Question about iRiver H10 MP3 Player
Iriver H10 - DB Open Error
I have had my iriver for about 4 years now and have never had any problems with it until now. I can use the radio and everything else seems to be fine, but when i click on music to try and access anything i have downloaded onto my iriver, i get the following message 'DB Open Error. Connect iriver plus And DB Update'. I have no idea what this means. I have tried connecting it to my iriver software and completing a sync but its not working. Any ideas??
  • salstokes Feb 11, 2009
    I also have the same problem! How do I fix this?
    Problem Solver:
  • 18 Answers
One idea...
connect player to your pc using the ums trick
What is the UMS trick on IRiver H10?http://www.zolved.com/synapse/view_content/5942/What_is_the_UMS_trick_on_IRiver_H10
This article tells you how to transfer music to your player The UMS trick is a great thing to know how to do. With it, you can transfer music, or treat your H10 as a harddrive to put anything you want on.
The UMS trick will also allow you to use your H10 with virtually any OS.
For 5/6 GB MTP Models
  • Make sure your H10 is turned off and disconnected from the computer.
  • Take out the battery, wait a second, and put the battery back in.
  • Turn on the hold switch (so that you don't accidentally turn the H10 on all the way).
  • Plug the H10 into your computer.
  • Turn on the H10 while holding the "O" button.
  • You will see the message "UMS Mode" if you have done everything correctly. You can now let go of the "O" button.
For 20 GB MTP Models
  • Poke the "reset" button with a paperclip.
  • You will see the message "Emergency Connection" if you have done everything correctly. You can now let go of the "O" button.
For UMS Models UMS models do not need this trick because they are
always in UMS mode!
---download and run the free playlist maker called easyh10. It will read the music files on your h10, rebuild a playlist and save it to your player.
Posted on Apr 03, 2009
I reformatted my iriver player, and now it shows system error. what should i do?
Sir/ madam
good day.
me i ask regarding my iriver H10
the problem is system files missing
how to restore the system files connect H10 to iriver plus?
thank u?
Feb 19, 2010 | iRiver H10 MP3 Player
Tip
Apple Compatability
iriver:
Hello! This is iriver supporter. Please enter your question, then simply click 'Go' button or press Enter key.
Maxicube:
[H10 H100 H300] apple software
iriver:
Are you asking me that "(Harddisk Player)You want Macintosh compatibility information"?
Maxicube:
Yes.
iriver:
H10 & E10 Players
H10 Players are only compatible with Windows XP. They cannot be used on Windows 98SE / Me / 2000 or Macintosh computers.
H100 Series, H300 Series and iGP players
The H100 Series, H300 Series and iGP players are compatible with Mac OS versions 9.2.2 and 10.2 or higher. When attached, the player will display as an icon on the desktop. Open the icon to add files to the player. Note, the DB functions described in the manual are not available for Mac OS at this time, as the index cannot be created with Mac OS. This means that Album, Artist, Genre, and Title searching will not be available.
For The Iriver Bot Goto http://www.iriveramerica.com/support/contact.aspx
on Feb 10, 2008 | iRiver E10 Digital Media Player
My iRiver H10 scroll doesn't work
for tips on fixing the H10 with problems -- try this website.
From what i have seen, your scrollbar is in need of replacement. Need to buy a cheap as-is unit from ebay, get tools to open your H10, and replace the defective part.
Apr 01, 2009 | iRiver H10 MP3 Player
IRiver H10 - System files missing
please, my new iriver h10 is not open. it will say "System files missing"
Aug 03, 2008 | iRiver H10 MP3 Player
Iriver h10
This is straight out of p. 67 of the user's manaul, available on iRiver website (it may not work if the computer does not recognize the device):
Initializing H10
67
Additional information
Firmware upgrade
66
What is firmware ?
It is the operating system that works in the H10.
iriver provides you with the latest and best features through Firmware upgrade.
You can choose manual or automatic upgrade function.
For information on automatic upgrade, refer to the iriver plus instruction manual.
Manual firmware upgrade
Select [Option - Firmware Upgrade] from the menu in iriver plus.
Do not disconnect H10 during firmware upgrade.
Internet must be connected for the "Firmware Update" function.
Change to "Player must be connected to the PC for Firmware Upgrade function.
Note
Please initialize H10 player in the following cases.
All music, pictures, text, and data will be erased from the player during this initialization.
- if there appears to be corruption on the internal hard drive.
- if an error message displays and the player doesn't boot properly.
1 Connect the player and PC using the cable supplied with the player.
Open iriver plus.
Select [Option-Portable Device Initialization]. 2
Click [Start] to begin initializing.
Initializing H10
A
A
B
B
May 30, 2008 | iRiver H10 MP3 Player
H10
Male sure you have the Vista drivers/updated software from iRiver website
May 24, 2008 | iRiver H10 MP3 Player
Iriver Troubles
Delete the playlist and try to re-add using windows Media Player - make sure EVERY song in the playlist is in the right format
Mar 31, 2008 | iRiver H10 MP3 Player
System initializing
Initializing H10
67
Firmware upgrade
66
What is firmware ?
Note
Open iriver plus.
Initializing H10
Dec 18, 2007 | iRiver H10 MP3 Player
Opening for repair the iriver h10 20gb
I am having the same problem. Resetting it doesn't work and now it's locked all the time and I can't do anything with it! There are no suggestions on the iriver website. Have you got any other solutions to this problem?
Dec 07, 2007 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
1,583 people viewed this question
Top iRiver Audio Players & Recorders Experts
aliasger yq
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
