Question about Saeco 00034 Incanto Sirius Super Automatic Espresso/Coffee Machine
SAECO Incanto Sirius Brew Group
My Incanto Sirius Brew Group doesn't seem like it's "clicked" into the unit. When I remove the Dreg Drawer, the Brew Group comes out with it. I can't get it to stay in there while removing the Dreg Drawer.
    President:
  • 1,618 Answers
When you remove brew unit look on the back you will notice a small latch near the top, make sure it is in the up position.
Posted on Oct 07, 2009
How to change brew group rubber orange gasket on saeco Incanto Sirius
google for USA-Incanto Rondo SBS-RS, E74088 Rev. 03.pdf
it has an exploded view of the brew unit. partsguru has the part.
Jan 30, 2013 | Saeco Vienna SuperAutomatica Coffee...
I have a Saeco Incanto S-class sirius machine. Message displayed, "Brew Group Blocked", so I purchased a new Brew Group Unit, when I installed it, got the same message. when turned on, I can...
Brew group blocked is normally displayed when there is no water flowing through the brew unit. Remove the brew unit and use a small screwdriver(make sure machine is off and cooled), then gently lift up on cross section fitting on white plastic valve inside the machine, if water flows out it works, now we will plug in machine keep brew unit out and turn it on and press fitting in again, if water flows and pump kicks in and water flows out from valve and not under machine you are good, The coffee grind might be too fine and needs to be adjusted to coarser.
Jun 28, 2011 | Saeco Incanto Sirius Fully Automatic...
I have a Saeco Odea Go and my puck in the dreg drawer are really wet and I have water leaking (brown so with coffee) under the dreg drawer. how I can fix it ?
I recently had this problem. I throughly cleaned and lubricated the brew group as directed by the manual. Apparently if the brew group doesn't move smoothly enough it won't grind the correct amount of beans. Try lubricating and then brewing 2-3 cups to have the machine recalibrate the grind amount.
Jan 12, 2011 | Saeco Odea Go
Saeco Incanto Deluxe brewunit jammed
Remove the dredge drawer. Open the door. On the left side of the brewing unit, and towards the back of the brew group, there is a single screw. Remove the screw. Grab the handle and pull carefully, but firmly with a quick ****. The brew group should come out. There is a piece that remains in the machine. Slide that piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position.
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. (You can insert your key into the hole in the front and twist the key to return the brew unit to the center. Line up the 2 diamonds and it centered) If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit,(it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door and turn on the machine without having the brew group in, but you must have your drip tray and dredge drawer in. Turn the machine on. You will hear the motor turn on and when it stops completely, open the door and remove the tray, now insert the brew group and replace the tray.
Mar 04, 2010 | Saeco INCANTO DELUXE Espresso Machine
Should be brewing but little or no coffee comes
Check the end of the steam wand and the parnello it may be blocked use a paper clip to clear, as for the brew unit the shower screen may be blocked it will have to be removed and cleaned. It is located under the red o-ring, then adjust the grind coarser. If that solves the problem for the coffee, but the steam wand solution does not work then it is clogged higher on the line in the system.
Nov 11, 2009 | Saeco Incanto Sirius Fully Automatic...
Hello. I have had my Incanto Sirius S-Series for
check your brew valve,maybe is plugged or leaking in tray.
Sep 03, 2009 | Saeco Incanto Sirius Fully Automatic...
Dregdrawer full message will not go away
Have you tried removing the drawer with the machine on, leave it out for say 2 minutes and then replacing the dreg drawer again?
There is no dreg sensor. Dreg drawer full works off a counter - depending on when the counter was last reset your drawer may be full but it may be empty.
Simply removing the dreg drawer and replacing it quickly will not reset it. The machine has to think that you have actually taken the time to empty it - a couple of minutes should cover this.
If this does not resolve the issue, you need to get a Technician to take a look.
I hope this helps
Aug 26, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Brew unit blocked
You can remove the brew group by following the "how to remove a jammed brew group?" on this page http://cerinicoffee.com/Saeco_technical_documents.asp
For Cleaning Supplies and Saeco Parts visit:
www.cerinicoffee.com
May 30, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
I have the saeco incanto sbs rapid stream and the red light stating that the door is open will not turn off
that can mean that the brew group is not in the right place, the dreg drawer or door.
Please check all three of them
Apr 07, 2008 | Saeco Incanto Classic Espresso Machine
Saeco 00034 Incanto Sirius Super Automatic Espresso/Coffee Machine Logo
580 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
