Question about Goodman GMS90703BXA Heater
Combustion fan and circulating fan running and no heat
This unit has had two new boards put into it, honeywell brand boards. The unit started running the combustion and circulating fans and not producing heat. Two technicians have worked on it and it is still sitting there with the combustion and circulating fans running. have even put in a new ignitor and flame sensor. the loops check out fine, it is not the tstat. Can anyone help with this problem. I paid for expert help but this site will not honor it, wasted that money.
  • 3 Answers
Check near the squirrel cage fan and see if there is a sail switch.  Sometimes these are used to confirm air movement prior to firing off the gas furnace.  It is simply a square piece of metal on a stick that attaches to a microswitch.  This switch is then depressed when the fan pushes the air (and the metal piece) allowing the burner to fire off.
Hope this helps.
Posted on Feb 04, 2009
I have a Honeywell thermostat and the fan runs continuously. Not sure if need to set on Auto fan and Auto Heat or what.
Hello Donna,
You are right. The Auto setting will allow the fan to shut off when the fan is no longer needed.
Jan 14, 2018 | Honeywell Heating & Cooling
Help- when heater gets to room temp. the circulating fan stops, but fire remains in combustion chamber and the blower motor or exhaust fan continues to run for hours. Toyostive laser 56MH thanks Jim...
If there was a flame in the burner and no circulating fan running the stove would over heat in less than 5 minutes. It would show an EE 6 message. Are you sure there is a flame in the pot? The stove does have a safety feature that allows the combustion fan and circulating fan to run continuously in certain cases. This is a rather extreme case. In any event the circulating fan would be running at the same time the combustion fan was on. To get out of that mode turn the stove off and on again. Now you should be able to restart normally. Keep us posted,
Oct 21, 2010 | Rinnai Toyostove Direct Vent Heater:...
Honeywell TH6000 series thermostat does not turn Fan on.
It's one of two issues; either the wiring to the thermostat is incorrect, or possibly you have an open ground. Depending on your system the wires at the thermostat end might have to pair up on one lead. go to where your unit is and look at the schematic for the control board, it will let you know what color you are looking for on the blower lead -- then make sure the corresponding color matches at the thermostat. Knowing the make and model of you unit and the board on it would allow me to be more specific, hope this helps you out some in the meantime.
Jun 17, 2009 | Honeywell Focus 6300B 5-2 Days...
Goodman pgb 0300751 gas package unit. The unit started running both the combustion and circulating fans. Technicians have put two new honeywell boards in it. the fans are still running. all circuits and...
then you need toi have them check the fan high limit that is mounted in the blower compartment. if it's closed then the blower fan and the conmbustion air fan will run together.
Feb 03, 2009 | Heating & Cooling
Older Goodman gas package unit combustion and circulating fans
There is a limit switch tripped somewhere. it is either the main limit in the firewall orthe limit switch on the small fan (inducer) that is tripped some of these are manual reset try pushing the button in and see if that stops it.
Feb 03, 2009 | Goodman CLQ36AR49 Air Conditioner
My father has an older model two and a half ton goodman gas package unit. it has had two boards put in it, the problem is that the unit will go through a heat cycle and the combustion motor and the...
the fan induction motor produces a vacuum, check of orofice on motor is plugged by pulling hose off switch end and putting in mouth while running and sucking, this will make a whining sound immediately if no restriction. the fans are controlled through the board by vac., swich, limit sitches, and timers in the board itself. maybe a bad ground on flame sensor.
Jan 29, 2009 | Heating & Cooling
Two and a half ton Goodman Package Unit
goodman boards really have to have a very good ground. make sure the ground wire is securely attached. also even though you say the limits are all good, you need to check the wiring that goes from one limit to the next. they should make a loop that goes from the plug at the control board to each limit and then back to the plug. take the plug loose and locate these 2 wires. ohm them out. if it is open, your problem is somewhere in the loop. the fact that the blower is running all the time tells me the board is not getting the signal it is looking for from the limits. I have seen some goodmans that have a rollout problem at the burner box and it melted the wiring to the limits on top of the is hard to see so you have to look closely. also if this is the case, you need to have someone check the heat exchanger for a crack. the rollout usually does not happen till the fan starts blowing while the burners are on. if this is the case, you do not want to run the furnace for any reason as this is a carbon monoxide risk.
Jan 27, 2009 | Goodman CLQ36AR49 Air Conditioner
My apartment honeywell a/c is on full crank at 90 degrees on "heat". It doesn't feel warm at all, though it's been on for hours. I have a new filter in, as well. Also, "fan" and "auto" are other controls...
The "Fan on/auto" switch is desighned to give you the option of running the fan constantly, which continuosly filters the air in gives circulation.
It does not effect the heat or cool modes of the unit. All it does is effect the fan.
On the "Auto" setting, the fan will only come on when the unit is calling for heat, or cooling.
This will save a little bit of electricity, but will not continuosly circulate or filter the air.
What was the temperature inside tha apartment when you first set the T-stat on 90?
What is it now? if it is still climbing and it started out very low, it may just be working fine.
If not, you could have other problems, like low refridgerant (if it's a heat pump) or bad insulation on a very cold night or an undersized unit.
Has it been working properly before or have you just moved in/turned it on?
Dec 06, 2008 | Heating & Cooling
Goodman GMS90703BXA Heater Logo
135 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
