Question about Microsoft Xbox 360 Console
Disc spins excessively fast and program won't start
When I insert a disc, it starts to spin at a very fast speed and continues to just spin. The program won't start. Any help for this Xbox 360 problem?
  • Microsoft Master
  • 2,404 Answers
Take a can of air and blow some air gently into it. Could be a dust problem on the laser. After this then try and load the game again, if it doesn't work still, then its a weak laser and you'll have to get the drive replaced
Posted on Feb 04, 2009
My bang & olefson cd 50 will not play. hear "spinning" sound when disc inserted.
THE CD50 DOOR MECH IS BELT DRIVEN IF THE BELT IS WORN THE DOOR OPEN/CLOSE SWITCH WHICH IS TRIGGERED BY THE MAIN CAM UNDER THE MECH MAY NOT BE FULLY CLOSED OR THE SWITCH MAY NEED CLEANING,ITS A LEAF SWITCH.THE MOST COMMON REASON FOR THE DISC TO SPIN BUT NOT READING DISC IS DISC MOTOR NOT GETTING UP TO CORRECT SPEED.IT CAN BE REMOVED,DISMANTLED AND LUBRICATED BUT CARE MUST BE TAKEN TO MEASURE THE TURNTABLE HEIGHT,BEST MEASURED FROM THE BASE OF TURNTABLE TO CHASSIS WITH FEELER GAUGE,CAUTION THE MOTOR SHAFT HAS SEVERAL VERY FINE WASHERS INSTALLED DONT LOSE THEM.
May 21, 2014 | Bang and Olufsen Beocenter 9300 Shelf...
Cd wont spin
The pladder motor is bad, "disc sits on top" most be replaced to regain normal operation.
Apr 14, 2012 | Sony CDP-CX300 CD Player
No disc spin-up when inserted or when powering up
The problem is in the pladder motor that spins the DVD, the motor needs to be replaced, but the problem is they only sell the laser pickup assembly, which is very expensive.
Mar 13, 2012 | Samsung DVD-V8600 DVD Player/VCR
My CD player keeps displaying no disk and wont play the cleaner disc, is something dirty or broken?
Hello
If it does not play the cleaner disc, just inspect whether the disc inserted in spins inside it. You can check this by open the upper cover of the player, and inserting a disc into it. If inserted disc spins inside, and the player won't read it, the fault is with its laser pickup unit, and it should be replaced with same type and number.
If the disc dos not spins, the fault is with the sled motor [the motor that spins the inserted disc], has damaged, and should be replaced. OK.
Dec 25, 2011 | Sharp Audio Players & Recorders
Wat should i do when is displays no disc
Hello
If your DVD player shows no disc, even a disc is inserted, try to clean its laser head assembly, by inserting a cleaning disc in it and play atleast three times. Take it ejected each time before you play it. If it does not helps, open the top cover of your DVD player, insert a disc, and notice if the disc spins or not. If disc spins, and not reads, the laser picup unit of your DVD player is faulty, and should be replaced with same type and number. If its stripe wire connected between pickup unit and main board is detachable, try repalcing the strip wire first. In some occations, bad strip wire will show this type of problem.
If disc does not spins, the sled motor [the motor that used to spin the disc at high speed], is damaged and shoud replace it. OK.
Apr 07, 2011 | GE DGE100N DVD Player
Disc spins very fast but program won't start
yeah this is a comon problem with the laser dying on the xbox 360 your best bet is to call this number and get them to change it free of charge 0800 587 1102 it will take around a week to sort but you will have no money to pay and it will be returned fixed
cheers
Feb 03, 2009 | Microsoft Xbox 360 Console
Insert dvd, starts to spin up and stops, starts, stops, starts......and then is silent
I have the same problem. when i put in a disc while holding down the little button that makes it think it's closed, it starts to spin and if i keep on spinning it it will say loading until i stop spinning it, then it just says no disc.
Jul 16, 2008 | Televison & Video
Hitachi DVD saga
need to replace lens
May 22, 2008 | Microsoft Xbox 360 Console
Disc load error
DVDs spin at constant linear velocity. This means that the disc can be spinning slowly or relatively fast, depending on where the laser is positioned on the disc and what function is being used at the time....accordianman
Dec 18, 2007 | Philips MX3600 System
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
