Question about Frigidaire FMV156DC Microwave Oven
POWER COMES ON WHEN PLUGGED IN
The handle was touchy on our fmv156dca microwave nad you had to wiggle it to work. I replaced the monitor switch and it did not fix it. I switched the top and bottom relay switches and must have a wire crossed, because now as soon as i plug it in the microwave come on. I tried switching back and still does it. The only time it stops when the bottom relay is unplugged. Help PLEASE!
  • Frigidaire Master
  • 9,086 Answers
The orignal problem would have been a loose or misaligned door switch or holder on the lower door switch.
We have the service / repair manual for this model and have uploaded it to our site here to help you.
Page 37 shows the proper wiring and page 34 covers the switch adjustment.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
Instead of replacing the switch mount, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
I would recommend replace both the upper and lower switch now. You can order a universal type here for $5 each postpaid.
Posted on Feb 08, 2009
FMV156DCA Microwave starts on its own
Why not unplug it, and plug it in when you need it. It probably cant be mended for less than its worth! I suspect the timer is shot
Mar 08, 2014 | Electrolux Microwave Ovens
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
FMV156DCA turns on, cook indicator lights but not cooking, timer counts down fine too
Hello epinvegas - Try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, then it sounds like the microwave has a faulty magnetron, wiring failure or control board. Contact a professional to assist with the repairs.
Feb 07, 2013 | Frigidaire FMV156DC Microwave Oven
Frigidaire door/power problem
Sounds like either the latch assembly or hinges too loose to activate the micro switch. TIP: Go to the web and type www.partselect.com enter your model number then scoll down to your part. Click to enlarge exploded diagram on left. Veiw enlarged diagram at top of page. You can print the entire diagram for exact assembly by holding your pointer in the upper left hand corner of diagram. Select the print icon. Now you have what you need. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 19, 2009 | Frigidaire FMV156DC Microwave Oven
Microwave comes on on its own. What can be the problem?
I suggest you see a repairer but until then when ever it's not in use leave the door OPEN
Kind Regards,
J Howard
FixYa Operator
Dec 28, 2008 | Frigidaire FMV156DC Microwave Oven
GE 1339BW002 Microwave stopped working
Yes, there should be a ceramic (tubular) fuse under the cover on the top side where the power comes into the microwave.
Dec 11, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Frigidaire FMV156DC Microwave Oven Logo
143 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
