Question about Dell Inspiron 1501 Notebook
Wireless card in E1505 Dell not finding networks in range
Thank you for your imput. I tried what you suggested - again, the Dell Wireless 1390 WLAN Minicard and the 1394 Net Adapter are both enabled. The 1394 says it is connected, the Dell Wirelesss minicard says it is not connected. When you double click, a window comes up saying there are no wireless networks found in range. That's not possible, because I am connected to a computer that is connected via wireless and the laptop is right next to it. What could be the reason why the minicard, though enabled and "working properly" does not recognize a wireless network?
  • Anonymous May 11, 2009
    I have the same problem with you. It was terrible. I can not believe it. So, what should we do?
  • Dell Master
  • 32,281 Answers
The 1390 WLAN Minicard may not be configured to communicate with your wireless router.
Check the wireless router settings, (check the wireless settings on your other computer) and configure the 1390 WLAN with the same settings eg. SSID, WEP/WAP encryption, etc.
Is MAC address filtering enabled on your wireless router, if so add the MAC address of the 1390 WLAN to the MAC address list in the wireless router.
Check the TCP/IP properties of the 1390 WLAN card the Internet protocol should not have a fixed IP address, set it to Obtain an IP address automatically including the DNS.
Use the Ipconfig command to see the IP configuration of the network cards.
Use the Ping command to see if you can communicate with wireless router.
Posted on Feb 03, 2009
Dell NetworkDell Wireless 1350 WLAN MiniPC
The Dell Wireless WLAN Card Utility locates, manages and provides information about wireless networks in your area.
The Dell Wireless WLAN Card Utility allows you to create network profiles, connect to an available network, and diagnose connection problems.
Enable the utility through an icon in the notification area of your desktop, or locate it in the programs list depending on which Dell computer you have.
Turn on the Dell laptop and make sure the wireless switch is in the "On" position.
Right-click the utility icon in the notification area of your desktop.
The icon appears as a set of four green, yellow, red or white bars, depending on the signal strength in your area.
Click "Enable Radio."
Right-click the icon and click "Open Utility" to open the Dell Wireless WLAN Card Utility.
Control Panel
Click "Start" and select "Dell Wireless WLAN Card Utility."
Click the box next to "Enable Radio" and click "Apply."
Click "OK."
http://support.dell.com/support/edocs/network/p70008/en/utility.htm
http://support.dell.com/support/edocs/network/p70008/en/wizard.htm
Jul 05, 2013 | Dell NetworkDell Wireless 1350 WLAN...
Dell Wireless 1390 WLAN Mini-Card driver
Hi. You can download the driver from Dell website. I strongly recommend that even there will be more recent versions out there, stay with the versions released by Dell, Dell before releasing a driver tests it with the systems to ensure full compatibility and zero-problems with other devices:
Dell Wireless 1390 WLAN mini-card driver
Also for future needs, it's advisable that you go to the following web page:
Dell Drivers & Downloads
And enter the service tag of your Dell computer, so that you could get drivers specific to your system.
hope it helps
Oct 22, 2012 | Microsoft Windows XP Home Edition
I cannot get my wireless Lan mini card to connect to a wireless network, the network is detected but will not connect
Go to the Device Manager. Double click on the Dell Wireless (1390/1490/1500) Dual Band WLAN Mini-Card device. The properties dialog should appear. Click on the Advanced tab. Look for Antenna Diversity under the Property. Change the value to Aux. Hit ok. Then try and reconnect to your WIFI connection. By changing this you should see your access point and be able to connect to it.
May 08, 2011 | Toshiba Computers & Internet
How do i download network adapter for my dell tower, its service tag is C0WST21
please page the URL below in your browser and click download button.
http://download.cnet.com/Network-Dell-Wireless-US-WLAN-Network-Adapter-Card-Wireless-1370-802-11-b-g-WLAN-MiniPCI-Card-Wireless-1350-802-11b-g-WLAN-miniPCI-Card-Wireless-1450-802-11a-b-g-Dual-Band-WLAN-miniPCI-Card-Wireless-1350-WLAN-802-11b-g-PC-Card-TrueMobile-14/3000-2112_4-109107.html
Feb 19, 2011 | Dell 04U852 Network Adapter
I have limited connectivity. Both my Broadcom 440x 10/100 Integrated Controller and Dell Wireless 1390 WLAN Mini-Card drivers are up to date.
make sure the access point or router is on DHCP then connect the computer, but if its on dynamic IP... them enter an IP in range of what you have on your AP/Router
Sep 06, 2009 | Dell 430-0008 Network Adapter
Wireless Connection Problems between an Dell Laptop and Actiontec
Have you got permission to connect into her Internet using her wireless router?
If so you need to get the WPA encryption key from her to configure your wireless card's encryption to get access.
Jun 28, 2009 | Dell Inspiron E1505 Notebook
Browsers on Dell Inspiron E1505 won't bring up pages
Open a command prompt and type the following command:
netsh winsock reset
This works wonders on mysterious networking problems like the one you describe here.
Hope this helps.
Feb 28, 2009 | Dell Inspiron E1505 Notebook
Can not connect to internet using wireless
Did you input the WEP key? I will assume you are using Windows XP. So go to control panel, network connections and then go to the wireless connection and then select view wireless connections double click on the one with the highest strength, which should be your 2wire. When it asks for the network security key type in the numbers that are located on the sticker on the bottom of your router between the [########] brackets.
Jan 16, 2009 | Dell Inspiron 1200 Notebook
Internal wireless card has been disabled. How do you fix this?
Hi car7924,
First, make sure that the wireless switch on the left side of the computer is turned on (this should make the WIFI light go on -- beneath the lower right corner of the screen). If it doesn't work, then try going to Start Menu > Control Panel > Network and Internet Connections > Network Connections.
You should see the Wireless Network Adapter in the window that comes up. If you don't, you need to download the driver for that adapter. The most common adapter in the D820 is the Dell 1390 WLAN MiniCard, and the driver for it can be downloaded at the following web address:
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/Dell-Latitude-D530-Wireless-1390-WLAN-MiniCard-Driver-A17.shtml
If, on the other hand, you do see the Wireless Network Adapter, but it says "Disabled" underneath the name, then right-click it and select "Enable." This should make it work.
I hope this helps - please let me know if I can be of any further assistance.
Kind regards,
H2H
Dec 13, 2008 | Dell Latitude D820 Notebook
Dell 1390 wireless inconsistent on start-up
hi
please uninstall the drivers completely, make restart and either install the original drivers that comes with your laptop or download the latest drivers setup from internet and install them.
most the the problems solve by completely uninstalling the drivers and reinstalling the fresh ones.
i hope this will help you. Please give your feedback
bye
yasir
Feb 24, 2008 | Dell 1390 (WPCB143GDW1390WPCB143G)...
Dell Inspiron 1501 Notebook Logo
652 people viewed this question
Alun Cox
