Question about RCA F36650 36" TV
Set has no sound then comes on full blast
Set comes with picture but no sound. volume bar runs up and down. after set is on awhile, sound comes on full blast. unable to control volume with remote or at set. chassis # is ctc203ac. model # is f25422
  • 28 Answers
Replace all the tac switches.
Posted on Feb 03, 2009
Volume up then pic gone
You've got a bad solder connection,or broken foil line,s on the pcb (printed circuit board1.gif).Narrow it down by pressing in different places,or use plastic or rubber tip.If not,then you got a shorted load on this fuse and diode.do you have a schematic,whats at the end's of this circuit.D represents a <Diode> not a transistor.
Jan 28, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
Volume will just blast real loud
If you have a remote control , unplug the lead from the volume control (at the back of the machine) and instead of it plugging into the Inrfa Red control unit in the base of the cabinet, plug it straight into the amp volume input.
There has been problems with the remote that does what you are suggesting so this will prove the point.
Jan 16, 2009 | Wurlitzer Jukebox 1015 One More Time...
Possible blown speakers
I have experience with that model of speakers. When they give up the ghost, the volume is VERY low. But just to be on the safe side, check the volume properties to make sure nothing is set too low. Start>Control Panel>Sounds and Audio Devices. Check the slider bars here, check in the Advanced area as well to make sure nothing is low and check the Speaker Volume as well. If all the bars are set to their maximum, it's time for some new speakers.
Thanks for using fixya.com. If you like my answer, please help me out and rate me accordingly.
Jan 11, 2009 | Dell A215 Computer Speakers
Problem with the volume
what about sound bar in the tv that shows how much is vol.
is it remain normal or go at full ..
check if it remains normal then its another problem
if it goes also full then it might be software problem
Aug 14, 2008 | RCA F25422 25" TV
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
"snow" screen, full volume, remotes don"t work
good day
due to the long time the buttons were not used, they tend to get stuck and this causes channels eighter to stay in one station or continou scanning. it could be resolved by spraying WD40 on the buttons and press it many times then dry it before operating the unit.
chris
Mar 25, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Volume goes full blast when turned up from zero to just a "1" onscreen
I have seen a similar problem. get to design mode (that trick with the remote mute & the set menu button) & look for a data address in the audio section that is set to all (F)s. sorry i can't remember the exact address. you could always just guess just make sure you write down where they are currently set .
Hope this helps.
Jan 25, 2008 | Toshiba 19A26 19" TV
Sounds like you have a jammed / shorted out button on the control panel... Try un-plugging the tv, and then unplug the "button panel" on the front of the tv...see if you can turn the tv on with the remote. Sometimes if one of the buttons gets shorted, it will "lock" the processor from doing ANYTHING else, as it thinks you are holding down the defective button. If this works, simply have the defective switch or control panel replaced, or just leave it unplugged and use the remote only! Hope this helps!
Jan 03, 2008 | Mitsubishi WT-46807 46" Rear Projection...
RCA F36650 36" TV Logo
108 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
