Question about Dell XPS™ 600 PC Desktop
Windows XP won't boot with "CREATIVE SOLUTIONS" PC
I have a "Creative" built Windows XP Pro platform with 256 System Memory, 13 GB HD; CD ROM, 3.5" floppy drive.
When booting it gets stuck on the following:
Intel PC 133 Pentium® processor, 733MHz
128 MB PC133 RAM
It will sit awhile then "sees" my peripherals (mouse, Keyboard etc) and
Then the screen clear and goes to "Drive Not Ready-System halted"
It boots OK at times but I can’t count on it.
I got this machine 2nd hand so no software. It was surplus property of the State of California and built "custom" to their specs I presume, but nothing exotic, not even a large hard drive, just 13 gigs.
Any ideas?
Hardy
  • 4 more comments
  • hardco58 Feb 04, 2009
    I'm not sure what an optical drive is. I don't have anything on this machine driven by optics as far as I know. I suspect "gymowner" is right with his analysis in that XP Pro is too much of a memory hog to run this machine right.
    I have another machine, a Compaq Deskpro. Also from the Stone Age, but I'm from that era too. it has a Pentium III processor, 598 MHz, 256 MB RAM. It runs but I often get low memory warnings. It's slow but I never thought it was because it too has too little RAM. Figured it was the Net that was the cause.
    Sounds like I need more memory for both my machines. How can I tell what's what with memory, short of taking my old ones into the store like Frye's. They advertise "2GB DDR2 PC4200 Memory, Speed 533 MHz single module, for $19.99. Am I getting close?
    If I do have something "optical" in my "Creative" machine, it's probably my eyeglasses I can't find since I had that case open last.
    Hardy C.
    AntiochPC: I just reread your note to me and it looks like you're telling me that these are the minimum to run XP Pro.
    1.6 GHz CPU, 256MB Ram, and DirectX 9 hardware-accelerated GPU
    Looks like adding RAM alone isns't gonna do it for me, I need a new processor and that probably means a new motherboard and that puts it out of range of my budget. I don't know where to get a copy of bargain basement Win 98 and am likely stuck with a door stop with my Creative machine and a slow Deskpro. If the Creative comes up once in awhile it'll be enough to continue to use it as a backup for my files and the other one, well, I'm kinda slow myself and don't have much of a need for blazing speed, as long as it keeps running at ANY speed.
    Thanks to both of you for your fast response. Now I know.
    Hardy C.
    * Unplug the optical drive from the motherboard and see if it boots.
    No it didn't. Drive not ready came on without the usual text that shows 128 Ram.
    If not, unplug the hard drive and plug back in the optical drive. It will boot to an operating system not found error, but see if it pauses for a long time on the processor/ram screen. If it goes normal, then you know the problem is either the hard drive or the hard drive controller.
    * It came back with the last line of 128 Ram.
    If and when that Creative machine should ever boot again, would it work to increase the virtual/emulation memory, which I've done to my Net connected Compaq? That was really done by MaCafee but I'm familiar with how to do so.Can't try it until/unless it boots though.
    I wonder if I should face Mecca, Jerusalem, or St.Peters to petition for a miracle......
    Hardy
  • Kevin Shafer
    Kevin Shafer May 11, 2010
    Optical drive = CD drive (ran by optics)
    I've succesfully ran windows xp on a 233 MHZ machine with 128 MB Ram. Not very efficiently, mind you, but the specs you have will run XP.
    Just to note what fry's is advertising in the way of RAM won't work on your machine. Your machine takes an older type of memory module that you probably won't be able to find in a retail store anywhere. What you need is 128 or 256 MB SDRAM PC 133 memory chips, but I can't guarantee the 256 will be able to be seen by your motherboard.
    That being said, that does not address your original problem. The reason your machine "gets stuck" on the cpu/memory display is because it is having problems reading either the optical (CD drive) or the hard drive. It could be a fautly drive as I outlined earlier or even perhaps a faulty motherboard.
