Question about Saniflo 005 Toilet Tank White
Replacing Sanicompact toilet seat
Hi, I bought a Sanicompact off a builder not knowing that you they were sold with toilet seats included. He didn't include one and I didn't ask at the time. I've asked since, but he hasn't got back to me and don't think he ever is going to.
I have looked and asked everywhere to find a toilet seat for the Sanicompact and would appreciate any help in tracking one down. I live in the UK, but would be willing to import one if that was the only solution.
  • bigslimaba May 11, 2010
    They take a normal toilet seat.....can you give more detail?
  • 34 Answers
I have asked around they take a normal seat on most us models
Posted on Feb 05, 2009
    New Friend:
Hi, I have a SaniCompact Serial #08031, 20 years old now and still
working. Canada: call 519-883-5874 and US call 716-754-4383. or call
1-800-36 Flush
Posted on Nov 28, 2012
    Scholar:
  • Saniflo Expert
  • 115 Answers
There are two types of Sanicompacts. The Sanicompact 48 (round front toilet) and the Sanicompact Elite (square front toilet) visit this link to purchase it in the UK. http://www.saniflo.co.uk/
Posted on Jul 27, 2010
How do I wire a 2005 sanicompact?
Use the power cable that came attached to the motor to wire to a fused spur.
Jan 10, 2015 | Saniflo SaniCompact-48 SaniCompact One...
Water spraying out of holes in back of toilet
Check the holes rubber ring or change the whole holes
Oct 16, 2013 | Saniflo SaniCompact-48 SaniCompact One...
I have a sanicompact 43, if the water pressure is low will this b the reason for flushing problems , please ?
Its a Cisternless ceramic toilet with built-in Macerator Pump.So the water pressure should not make much of a difference as most of the job is done by the pump
Regards.
plz. Don't forget to rate my suggestion.
Jul 13, 2011 | Elite Saniflo SaniCompact- SaniCompact One...
Sanicompact motor operates continuously but bowl doesn't clear. Have emptied bowl manually and poured Saniflo cleaner in.
This problem occurs when the flush button is damp after cleaning the whole toilet with a shower. Solution: Wait till it dries up 2) if you have installed a main switch put it on and at the same time press the flush button.
Dec 26, 2010 | Elite Saniflo SaniCompact- SaniCompact One...
Involuntary flushing operation occurs every 10 minutes
hi,
i was having same problem with my sanicompact48,it was flushing continuously after few minutes.i opened and cleaned every thing still it was the same thing.and i noticed irreguliar flushing due to SOLONOID VALVE.just replaced and works fine.yo can order by phone # 1 800 571 8191 to "saniflow".tale them your problem and your toilet model.
good luck
garry
Sep 06, 2010 | Elite Saniflo SaniCompact- SaniCompact One...
The big black washer between the tank and bottom is deteriorating also the black washers on the bolts that hold the tank to the bottom are coming apart and the tank is leaking
Any hardware stores where plumbing supply is sold including lowes and home depot sell toilet seal kits including toilet to tank seals as well as toilet rebuild kits. Ask for a toilet to tank seal and washers for the bolts which might come with the large seal(check)
1. Close toilet water valve
2. Drain tank or sop with a towel and squeeze into tub until toilet is empty or bail water out with a cup.
3. Remove two tank bolts
4. clean area where old seals were
5. put tank seal on bowl and set tank lining it on top of seal.
6. Install tank bolts with new seals and tighten evenly
7. Don't over tighten or tank will crack. You probably can tighten until tank and toilet touch evenly on both sides.
8. Fill and check for leaks.
Aug 19, 2010 | Jacuzzi Home
At the moment we have a saniflo plus but the whole system has blocked but the pipes are clear what should we do next
If the toilet doesn't flush but the rest of the plumbing works fine you may need to buy a closet auger to clear the toilet stoppage, they cost around $20 and do wonders much better then plungers
Jun 25, 2010 | Elite Saniflo SaniCompact- SaniCompact One...
What size toilet seat fits a sanicompact elite?
The manual http://www.saniflo.co.uk/pdf/install/Sanicompact.pdf shows that the lid and seat is of an elongated design and I think that you would need to get a direct replacement instead of trying to fit a standard seat/lid combo as a replacement. A normal seat/lid may line up with the fixing holes, but would probably not be the same elongated design.
You should be able to get a direct replacement from your plumbers merchant (may need to order), or from Saniflo directly http://www.saniflo.co.uk/
If this helps please leave feedback, if not let me know and I'll try and help some more!
Jan 31, 2010 | Elite Saniflo SaniCompact- SaniCompact One...
Saniflo 005 Toilet Tank White Logo
2,503 people viewed this question
Top Saniflo Home Experts
Donni Steen
Paul Carew
Are you a Saniflo Home Expert? Answer questions, earn points and help others
