inconvenience.
If you would close the session at your end, you would be presented with options. Hopefully, the system would allow us to continue through the transcript although not real time.
I am hoping for your kind understanding and that we can somehow continue to resolve your concern.
Convergence Problem RCA HD52W59
you need to test all cables then make shure it is not your tv.
Jun 20, 2008 | RCA HD52W59 HDTV Projection Television
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
HD52W59 bowed picture
Check your screen. I have the same problem with mine. If the screen has a ripple in it, it could give the same effect.
Dec 15, 2007 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
130 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