    Again, windows XP will run on that system. But that is not the issue you are faced with at the moment.
  • Kevin Shafer
    bad hard drive or cd drive. Unplug the optical drive from the motherboard and see if it boots. If not, unplug the hard drive and plug back in the optical drive. It will boot to an operating system not found error, but see if it pauses for a long time on the processor/ram screen. If it goes normal, then you know the problem is either the hard drive or the hard drive controller. Let me know if either of these tests work for you. Thanks.
    President:
  • Dell Master
  • 1,314 Answers
So you need to replace your CD drive and you need to install an operating system on the hard drive. I've got to run now but any other questions, please feel free to ask and I'll come back in a few hours :c)
Posted on Feb 04, 2009
  • 679 Answers
That machine is too underpowared to run xp pro.
Windows XP Media Center Edition
you may get it to run but it is going to be dead slow. you will be waiting forever to load any apps with a processor under a gig, and less than 512 mhz of memory, it may work for emulation, but that's even questionable. I don't want to aggrvate you but that config is a decade old. Vista for instance needs at least 2 gigs of ram and a dualcore to run right. sorry bud, if you are dead set on it, the only thing you coula do is juice up the memory, to whatever the board is rated to take, or I would run windows 98, peace
Posted on Feb 03, 2009
  • George Bill
    George Bill Feb 04, 2009
    No i would guess yo are looking at pc133 memory, if you can pull up a schematic of the motherboard, "google it" it will give you the specs. Look on the board itself for a model number. You aren't dealing with DDR ram it's either pc100 or pc133
My computer won't boot up with windows xp service pack 3
This is a strong indicator the hard drive has failed, have it tested before replacement.
Jul 10, 2012 | Toshiba Tecra Computers & Internet
Gateway mx3222b laptop ram upgrade problem
your computer does not support 1GB memory sticks. The max memory for that system is 1GB which would be 2 sticks configured as 512MB
see below for the specs (i bold, italics and underlined the main part)
Processor Intel® Celeron® M Processor 370
1 MB L2 Cache | 1.50 GHz | 400 MHz FSB Display Screen 14-inch Widescreen Ultrabright™ WXGA TFT Chipset Via VN800 Memory 256 MB DDR2 (1 × 256 MB) SODIMM
Total slots: 1 DDR2 slot | Available slots: 0 DDR2 slots
Expandable to 1 GB Video S3 Graphics UniChrome™ Pro IGP
Up to 64 MB shared VRAM Audio AC'97 2.3 Compliant Hard drive 40-GB 4200 RPM hard drive Optical drive DVD +/- RW Multi-Format Double Layer
Write maximum: 8X DVD+/-R, 6X DVD-RW, 8X DVD+RW, 2X DVD-R DL, 2.4X DVD+R DL, 24X CD-R and 16X CD-RW discs
Read maximum: 24X CD-R/RW/ROM, 8X DVD-R/RW/ROM, 4X DVD+/-R DL, RAM discs Media Reader 4-in-1 Digital Media Manager
Secure Digital™, Memory Stick®, Memory Stick-Pro®, and MMC™ Modem 56K ITU V.92 ready fax/modem Network 10/100 Mbps built-in Ethernet
802.11g integrated wireless (up to 54 Mbps) Interfaces
  • 2 - USB 2.0 ports
  • 1 - VGA external connector
  • 1 - RJ11 (modem)
  • 1 - RJ45 (Ethernet LAN)
  • Microphone jack
  • Headphone jAck
Pointing device Touchpad with vertical scroll zone PCMCIA 1 - Type I or Type II; Card Bus Battery 6-cell Lithium-ion Dimensions 1.1 to 1.24-inches (H) × 13-inches (W) × 9.7-inches (D)
28 to 32 mm (H) × 330 mm (W) × 246 mm (D) Weight 5.01 pounds
  • 2 - USB 2.0 ports
  • 1 - RJ11 (modem)
  • Microphone jack
  • Headphone jAck
  • 2 - USB 2.0 ports
  • 1 - RJ11 (modem)
  • Microphone jack
  • Headphone jAck
Chipset Via VN800
Expandable to 1 GB
Interfaces •2 - USB 2.0 ports
•1 - VGA external connector
•1 - RJ11 (modem)
•1 - RJ45 (Ethernet LAN)
•Microphone jack
•Headphone jAck
Weight 5.01 pounds
Mar 03, 2010 | Gateway Computers & Internet
What is the minimuim requirements on resident evil 5
Yeah maybe but it gonna be SLOW so I dont recommend it. you should have a better computer.
