Question about Seiko Instruments Smart Label Printer 430 Thermal
How do i open up the smart label printer 430 to add paper?
Yes it was corrected. thank you for following up with me.
Posted on Feb 09, 2009
How do I transfer saved labels from Smart Label Printer 100 to Smart Label Printer 620?
In the SmartLabel directory under Program Files look for a file named label.sll This file holds your SmartLabel 100 addresses. After installing your new SmartLabel printer, copy the label.sll file into the new SmartLabel directory under Program Files. When you open the SmartLabel software, if you don't see your addresses, you may have to use the Import command on the label.sll file to bring your addresses into your new SmartLabel Application
Feb 27, 2015 | Seiko Smart Label Printer 100 Thermal
What in the world!! I have the Smart Label Printer 450, it is not advancing the label, and the power button is flashing. It will not print a label at all at this point, and when it will end up printing a...
Unfortunately, this is usually an indication that the label roll in the printer are too old. This action is by design, compatible labels should have a black rectangle on the reverse side and the Smart Label printer uses the black rectangle to orient the label. This means your Smart Label doesn't think its wasting labels, it's just trying to run through what it considers to be unsuitable labels as fast as it can. If you're only printing one label at a time you can recover some labels by correctly the label's line up after each label you print but there's nothing you can do so that your printer will properly advance its current labels.
Remove the current roll, open a new boxed label roll, remove a sealed roll, cut open the sealed plastic, remove fresh label roll and load it in your Label Printer. Power the label printer back on and press the label advance button, it should correctly line up.
May 08, 2014 | Seiko Smart Label 240 Thermal Printer
Louding lables
You shouldn't have to open the back of the printer. You may be having problems with the platen being too tight to allow you to load labels.
If included a picture to help describe the loading process:
Pulling the lever forward (3) releases the Platen tension. Feeding the labels from the bottom of the roll (4) into the slot shown. With the tension off the Platen you should be able to insert the label all the way through the printer
Apr 04, 2014 | Seiko Smart Label 240 Thermal Printer
I lost the toolbar that has the fonts, font sizes
I lost the toolbar that has the fonts, font sizes on my Seiko 650 printer. Any idea ?
Mar 04, 2014 | Seiko Instruments Smart Label Printer 430...
After printing a label it advances too far wasting the next label
This is usually an indication that the label roll in the printer are too old. This action is by design, compatible labels should have a black rectangle on the reverse side and the Smart Label printer uses the black rectangle to orient the label. Remove the current roll, open a new boxed label roll, remove a sealed roll, cut open the sealed plastic, remove fresh label roll and load it in your Label Printer. Power the label printer back on and press the label advance button, it should correctly line up.
Jan 03, 2014 | Seiko Instruments Smart Label 450 Thermal...
Printer working fine - when it stopped printing in mid of alabel♠
If reinstalling the drivers doesn't work... sadly I think it's time for a new one..!
Mar 30, 2017 | Seiko Instruments Smart Label Printer 430...
Delete it from Control Panel, unplug the USB cable, then reinstall the softwre.
Jan 05, 2009 | Seiko Instruments Smart Label Printer 430...
Hi, My Smart Label Printer 430 was working fine until I unplugged the back 2 cords to change the tape in it. How do I get it to print again?
unplug your Smart Label Printer (slp430) from your pc,
go into your control panel, then to add/remove programs.
remove the slp430 software then reboot your pc.
DONT PLUG IN YOUR SLP430 yet...
reinstall the software that came with the label printer.
follow on screen instructions.
plug power in for the printer
then attatch to your pc.
if this doesnt work let me know ; )
Seiko Instruments Smart Label Printer 430 Thermal Logo
281 people viewed this question
Top Seiko Instruments Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Seiko Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
