Sangean DT300VW AM/FM/Weather/TV Radio Logo
A
Anonymous Posted on Feb 06, 2013
Bought the Sangean DT-210/L/V personal radion. Have set the pro-set stations. and set memory . Can't get from station to station without using tuner. That defeats the purpose of having pre-sets. Manual doesn't help
2 Related Answers
Anonymous
  • Posted on Aug 06, 2008
SOURCE: Sangean ATS 606 A Portable Radio
Remove the battery compartment door and the batteries. There should be a small hole marked "reset" under the upper battery cradle. Press (gently...until it clicks) and hold for 5 seconds. Replace batteries and try again.
Anonymous
  • Posted on Nov 30, 2008
SOURCE: setting station presets on Sangean ATS 505
A copy of the manual is at
http://download.qrz.ru/pub/hamradio/schemes/receivers/DX-398_Owners_manual.pdf
or you could enter dx 398 manual into google.
best regards apritt
1helpful
When the alarm activates on my Sangean WFR-28, I can see the preset station showing up on the screen but there is no sound, although the volume is set to 20.
I have the same issue with my Sangean WFR-28c. I just contacted support (through Sangean Europe site) but im still wating for an answer. If this carries on, i cannot use this radio. :(
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
3answers
What fm station do I set my radio on?
i have a ford explorer, 1995 it came with a 10disc cd changer only trouble is we dont know what radion station we need to use for it can you help?
5helpful
How to set buttons for memory
To set memory buttons:
1) Tune to the station you want.
2) press "mem" button.
3) press the memory button you want to use for that station (1 thorugh 6)
4) press "mem" button again.
You have now set the memory button you selected to the station you selected.
Set the radion stations
Check the GMC website for a manual
13helpful
2answers
Setting the stations on memory
OK HERE'S WHAT YOU DO
1. USING THE UP AND DOWN TUNING, TUNE IN THE STATION
2. PRESS THE MEM SWITCH (LEFT SIDE OF ROUND SWITCH)
3. PRESS STATION LOCATION
4. PRESS MEM AGAIN ---- THAT'S IT
SUMMARY: TUNE, MEM, SET STATION, MEM
2helpful
2answers
Top Sangean Audio Players & Recorders Experts
 Grubhead
Grubhead
john h
k24674
Are you a Sangean Audio Player and Recorder Expert? Answer questions, earn points and help others
