Question about Saeco Aroma Espresso Machine
Saeco Aroma now only produce bitter coffee...
I bought this machine last Summer and it produced excellent coffee until about a month ago.
I still use the same coffees grinded at the same places, so it's not a matter of what I put inside the machine.
I decalcified. I brought the machine back to SAECO and they opened it, cleaned, tested (probably did not taste although I clearly explained the problem), brought it back home and the problem remains: a bitter coffee bad enough to make me wish for a Tim Horton's dish water instead...
One thing SAECO asked over the phone before I brought the machine in: does it take longer before the red light appear when I put the machine ON. Answer is clearly: yes it does. But they did not seem to see anything wrong when they actually tested it.
Anyone has experienced that or has an explanation ?
  • 22 Answers
May I add that after cleaning, the best for your machine is to use deionized water, not just merely bottled water. If you cannot find deionized water, select water with the lowest dissolved solids. Some bottle water is really hard and will scale the internals just as fast as tap water.
As for bitterness... I'm not si sure you had the machine carefully looked at. Bitterness can be the result of overheating. Ideally the water should be heated at 91C, and exit the portafilter at about 65C. Overheating will burn the coffee. Maybe it's time you replaced the main thermostat...
Posted on Mar 22, 2010
besides a good coffee machine, 2 things are critical when you want a good cup of coffee; the coffee itself and the water. When in France, i tasted some of the best coffee I have ever had, but they always told me that the quality and purity of the water made for 50% of that great taste. Has your municipality changed anything about the water treatment recently? Do you drink that same water and find it tastes funny? Perhaps bottled water is a solution in your case. Hoping this helps.
Marc
Posted on Feb 04, 2009
Hi,I just bought a Aroma Saeco Manual Expresso machine from Amazon.
make your concerns known directly to amazon and if they will not assist then return it for a refund as it is not fit for the purpose
Feb 07, 2016 | Saeco Aroma - Stainless-Steel
Bitter coffee
you must read your instr. manual and proceed with the section troubleshooting from helps and solution . Download your manual from www. retrevo.com or www.fitness.manualsonline.com
God bless you
Jul 23, 2012 | Saeco Odea Giro Plus Automatic Espresso...
Hi - a couple things... 1-Coffee is bitter + not creamy (I know it is not the bean b/c it produces nice a smooth creamy coffee in another machine) 2-water leaks into the drip tray (sometimes grind too)
One possibility is that the grinding is too fine and the coffee is running slowly. Turn the coffee grinder udjust so the coffee will be more groase and the coffee will run faster. For a 30 cc coffee need around 20-25 sec.
Jan 02, 2010 | Saeco Vienna SuperAutomatica Coffee...
My machine will not froth milk
This problem developed on my Sirena machine about a week ago. Stopped frothing milk, but still produced lots of steam. In fact, it was splattering milk everywhere, just not producing foam. Cleaned the steam wand (including air intake) and descaled the machine (even though its only 3 months old) to no avail. Called Saeco customer support (1-800-933-7876) and the very helpful rep immediately identified the problem. Inside the Panarello steam wand is a removable plastic tube. The tip of this tube should protrude about 1/8" beyond the end of the steam wand. Mine was not. Using the eraser end of a pencil, I pushed the inner tube downward into position and, voila, I now have froth again.
Nov 01, 2009 | Saeco Starbucks Sirena Espresso Machine
Our Saeco Vienna deluxe had a couple of problems: the grinder wouldn't stop grinding..coffee all over the place...stopped it cleaned it and it's ok. The other problem is that it takes forever for a small...
What does the coffee produced taste like, is it bitter and watery, is there any creama on the espresso shot. Try adjusting the grind and the coffee level, maybe a little coarser.
Mar 26, 2009 | Saeco Vienna De Luxe Espresso Machine
How to clean the saeco aroma ??
Buy an espresso machine descaling agent (they come in packets, and you can get them all over the internet), and follow the instructions that come with it. Do NOT use vinegar like you might use on a drip machine.
Feb 09, 2009 | Saeco Aroma Espresso Machine
Curious
Try to descale your machine, if there are calcium in the boiler then the coffee will have wrong temperature and tast bad.
Aug 06, 2008 | Saeco Aroma Espresso Machine
Coffee suddenly bitter
Have you descale your machine?
Mar 11, 2008 | Breville ESP8XL Espresso Machine
Coffee Makers & Espresso Machines Logo
698 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
