Question about Whirlpool Dishwashers
Replace dishwasher / counter tops are not standard
Have a leak in old dishwasher and bought a new whirlpool from Lowes only to find out when they went to install that they can't get old out without taking out counter tops (tile). Do you have have something that I can order (buy) that will fit. I well that I will probably end up cutting out the sub floor and removing the dishwasher, this house was built in 1929 and I really don't want to dump more $$ into the tops. But I really want to have any problems with a new one and can't have it worked on or replaced again without cutting the sub floor. Rose
  • rosemaryhoga Feb 03, 2009
    The new dishwasher is too tall! No way to slide it in. Does Whirlpool make anything shorter? Custom product? Let me know.
    Rose
    Sergeant:
  • 311 Answers
I have had that problem before and used a saws-al and cut the legs and what ever else i needed to get that puppy out.the question is will your new one fit?in my case most all i ever tried to install i got them in.and i have done a hundred or so
Posted on Feb 03, 2009
  • Thomas Malailua
    Thomas Malailua Feb 04, 2009
    there are some shorter versions.check out sears on line with your measurments
I just bought a whirlpool dishwasher from Lowe's.....water is leaking out of the. Bottom.....should I repair or return
Return. Any attempted repair could void warranty. Just be sure it's not an installation error.
Nov 14, 2017 | Whirlpool Dishwashers
The new dishwasher kitchen aid we bought is leaking
If it is leaking from the front, then there is a problem with the seal that runs around the front of the dishwasher. It is usually located behind the main door on the edges of the unit itself, it will look similar to weather stripping. A cheap way of fixing this is to get real good weather stripping from Wal-Mart, Home Depot, Lowes, etc. It will have a sticky surface on one side, you peel off the paper, then apply the weather stripping to the actaul door, first try to mark where the old one sits against it.If its leaking from underneath, than it can be a number of things, but most are easy to repair, you just have to pull the dishwasher completely out to get a better look. Sometimes one of the components will be leaking, but for the most part, it might just need a new hose clamp or tightened up. Hope this helps.
Dec 27, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwashwer wont fit under counter
it depends on how much tallerit is . you can adjust the legs but you have to know how much. if this helps let me know.
Dec 27, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Replacing a water elbow in a Fridgidare model FRS26ZRFW1. Can't pull old plastic elbow off the existing tubing. Do I need to cut and push in? The tube is coming into the ice maker/water dispenser from the...
I went to Lowes and bought a new Elbow (2.49) and cut the lower tube right at base of elbow. Upper tube slid out. Pulled a little on bottom tube and replaces easily.
Jun 15, 2009 | Refrigerators
Danby counter top dishwasher power switch problem
In regards to the problem with the power switch , I was able to get the 800 number from the store that we bought it at. Called the number-got right through-and they emailed me a COMPLETE breakdown and parts manual for my specific machine.
And I was able to order the part from them right over the phone and it was shipped out immediately. Very pleased with the service. Any one needs the parts breakdown I can email it to them.
Good luck-
Jan 10, 2009 | Danby 22 in. DDW399 Free-standing...
Kenmore Dishwasher installation
taking astab at this but your kit floor has been replaced and to close to counter now????, your either shimming up counter or removine the floor from under d/w
Mar 11, 2008 | Whirlpool 24 in. GU1500XT - Multiple Color...
Whirlpool DU1055xtss doesn't fit cavity where old Whirlpool dishwasher exists
best bet go see your local KNOWLABLE sales rep. generally the mom and pop better then the big chains for knowing what will and wont fit your height requirements
Feb 29, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwashers Logo
300 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
