Question about Belkin (F5D7000) 802.11g/b Wireless Adapter
Belkin Wireless connection speed at 11mpbs. Why not 54mpbs?
Running Windows Server 2003. I have 2 network cards. The main one is hard wired to my router. The other is a Belkin Wireless G PCI F5D7000. I want to set it up that all my computers connect to the Belkin to get internet connections for the laptops. I have it set to static, no default gateway. I created a SSID via the wireless card and am able to connect to it with the Belkin (setup for On Demand connection). It seems that the only way the SSID shows up is when it is set for an adhoc computer to computer setup. When the other computers connect to the Belkin they only connect at 11mpbs. The Belkin shows that it is connecting at that speed which is why the other computer connect only at 11mpbs. If I were to set it up to connect to my router and obtain IP and DNS automatically it connects at 54mpbs. Why does the Belkin only connect at 11mpbs internally? How can I get it to 54mpbs so that the other computers connection speed would be 54mpbs?
It was recommended that I need to increase the frequency in the wifi router settings. How do you do this? Do you increase it in the router itself? It doesn't make sense. The router is set up for wireless b/g. This wireless card is not connected the router. It is setup so that other computers can connect to this card where they will get their IP address. The server is hardwired to the router with another network card. Basically the server is going to provide the IP address and the internet access. However my laptops can only connect at 11mpbs. Don't know why.
This is from the d-link support page:
"Question :Why can't I get the advertised speed and performance when in Ad-Hoc mode?
Answer :
This FAQ applies to 802.11b, 802.11g, and Super G™products.
D-Link wireless products follow the IEEE 802.11 standards. The802.11b and 802.11g standards specify that Ad-Hoc mode only needsto support up to 11Mbps. For best results, use an access point orwireless router and set your adapters to Infrastructure (station)mode."
Posted on Feb 05, 2009
Can I wirelessly network my hp pec 1350 with a belkin wireless g all in one print server
The Belkin Wireless G All-In-One Print Server lets you easily add an all-in-one printer to your wireless or wired network. It features 802.11g technology that makes sending print jobs faster than ever, and includes a memory buffer that handles your graphic jobs effortlessly. The Print Server is so easy to install that you'll be printing in minutes. Simply connect your Print Server to your Belkin Wireless Router and run the Belkin Easy Installation CD. Next, attach your USB printer to the Print Server and load yourprinter drivers onto your computer. You are now free to print, scan, fax and readcard media* wirelessly from around the home or office. The Print Server also works flawlessly with wired networks through its integrated Ethernet port. Compatible with most USB, network-ready printers, the Wireless G All-In-One Print Server from Belkin delivers even your most data-intensive print jobs with maximum speed and reliability.
*If your all-in-one device has a card-reader slot.
Nov 21, 2012 | HP Psc 1350 All In One Printer Scanner...
My Server can not conet to the network
Check your IP address and workgroup settings in the computer or try assign Static IP to the computer.
May 11, 2010 | HP Compaq ProLiant ML110 G4 Server
Laptop won't connect to new Belkin G Wireless Router
Just Install the hardware and insert the driver of the router...then follow the instruction...
May 10, 2009 | Belkin (F5D72304F5D7000) Router
Belkin Wireless G desktop card & BTHome Hub
it has been seen that due to some reason the wep key doesnot work...
u can try changing the key type to WPA instead of WEP...
go to the router page and change the security type to WPA instead of WEP..
1 more thing in vista you can use the windows utility come is it possible that you are using the card utility as well..i suggest you to disable the card utility and just use the windows default utility..
vedhick.....let me know if u need steps to change the security type to WPA..
Jan 26, 2009 | Belkin 802.11g Wireless Desktop Network...
Server cannot see wireless workgroup machines but shares Internet
Disable any firewalls on the machine like Windows firewall or any other firewall like Norton, McAfe, ZoneAlarm and something like that. Or if you have firewall policies or access rules, you must enable the sharing there.
Oct 31, 2008 | Belkin Computers & Internet
G+ mimo Notebook Card
She probably has both the Mimo Utility and the Windows XP Wireless Configuration Utility running at the same time.. Try disabling the Windows Configuration Utility and see if she can connect now..
Start > Run > Services.msc (OK)
Disable Windows Zero Wireless Configuration
Here is a visual explanation I found:
Dec 04, 2007 | Belkin High-Speed Mode Wireless G Notebook...
Belkin (F5D7000) 802.11g/b Wireless Adapter Logo
274 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
