Question about Panasonic Televison & Video
No picture - wont 'turn on''
Seems to not want to ''turn on'' remote nor button on front on TV works. Receiving sound through stereo (hooked up to digital cable) is this a problem with the on/off switch or tuner? is it worth getting fixed vs. new tv.? this one is 5 years old.
  • angelagraden Feb 04, 2009
    the light is not flashing (nor is it on)
    it is a HDTV panasonic CT-32HXC43
    i did unplugged it for about 3 hours but it still did not come on
  • marionbagget May 11, 2010
    Does the light on the front flash ? Panasonic uses the number of flashes to guide you to the problem. What is the model of the tv ?
    Panasonics has a website technicans can use to download manuals to diagnose some of their TV.
  • 718 Answers
If it fails while plugged into energized outlet then its related to the main power supply regulator circuit. If you are NOT an electronic/electrical/technician or tech savy with DVM do not read this message further.
No light on means you should check check the fuse(s).
UNPLUG the unit and removed the cover.
CRT based units will still have 25,000 Volts EVEN WHEN UNPLUGGED !! So do not touch the CRT/circuit.
The fuse(s) will most likely be located on/near the power supply board. Look for a small panel where the cord enters the unit.
For a glass type, check to see if it is blowned. If bad replace with identical value. Attach back cover and try set.
http://service.us.panasonic.com/OPERMANPDF/CT32HL43G.PDF
Posted on Feb 04, 2009
No picture on the screen. Sound is working
This problem is hard to pinpoint as there are so many variables.
If I could ask you a few questions first: -What is the model of the display?-What other components are hooked up to it?-What cables are connecting these components to the TV (e.g.. HDMI, Component, Composite etc.)?-Are you using an external sound source (stereo) or the TV speakers for audio?-Do you see and indicators or the screen when you turn up/down the volume or change inputs? This is of course using the Samsung TV's remote.
I would try these things though:
1. Turn the TV off, unplug it from the power source for 30 seconds.2. Check the cables are all plugged in firmly and correctly.
3. Plug it back in and turn on the TV. Still no picture?
4. Try changing to another input (e.g. DVD, VCR, XBOX etc if you have one)3. Check on the Tv's remote to see if there is a "picture mute", "blanking" or similar button they may have been accidentally pressed. When you press it again, you will get picture back. If there is no button and still experiencing the same problem after checking all these things then you may have a fault.
Oct 27, 2012 | Televison & Video
My tv wont show a pic or sound. the green light comes on and it clicks but nothing. its a sony bravia kdl-55ex710. its happened before and my husband played around with the home button. it occassionly...
On the remote control to that tv, after the power is turned on, find and push the input button untill you have a picture. The input button switches where you are receiving your signal from, cable, component, video 1, vedeo 2,,etc,,,.
Hope this helps
Apr 19, 2011 | Televison & Video
I HAVE A JVC AV-3290S TV REMOTE DOES NOT WORK AND I CANNOT GET THE TV ON CHANNEL 3 TO WORK WITH CABLE
Try using the video input connectors using the front panel buttons to select. or hook up the cable box so your sure the TV is receiving the signal and then select autoprogamming through the front panel buttons
Oct 04, 2009 | Televison & Video
Remote control and buttons on top of tv wont work!
you unplugged the front panel with the buttons on it and the remote reciever
you have to slide the chassis out
reach in to the front and replug the front panel to the plug from the main board
then slide all boards back in place
Aug 26, 2009 | Sony KV-35V42 35" TV
I have a dvd player that I am trying to hook up to a sharp tv model number 25L-M100B. This tv don't have the necessary ports inthe back to plug dvd or anything up to it. It does have 2 in the front of
Hook the dvd player up to the front inputs usually a yellow and a red or possibly a yellow red and white depending if the TV is stereo or not.
Then on your remote, it the INPUT button and take it to "VIDEO 1" while your dvd player is on and you should get a picture.
Make sure not to mix the cable colors.
Yellow is video
White Audio
Red Audio
A lot of times there is only either white or red and not both. This is just Mono sound, it works, just not "stereo" sound.
Jun 01, 2009 | Televison & Video
Hooked up to sony bravia 52" tv and can barely hear sound
You'll want to turn of the TV speakers in the Remote Menu and try turning up the volume level of the TV, which usually controls the level of the RCA outputs, as well
Feb 02, 2018 | Yamaha RX-V596 Receiver
Conia plasma.no buttons work on the tv and the picture does not appear when you turn it on.it shut of one day.the aerial works and the tv has power.
How long have you owned the television. What is the exact model of the television. Once I have more information I can help you further.
Thanks,
Lee
Aug 26, 2008 | Televison & Video
Toshiba 36AFX61
Just Connect signal to tv and run autoprogram. Or use video input jacks from converter to tv ( yellow,white and red video in ) and select tv/video on tv pannel front ( don't need remote control) I hope this work for you.
May 11, 2008 | Toshiba 36AFX61 36" TV
Zenith system 3 tv will not turn on
I'd say just get a stereo system (amplifier) or something like that, and hook your cable box, vcr, converter or whatever you have right into that. That's what I've been doing for years. Most cable boxes and satellite boxes will control the main volume that goes to the sound output, or you can get a digital stereo with a remote to control the volume that way.
Oct 26, 2006 | Zenith SY3538RK TV
Televison & Video Logo
218 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