Resident Evil 5
Publisher: Capcom
Developer: Capcom
Minimum System Requirements
OS: Windows XP
Processor: AMD Athlon64 X2/Intel Pentium D series
Memory: 1 GB
Hard Drive: 8 GB Free
Video Memory: 256 MB (ATI Radeon HD 2400/NVIDIA GeForce 6800)
Sound Card: DirectX Compatible
DirectX: 9.0c
Keyboard and Mouse
DVD Rom Drive
Recommended System Requirements
OS: Windows Vista
Processor: AMD Phenom X4/Intel Core 2 Quad series
Memory: 2 GB
Video Memory: 512 MB (ATI Radeon HD 4800/NVIDIA GeForce 9800)
DirectX: 10
Keyboard and Mouse
DVD Rom Drive
Aug 17, 2009 | Intel DG31PR Motherboard
SM Bus Controller and Video Controller (VGA Compatible) drivers
You can download all Windows XP Home Edition drivers for the Intel D101GGC motherboard from Intel's web site at the following link:
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2229&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go!
May 15, 2009 | Intel D101GGC Motherboard
IN MY SYSTEM UNFORTUNATELY UNINSTALLED THE DRIVER SOFTWARE BUT I HAVE THE CD ROM. AFTER I PUT THE CD ROM AND EXECUTE, DURING THE PROCESS AFTER REACH THE INSTALLATION AT 34% BUT AUTOMATICALLY DISABLE THE...
You can try this:
I am assuming you have a PC based sound system.
1. Remove your Creative Labs Home Theater from your PC. You should remove all hardware.
2. If you have Windows, go to "Control Panel"
3. Select "Add or Remove Programs"
4. Delete all Software releted to your Creative Labs System
5. Go to http://www.creative.com/language.asp?sDestUrl=/support/downloads
6. Download the appropriate driver for your system
7. Reinstall the system with the new driver
You could try your CD ROM after completely deleting the software from your PC, but I think I'd just try the downloaded version. The important thing is to completely remove all hardware and software before reinstalling.
Apr 08, 2009 | Creative Labs Audio Players & Recorders
Software purchase
Hello dazz_hammer,
You can put up to Windows XP. If do, I would suggest to add memory and bigger hard drive.
Or if the pc has Windows Product Key Tag, and what ever the operating system it indicates then you can re-install that operating system.
Hope this helps and good luck.
Jul 27, 2008 | Dell Latitude CPX Notebook
Pinnacle TV card will not work in 761mx (gx-968) motherbd. Pinnacle Ref: 203560713235309122. Windows sees and loads one driver, but original driver does'nt load.
http://www.twenga.co.uk/specs-PCTV-Hybrid-Pro-PCI-310i-PINNACLE-TV-tuner-card-114949
see the link
Software / System Requirements Software Included Pinnacle Studio QuickStart, Pinnacle MediaManager 1.1 OS Required Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Media Center Edition 2005 Peripheral / Interface Devices CD-ROM, DVD-ROM, DirectX 9.0 compatible sound card, DirectX 8.0 compatible graphics card System Requirements Details Pentium 4 - 1.8 GHz - RAM 256 MB - HD 5 GB
Jul 21, 2008 | Computers & Internet
Dell XPS™ 600 PC Desktop Logo
125 people viewed this question
Alun Cox
