Question about Sony Audio Players & Recorders
Cant get equalizer to work with my receiver
Yes when I try to hookup my adc soundshaper two mark 3 equalizer to my sony str-de 197 receiver it doesnt work.Is it because the receiver doesnt have any tape monitor buttons?I had it hooked up before to an older 70s sanyo receiver which had monitor buttons and it worked fine.But that receiver quit working.So now im trying to get it to work with my new sony but with no luck yet.
    Problem Solver:
  • 7 Answers
This might work fish76, The EQ needs a in & out source to operate correctly? If you have audio device connected to an aux input disconnect that & connect the EQ to that audio device & then plug the EQ to the Sony receiver AUX input. The tape monitor is the most important source for hooking up an EQ device, so you are very limited on a total receiver or amp tonal connection source. The bottom line is you can only use the EQ if another audio source to plug into it & the EQ plugs to your pre-amp input on the back of your rec or amp
Posted on Feb 04, 2009
Using an equalizer with a Sony STR-DE 475
I think I must have missed something. Where does the EQ get hooked up to on the Sony STRDE 475? Thanks, Nicolas
Nov 22, 2012 | Audio Players & Recorders
Unit won't turn on. There's power to the outlet but the reciever just won't light up! Sony STR-DE 197 It's only a couple of years old and shows no damage.
Failure of the the power source. To see if it's fixable the receiver will have to be opened and the power board tested . This job requires at least a basic experience in electronics - if you don't posses it all you can do is to look for a burned fuse or damaged capacitors. For them follow this
http://www.youtube.com/watch?v=YCSNWi3UHf4
Sep 05, 2011 | Sony STR-DE197 Receiver
Can I hookup a Sony receiver STR-DE505 to a Bassbite 2 KLH Audio system and how??
Yes.
It's frustrating that KLH manuals seem impossible to find anywhere online BUT a simple picture will suffice...
Go here and supersize the picture of the rear of the sub...
http://cgi.ebay.com/KLH-Audio-Systems-Bassbite-V-Model-E214708-Speaker-/110673631693
Run your front channel speaker wires to the CLEARLY-MARKED connectors on the sub and daisy-chain your front speakers to the CLEARLY-MARKED connectors on the sub.
Adjust the sub volume to match the front speakers levels. This will give you local volume control at the Sony.
Jun 04, 2011 | KLH BB-II Subwoofer
Remote's will not work with my Sony STR DE-485
the ir feed receiver amplifier has failed a common sony fault on older units a fix is about $100.00 or use a repeater ir blaster from circuit city for $40 and try that you can return if no success the repeater eye covers the receivers originaland pumps up the out put into the unit
Sep 09, 2009 | Sony STR-DE485 Receiver
Getting the best out of my Sony STR DE-475
Yes, it would downgrade.
Simply run an HDMI cable to the LCD from the DVD player. Now, use the digital audio output of the DVD player to run to the receiver. I know the Sony has an optical input which i recommend over the coaxial input as the optical cable doesnt waste any energy as a medium transferring sound since its only light.
Mar 29, 2009 | Sony STR-DE475 Receiver
Remote control won't work
Could need a new ir sensor or repair solder connections on the display (ir) board. You can check that the remote is putting out a signal by viewing it with a camcorder, turn the camera on look through the viewfinder and point the remote at it push a button. If it is working you will see a flashing light on the remote.
Feb 08, 2009 | Sony STR-DE197 Receiver
Equalizer connections
Usually you hook your equalizer between the pre out and main in RCA jacks and then open the connection between the pre and main with a switch. If your unit doesn't have pre out/ main in jacks then I have seen it done by putting your equalizer between the tape in and tape out jacks and then select that tape function on your front panel. The tape out goes to eq. in and the eq. out goes to tape in. Good luck.
Jul 25, 2008 | Sony STR-DE485 Receiver
Remote Doesn't control stero
Blinking doesnt always mean that the IR transmitter is working in the remote.
Check a couple-few of the online remote dealers you may be able to get one cheap.
Feb 24, 2008 | Sony STR-DE875 Receiver
Can I still used this equipment
Hi Jerome
You will need either a pre-in pre-out connection on the amp to use, A vcr in/out loop can be used in lieu of a "tape" loop. Or alternatively you can put the EQ in line with the bit of gear you want to EQ. In this day and age, of "many more than stereo" systems, a 2 channel EQ has much less application. Although this seems to "outdate" a piece of gear, most stuff from yesteryear still sounds great, so why stop using it. Good Luck and happy listening. A "FixYa" rating from you would help my profile. I am happy to answer any questions you may still have, put them in here and I shall get back to you.
regards
GRaeme
Jan 21, 2008 | ADC Kentrox SS-315 Home Equalizer
Connecting sony str/k660p to dvd recorder and tv
Hello jvirgil,
Go to http://esupport.sony.com/US/perl/model-home.pl?mdl=STRK660P&LOC=3
and under the hot topics section, click on "Hookup Recommendation Guide", select the components you want to hookup (Dvd recorder and receiver in your case. TV hass been autoselected). Click continue, select all the different inputs/outputs that your components have, click on Recommend my Hookup and... 'voila' you get your personalized connection guide. Hope this helps.
cancerags
Dec 27, 2007 | Audio Players & Recorders
299 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
