Question about Denon D-M51DVS System
Unit automatically switches off
In the process of playing a DVD my Denon D-M51DVS system automatically stops playing the DVD and switches to stand-by mode (flashing orange light) The time between turning the machine on and it turning itself off seems to shorten as it continues to play the DVD and thus the machine gets hotter. I have tried to make sure the machine has enough space around it in case overheating is the cause of the shut down problem but to no avail I have experienced the same problem. However, my unit shuts off not just with the DVD player, but with all the functions (e.g. tuner, aux) used. When I increase the volume the system automatically shut off to stand-by mode.
  • 10,594 Answers
Unit has problem in Amplifier Output area and due to over current drain it gets hot and thermal protection circuit shut it down for safety reason.
Qualified tech will check and test why unit get hot and what parts are consuming more then required current causing heat issue.
Posted on Feb 03, 2009
    Brigadier General:
  • 8,619 Answers
Hi!
Please tell the model no. of your tv. Can you smell anything ?
  • Rylee Smith
    Rylee Smith Feb 03, 2009
    Try using your tv and dvd on a diffrent socket. Maybe the socket is bad.
2 Suggested Answers
  • 196 Answers
SOURCE: unit automatically switches off
Maybe all you need is to dust off the DVD player's pickup. I have had this happen several times with several players. After dusting the pickup, those players are still in service.
Posted on Feb 15, 2006
Denon dvd 1730 plays no cds
It is likely a issue with the optical pickup in the unit or the unit needs cleaning (not likely but possible)
Apr 08, 2012 | Televison & Video
Denon 2910 CD player malfunctions
is this happening with all the cds??
the case may be with the cd sometime..where the tracks wouldnt have been properly completed...
Jul 13, 2008 | Denon DVD-2900 DVD Player
Denon AVR 886 only shows analog input
Are your speakers able to handle the 886's power. I have the same reciever and changed by speakers as the Denon would turn off instead of frying the speakers.
As for the digital, have you used the option to change your audio feed and video feed. (for example - I'll show photos through the front input but use the CD -digital for music. Maybe the audio feed is locked onto an analog input. Just a suggestion.
Jan 01, 2009 | Denon AVR-886 Receiver
Denon dvd player freezes in the same place on certain dvd's also sometimes willnot start to play disc unless re-inserted several times. Model D-M51DVS
sounds like its stoping during layer switch, if the player is old its needs to be cleaned. its best to clean it once every 20hrs or so. if you do not have a disk cleaner you should go buy one first. if the player is new return it and get the best dvd player you can buy for any amount the toshiba xde. this player is phenomenal, the best you will be amazed. no i dont work for toshiba but ever since they started making hd dvd players(i know they stopped)there players have become the best. trust me if you dont think so just return it. no harm done. if you want a blu-ray get ps3 I dont like them either but i have to admit after buying (for movies only)my third blu-ray player it is by far the best one. almost as good as the toshiba on standard dvd playback but not quite. good luck.
Oct 02, 2008 | Denon Televison & Video
Denon 500SD
HI
did you get this fixed? I have the same problem. Stuck on stand by doesnt switch on from remote or the unit.
please help
Dec 28, 2007 | Denon DHT500SD System
you could try this http://www.fixya.com/support/t244156-denon_2910_cd_player_malfunctions or clean the lens
Nov 06, 2007 | Denon DVD-2900 DVD Player
Denon S-301 video problems
Theis is a known problem by Denon, you need to get a "patch" by denon to fix the problem. If you hook up to the other video out sources there is no problem (but no HD either)
Jan 30, 2007 | Denon S - SERIES PREMIUM HOME THEATER...
Feb 15, 2006 | Denon D-M51DVS System
Denon D-M51DVS System Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
