Question about Linksys Wireless-G WRT54G Router
CONNECTING A LAPTOP THROUGH THE ROUTER
MY LAPTOP SHOWS AVAILABLE CONNECTIONS HOWEVER I CANT CONNECT TO ANY OF THEM
    Sergeant:
  • 219 Answers
Those connections are encrypted and require you to enter the connection's password to gain access to the associated network.
If you are trying to connect to your own router's wireless signal you will need to determine your router's wireless encryption key (Typically listed on the actual router or its manual(s)) and use that to connect to your wireless connection.
If you can't find that key let us know and we'll help you locate your router's control panel which will allow you to setup your encryption type and its associated password.
Posted on Feb 03, 2009
  • 63 Answers
Please check for any firewall or Antivirus on your computer. Try disabling the them.. Kindly let me know the Make of your laptop & are you using the Windows utility or any brand specific like Dell or HP wireless assistant.
If you are using any one of those than try the following steps:
1. Go to Control panel- Network connections- Right CLick WLAn connection- properties- Select windows zero configuration utility
When connecting to internet on laptop, the connections which I have set us to automatically connect do not show up in the list of wireless connections available. I have a linksys wireless connection...
If your connecting WIRELESSLY--the a network cable would be unplugged because your wireless not wired---
and if your not seeing the router on the laptop check the router settings to broadcast the signal
Jan 13, 2011 | Linksys Wireless-G WRT54G Router
My laptop quit working cant get no connections through router
First; Does your laptop see any wireless connections? If no wireless connections are showing up, your wireless card could be off. Depending what type of Computer you have, it could be a slide switch in front, if its dell, you can push Fn and F2, If you do see wireless connections, and just cant connect,. try shutting down your Computer, unplugging your Modem, and Router. Restart, then see if you can connect. Wireless has so many issues, If you still can't connect, let me know and I will give your more information. Hope this helps.
Oct 12, 2010 | Belkin (F5D7230-4) Router (587009)
Cannon 560 printer is not connecting to the router.
It shows your router is not configured properly. Reset your router and reconfigure as per the instructions. Dont forget to name your network (ssid). After this ascan for the available network and then connect
Jun 02, 2010 | Linksys Wireless-G WRT54G Router
I sm havings problems using my laptop in my house.
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jan 20, 2010 | Belkin (F5D7231-4) Wireless Router
Limited connectivity - wireless
Verify if your wireless option on the router is enabled.
Also when you setting the wireless on the router, be sure that channel is not on automatic. Specify a channel number. After that try to connect again to wireless
Aug 05, 2009 | Blitzz Technology BWA711 (B3WL000900)...
Cant get wife to connect is the wireless icon
hi
no the wifi stay blinking on activity, but the wireless connection on the laptop has to stay on
1. first have you tried with the ISP if you need any Proxy settings or specific IP address.
2. also check with the ISP if you need any specific DNS server settings
3. if the above two are given or not required but the router still does not give out connections then try this
instead of connecting the cable from the Modem to the slot named INTERNET try connecting it in one of the out going slots (numbered 1,2,3,4) and now connect the other systems as usual.
cheers
PS: if this has been any bit useful pls rate it, thanks
Jun 27, 2009 | Belkin Computers & Internet
Can connect via Ethernet but not wireless
well its unfortunate,,intel 2200 WLAN cards{oldest cards launched till now by intel} face this problem,the problem is with the differnce of wireless standards between the router and the wireless card.go for a wireless usb adapter,,install it and it wud work absolutely fine
Apr 12, 2009 | Intel PRO/Wireless 2200BG 802.11g/b
Can't connect to my K-jam to my new DLink DIR-655 wifi router
Can't connect to my K-jam to my new DLink DIR-655...
Mar 11, 2009 | i-mate K-JAM Cellular Phone
Cant connect 2 laptops through linsky wrt54g is this possible
are you connecting the laptop hard wired or wirelessly?
for wired connection, just plug the ethernet cable from the router to the laptop and it should work fine.
for the wireless connection, check on the wireless network connection. for xp, click on start> control panel> network connections> right click wireless network connection> then click on view available wireless network> then select your network.. for secure wireless connection, type the security key then click connect. :-)
Dec 13, 2008 | Linksys Wireless-G WRT54G Router
Cant connect to wireless router
Make sure the wireless adapter is enabled on the elonex laptop and its properly installed.
Connect wirelessly on the elonex one laptop using the same SSID and security key that you used on your main laptop.
Aug 07, 2008 | Belkin (F5D7230-4) Router (587009)
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
