Question about Dell Inspiron 1501 Notebook
Color Display problem
Hi
my Dell laptop has color problems. It shows green color than regular blue color. Any application I opened shows Pink color instead of regular color.
Can you help me in solving this problem
Ven
It seems that problem that ur facing is manly related to drivers but try booting into safe mode and incase ur screen look normal in it try installing the driver from support.dell.com.or check in bios and check the screen in case ur screen is still bad then contact dell
Posted on Feb 03, 2009
Pink flashing band down the middle of the screen
Hi:
You most likely have a bad LCD panel on your laptop, and to verify that is the problem, connect up a desktop monitor to the external VGA connector, and toggle to the external display. If it has a good display on the external monitor, you have a bad LCD panel. If the color band is still showing up on another monitor, you have big problems!
Mar 24, 2010 | Dell Inspiron 1501 Notebook
Car stereo wiring color code for f-150 1999
Constant 12V+ Light Green/Pink Switched 12V+ Black/Purple Ground Black/Green Illumination Light Blue/Red Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 6" x 8" Doors Left Front (+) Gray/Light Blue Left Front (-) Tan/Yellow Right Front (+) White/Light Green Right Front (-) Dark Green/Orange Rear Speakers 6" x 8" Rear Corners Left Rear (+) Orange/Light Green Left Rear (-) Light Blue/White Right Rear (+) Orange/Red Right Rear (-) Brown/Pink
Feb 21, 2010 | 1999 Ford F150 Regular Cab
Pink blue tint on display
Hello Adam, try replacing your signal cable. the signal cable has 3 color wires, 1 for red, 1 for blue, and 1 for green, the green wire is cut off, due to stress of twisting and pulling. find one on ebay. thats it.
Feb 08, 2010 | Dell M109S DLP Projector
What do the 4 color coded openings in the back of the sound blaster card mean? What plugs into which opening?I've got a Dragon dictating system microphone that has different colors. I'm away from home whee...
Hi, I know of three of your colors which may be the following.
blue.....Aux port
green...Soud (use this for your Dragon sound)
pink......Mic (this will be use for your Dragon connection mic.)
let me know if it worked.
WBTech
Jan 14, 2010 | Dell Sound Blaster Card
Hello i have a problem with my laptop i have pink color and green color on the screen all things in black are covered with green
The display is gone. Replace it. You see the basic Red-Green-Blue pallete... The liquid chrystals are "broken down"
Nov 29, 2009 | ASUS S6 Notebook
Toshiba Satellite L35 screen color turned to pink.
If you have a LCD-screen, not an old-style CRT-screen, it is the data-cable, and its connections, that are not transmitting one of the 3 "primary" colours, e.g., mix red & blue & green to get white,
but mix only two of those colours, and you could get pink,
because the mixing is an "additive" process.
If you mix NONE of the 3 primary colours, you should get BLACK.
If you see GREEN, you're seeing ONE of the primary colours.
Sep 19, 2009 | Toshiba Satellite L35-S2366 Notebook
White has turned pinkish
sounds like the linear adjustment is out of whack.....most projection type tvs, projection, lcd, plasma, have to be correctly aligned so that the color grids overlap each other to properly display the correct hue being created. you'd need the service code to re-adjust it, or have it serviced. also possible that one of the color grids is bad, but if you have all three (red,blue,green) colors showing on the entire screen area i would doubt it
Jul 24, 2009 | Vizio GV42L 42 in. LCD Television
Faded color display
replace the colorwheel.
Jan 27, 2009 | Eiki EIP-3500 DLP Projector
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Dec 30, 2008 | NEC WT610 DLP Projector
Distorted color on image
You might have "color filter" settings. Turn the digital filters off. Here is what manual at p72 says. "You can take pictures using digital filters. The filters consist of color filters such as red, blue and green, a soft filter that produces a fuzzy effect. Color filters Eight colors, black-and-white, sepia, red, pink, violet, blue, green and yellow, are provided for the color filters. When you select a color filter in the Digital Filter mode, the display on the LCD monitor is filtered with the selected color, and the pictures are taken in that color."
Mar 20, 2007 | Pentax Optio 555 Digital Camera
Dell Inspiron 1501 Notebook Logo
420 people viewed this question
Alun Cox
